POV-Ray : Newsgroups : povray.general : Github repository with useful macros Server Time
23 Feb 2025 08:14:11 EST (-0500)
  Github repository with useful macros (Message 1 to 10 of 41)
Subject: Github repository with useful macros
Date: 16 May 2021 12:15:00
Message: <web.60a143e3bfdf59778e52cc8789db30a9@news.povray.org>
I have now created a new Github repository with POV-Ray macros that I think is
useful.
https://github.com/t-o-k/Useful-POV-Ray-macros
The vectors.inc file contains these vector related macros:
ScalarTripleProduct()
VectorTripleProduct()
VectorCos()
VectorSin()
AngleBetweenVectors()  <--  VAngle() in math.inc
AccurateAngleBetweenVectors()
ScalarProject()
VectorProject()  <--  VProject_Axis() in math.inc
ScalarReject()
VectorReject()  <--  VProject_Plane() in math.inc
OrthogonalVector()  <--  VPerp_To_Vector() in math.inc
AltOrthogonalVector()
VectorAxisRotate()  <--  Built in vaxis_rotate()
VectorReorient()
VectorTransform()  <--  vtransform() in vtransforms.inc
VectorInverseTransform()  <--  vinv_transform() in vtransforms.inc
MatrixTransform()  <--  Matrix_Trans() in transforms.inc
AxisRotateTransform()  <--  Axis_Rotate_Trans() in transforms.inc
ReorientTransform()  <--  Reorient_Trans() in transforms.inc
At the moment the macros are made for POV-Ray v3.7,
but they should also work in v3.8.
There are links to relevant Wikipedia articles in the file.
Tor Olav
http://subcube.com
Subject: Re: Github repository with useful macros
Date: 17 May 2021 04:05:01
Message: <60a223ad$1@news.povray.org>
Tor Olav Kristensen wrote on 16/05/2021 18:10:
> useful.
> Tor Olav
> http://subcube.com
Thank you, useful and practical to use.
Paolo
Date: 17 May 2021 05:03:28
Message: <60a23160$1@news.povray.org>
Should the POV-Ray links pages be moved to the wiki?
Mike
> useful.
> VectorCos()
> VectorSin()
> ScalarProject()
> ScalarReject()
> VectorReorient()
> Tor Olav
> http://subcube.com
Date: 17 May 2021 06:45:00
Message: <web.60a248d9985098ff8e52cc8789db30a9@news.povray.org>
Hi Mike
I'm not sure if that question was meant for me. But if it was - and if you if
you are referring about this page (which is probably very outdated by now):
    http://www.povray.org/resources/links/
- then my opinion is that we should try that.
I also think that we should add a date for when the link was last verified, so
that the link collection is easier to maintain.
Tor Olav
http://subcube.com
Date: 17 May 2021 07:25:00
Message: <web.60a251bd985098ff1f9dae3025979125@news.povray.org>
I know that there used to be a trivial way to have the webpage automatically
check all the links and grey-out any dead/invalid links.
I can't recall the exact format that I used to use, but I believe that it has
evolved into xml.
But yes, dates are nice, but I vote for the greying-out mechanism as well, if at
all possible.
(And if we're playing with hyperlink color schemes, I'd like a bit more
differentiation between the unvisited links and visited links, because they
appear far too similar in the message digest lists)
Date: 17 May 2021 08:28:00
Message: <60a26150$1@news.povray.org>
> useful.
Cool! Very clean work as always. On my list to play with these macros
along with your suggested stats updates.
A comment on local variables.
Where you have multiple references to a local variable, the symbol
definition and look up is likely clearer and faster.
Where you have a local variable with only one reference, however, the
symbol definition and look up is all overhead. There isn't any
optimization which removes / streamlines the operations within macros.
There's a clarity vs performance trade-off in the single reference to
local variable case.
Bill P.
--- Ref.
A millsion calls.
AngleBeteenVectors without Dot
9.66user 5.30system 0:15.48elapsed
9.54user 5.44system 0:15.51elapsed
9.52user 5.49system 0:15.54elapsed
9.76user 5.14system 0:15.44elapsed
   "9.66 9.54 9.52"
AngleBeteenVectors with Dot local var
10.19user 5.58system 0:16.29elapsed
10.36user 5.39system 0:16.27elapsed
10.21user 5.48system 0:16.22elapsed
10.44user 5.48system 0:16.44elapsed
   "10.19 10.36 10.21"                 28.72 -> 30.76 ---> +7.10%
Date: 17 May 2021 12:58:47
Message: <60a2a0c7$1@news.povray.org>
If a macro is made for version 3.7, then, it will run in version 3.8.
To my knowledge, anything that works in version 3.3 to 3.7 will run in 3.8.
Date: 17 May 2021 14:09:48
Message: <60a2b16c$1@news.povray.org>
> Hi Mike
> Tor Olav
> http://subcube.com
Yes, all this could be moved to the wiki.
Mike
Date: 17 May 2021 18:40:00
Message: <web.60a2efab985098ff8e52cc8789db30a9@news.povray.org>
> evolved into xml.
> all possible.
An automatic check feature that can flag problematic links sounds good.
But I guess that it will not be able to detect all place-holding and parasitic
web pages that any new domain owners have placed there instead of old pages. So
manual checks will probably also be needed.
Yes, I agree.
Tor Olav
http://subcube.com
Date: 19 May 2021 16:00:00
Message: <web.60a56d1f985098ff8e52cc8789db30a9@news.povray.org>
Thank you for testing this Bill. - And for mentioning this performance issue.
As you say it's a clarity vs performance choice. Normally I prefer to go for
clarity and readability before performance. I also think that we should try to
make it easy for new users to learn from the code in the standard libraries. So
when I made those macros I tried to make it easy to recognize the parts that are
similar.
Further I think that descriptive, non cryptic variable names serve