POV-Ray : Newsgroups : povray.general : Github repository with useful macros Server Time
4 Jul 2025 00:26:58 EDT (-0400)
  Github repository with useful macros (Message 11 to 20 of 43)
Subject: Re: Github repository with useful macros
Date: 19 May 2021 16:05:00
Message: <web.60a56e87985098ff8e52cc8789db30a9@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > At the moment the macros are made for POV-Ray v3.7,
> > but they should also work in v3.8.
> If a macro is made for version 3.7, then, it will run in version 3.8.
> To my knowledge, anything that works in version 3.3 to 3.7 will run in 3.8.
Hi Alain
Yes, that is my understanding too. But I'm hesitating to claim that they work in
v3.8 before I or someone else have actually tested them there.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 20 May 2021 09:35:35
Message: <60a665a7$1@news.povray.org>
On 5/19/21 3:55 PM, Tor Olav Kristensen wrote:
> I have also rewritten a few of the macros slightly and added some new ones.
I like how macros using functions of transforms & inverse transforms
ended up. :-) Those, I didn't expect you to change and yet what you did
looks to me to be a clever approach to handling a macro's dynamically
defined functions.
I'll have to spend more time thinking about it and the actual inner
workings. I suspect you've gotten to something near like what happens
with prod and sum internally with the vm.
>> A millsion calls.
Yes, I'm forever inventing new words! :-) I've not a clue how I arrive
at some of them.
I noticed in your vectors.inc the indenting occasionally varies. It
looks like you mostly use increments of four - which is very common -
but OrthogonalVector, for example, uses three. I'd guess because it was
that in math.inc ?
I've been looking more at your Mean, Variance, Minimum, Maximum,
PrintStatistics, and Histogram suggestions. First, issue I hit was
testing your comments about vectors.
// Does also work for vectors
#macro Mean(Values)
However, dimension_size() expects an array identifier. Is there some
trick to getting vectors to work with dimension_size()?  As far as I
know, the dimension* SDL keywords work only with array identifiers and
'defined on call' arrays. The latter meaning:
    Mean(array {0.1,0.2,0.3,0.4,0.5})
is OK to do. Yes, this last bit is a little more than what our current
documentation says you can do.
I've recently moved the vector analysis macros in math.inc to a
vectoranalysis.inc include - which itself won't be a 'core' include.
Thinking the array statistics a better fit in a similar
arraystatistics.inc include - again now not a 'core' include.
With your vectors.inc, on the other hand, I'm starting to lean toward it
being a 'core' include file. Need to resolve collisions with math.inc
macros as a start.
Aside: Instead of moving some of the contents of arraycoupleddf3s.inc to
arrays.inc, I went the other way! I moved the ARRAY_WriteDF3 macro into
arraycoupleddf3s.inc alongside the ARRAY_ReadDF3 macro already therein
along with some other DF3 related macros. I dropped too the ARRAY_
prefixes. I now plan to treat arraycoupleddf3s.inc as a core include
file. I believe reading and writing DF3s should be doable from SDL as
'POV-Ray' is shipped.
Bill P.
Date: 20 May 2021 14:25:00
Message: <web.60a6a942985098ff786fa93e89db30a9@news.povray.org>
> that in math.inc ?
Yes, sorry about that. I hope I've fixed it now.
Years ago, when I had a tiny monitor, I used 2 spaces for indentation. Now I
prefer 4. 3 is very odd !  And I really hate indentation with TABs. (Because
stuff jumps around - and very seldom ends up where it looks consistent and
nice.) The Golang linter use TABs for indentation, so it's not very likely that
I will love to program in Go.
Good. I'm not sure if I like that the minimum and maximum values in the
Histogram macro always ends up at the "edges" of the outer bins. Perhaps someone
well-versed in statistics can give some advice here.
> #macro Mean(Values)
Try this:
#declare SomeVectors2D =
    array[5] {
        < 1,  5>,
        <-2, -2>,
        < 6,  3>,
        < 0,  2>,
        < 3, -1>
#declare vMean2D = Mean(SomeVectors2D);
#declare vVariance2D = Variance(SomeVectors2D);
#debug "\n\n"
#debug concat("<", vstr(2, vMean2D, ", ", 0, -1), ">")
#debug "\n"
#debug concat("<", vstr(2, vVariance2D, ", ", 0, -1), ">")
#debug "\n\n"
#declare SomeVectors3D =
    array[5] {
        < 1,  5,  3>,
        <-2, -2,  0>,
        < 6,  3, -4>,
        < 0,  2,  2>,
        < 3, -1, -5>
#declare vMean3D = Mean(SomeVectors3D);
#declare vVariance3D = Variance(SomeVectors3D);
#debug "\n\n"
#debug concat("<", vstr(3, vMean3D, ", ", 0, -1), ">")
#debug "\n"
#debug concat("<", vstr(3, vVariance3D, ", ", 0, -1), ">")
#debug "\n\n"
#error "Finished"
- and so on...
Tor Olav
http://subcube.com
Date: 20 May 2021 17:46:37
Message: <60a6d8bd$1@news.povray.org>
That's not always the case.  See, for example:
  https://news.povray.org/5cb13ce4%40news.povray.org
Also, where do you find POV-Ray 3.3?
Date: 21 May 2021 04:17:48
Message: <60a76cac$1@news.povray.org>
On 5/20/21 2:24 PM, Tor Olav Kristensen wrote:
> Try this:
>      array[5] {
>          < 1,  5>,
>          <-2, -2>,
>          < 6,  3>,
>          < 0,  2>,
>          < 3, -1>
Ah, OK! I was thinking only in terms of sets of floats. Still arrays,
but arrays of vectors.
With the introduction of mixed arrays in v3.8, I guess, so long as we
are willing to work in terms of the largest defined vector and take the
unspecified components of shorter vectors as being zero, things will
work out.
There is an exposure if someone drops in a float in the wrong place. We
get two different answers with a set up like the following where the
Mean of the SomeVectorsA is OK if you take the float as being promoted
to a 4 component vector, but that of SomeVectorsB is not because at the
time of the addition the parser doesn't know the max vector size in the
mixed array is four.
#declare SomeVectorsA =
     array mixed[5] {
         < 1,  5>,
         <-2, -2, 0, -1>,
         < 6,  3>,
         < 0,  2, 0, +2>,
         0.123
#declare SomeVectorsB =
     array mixed[5] {
         0.123
         < 1,  5>,
         <-2, -2, 0, -1>,
         < 6,  3>,
         < 0,  2, 0, +2>,
Mean <1.0246,1.6246,0.0246,0.2246,0.0000> SomeVectorsA
Mean <1.0246,1.6246,0.0000,0.2000,0.0000> SomeVectorsB
Would it be enough to recommend against mixed array usage? Or might we
test for mixed arrays in some way and stop, though, I have no idea how
to do such a thing at the moment.
Aside 1: If someone drops a non-numeric thing into a mixed array the
parser appropriately generates an error.
Aside 2: If someone uses color the length always goes to the full five
color component vector. It's possible with colors to mix lengths of
vector specification - even in the traditional non-mixed array case.
     rgb 1,           // promoted to 1,1,1,0,0
     color 1,         // warning. promoted to 1,1,1,1,1
     rgb< 0,  2>,     // promoted to five components. Trailing 0s
     rgb< 3, -1, 1>   // Same
     rgb< 1, 2, 3, 4> // Warning and 4th component used. 5th 0.
     rgbf<1, 2, 3, 4> // 4th used, no warning. 5th 0.
Maybe behavior all just what it is - user beware?
Bill P.
Date: 21 May 2021 05:10:00
Message: <web.60a77745985098ff8e52cc8789db30a9@news.povray.org>
> > Try this:
> >      array[5] {
> >          < 1,  5>,
> >          <-2, -2>,
> >          < 6,  3>,
> >          < 0,  2>,
> >          < 3, -1>
> work out.
>      array mixed[5] {
>          < 1,  5>,
>          <-2, -2, 0, -1>,
>          < 6,  3>,
>          < 0,  2, 0, +2>,
>          0.123
>      array mixed[5] {
>          0.123
>          < 1,  5>,
>          <-2, -2, 0, -1>,
>          < 6,  3>,
>          < 0,  2, 0, +2>,
When I see this I'm thinking that users that try to calculate the mean or
variance of an array containing mixed vectors deserves the messy result that
they may get.
My opinion is that POV-Rays automatic vector promotion is a design flaw. It
allows users to write code that is confusing and not so clear. And it creates
some hard to find errors.
Now I'm tempted to rewrite those macros so that they fail immediately if the
array contains anything else than floats. Perhaps it is best to not mention that
the mean() and variance() macros can be used with anything else than an array of
floats.
We can not, and should not, try to anticipate and warn/guard against all the
crazy things that users may do with macros. That would make them big, clumsy and
hard to read and understand.
If we keep the macros like they are now, then yes; we should have a user beware
warning.
Tor Olav
http://subcube.com
Date: 21 May 2021 06:45:00
Message: <web.60a78dd0985098ff1f9dae3025979125@news.povray.org>
> they may get.
I would agree that some features are more problematic than others, especially
for newer users.   Is there a way to add, multiply, or test for [nonexistant]
vector components with dot-notation in order to purposefully invoke the vector
promotion and force everything to me the largest vector size (5?) from the
start?
[Just as a related aside, what would be useful is a way to perform typical
mathematical functions like cosine on vectors and get a vector result.]
True, however one can have a scene containing all the cases one might think are
tricky or at least not obvious, and that allows plenty of room for doing all
sorts of things that have no proper place in a macro.
Macros, functions, and the documentation are the (overly brief) textbooks of
POV-Ray.  Scene files are the lecture and recitation notes.
In engineering, the rule of thumb for how tight a bolt should be is, "Torque it
down until it snaps, then back it off a half a turn."  That's valuable knowledge
to have which is easy to say and scribble on a blackboard, or show in a
demonstration.  However, it's probably not going to make it into the textbook.
> warning.
This is always the most difficult and painful part of writing real-world code.
- Bill
Date: 21 May 2021 16:15:00
Message: <web.60a81382985098ff47eee7f589db30a9@news.povray.org>
> defined functions.
The global namespace for functions have troubled me for many years. Local
variables inside macros holding functions does not really work the way it IMHO
should.
Now I'll go through some of my other old macros to see if the same trick can be
applied in any of them to get rid of "named functions".
I also wonder if "hiding" functions inside an array or a dictionary is a good
and robust way to avoid function related name clashes. But I guess we will still
have to struggle with name clashes related to the function parameters.
Sorry, but I don't understand what you mean here. I've never studied the
internals of that vm.
I agree with you, neither the vector analysis macros nor the array statistics
macros belong in a core include file. They are for users with special needs.
> macros as a start.
I'm happy to hear that :)
I've now added some documentation for vectors.inc in the Github repository.
Yes, that is a sensible move.
Btw.:
Have you considered using sum() in the FnctNxNx9ArrayEntryToDBL() macro in
arraycoupleddf3s.inc ?
Tor Olav
http://subcube.com
Date: 21 May 2021 17:35:00
Message: <web.60a82635985098ffdb12715a89db30a9@news.povray.org>
> > they may get.
> start?
I don't think that it is possible to investigate the number of components in a
vector without it being promoted automatically or having POV-Ray halt on an
error.
It would have been nice to have some functionality like with Python's
try-except-else-finally statements.
But I assume that that would be a huge task to undertake in POV-Ray. So perhaps
we could implement something like #ifdef (v0.z) instead.
I take it that you would like to be able write things like cos(v0) and then the
cos function will be applied to all of the components of the vector. If so I
second that. But only if that if is done with a built in functionality. I don't
like the macro's we currently have in the include files for such things.
To see how I've provided a similar functionality in my scikit-vectors Python
library:
- Look at the cells 'In [26]' and 'Out[26]' in this file:
https://github.com/t-o-k/scikit-vectors/blob/master/skvectors/doc/Using_a_Vector_Class.pdf
- and at the cells from 'In [48]' to 'Out[52]' in this file:
https://github.com/t-o-k/scikit-vectors/blob/master/skvectors/doc/Using_a_Fundamental_Vector_Class.pdf
Good analogy.
Funny :) I haven't heard that one before.
> > warning.
Yes, you are right about that.
I hate writing documentation. I suspect that one of the reasons for this is that
I'm struggling very much to be concise and precise with a rich, varied and good
language and at the same time use correct terms for the topic (or profession ?).
Tor Olav
http://subcube.com
Date: 22 May 2021 00:10:00
Message: <web.60a88326985098ff60e0cc3d949c357d@news.povray.org>
> error.
It is possible to do certain tests.  For example, this macro tests to see
whether or not v_Padding has a .t component.  This macro is ad hoc, but perhaps
a more general macro can be written.  I have not found a way to distinguish
between a scalar and a macro, though.
----------[BEGIN CODE]---------
// Convert input to a 4-D vector.  If the input is a 2-D or 3-D vector, then
// use the .y component for .t.
#macro Caption__Get_padding (v_Padding)
  #local caption_Promoted = <0, 0, 0, 0> + v_Padding;
 // See whether .t exists:
  #local caption_Test1 = v_Padding + 1;
  #local caption_Test2 = v_Padding + 2;
  < caption_Promoted.x,
    caption_Promoted.y,
    caption_Promoted.z,
   // Test whether .t exists:
    ( (<0, 0, 0, 0> + caption_Test1).t = (<0, 0, 0, 0> + caption_Test2).t?
      caption_Promoted.y: caption_Promoted.t
    // N.B.  Although a scalar tests incorrectly as having a .t component, it
    // doesn't matter, because the returned 4-D vector is the same either way.
-----------[END CODE]----------
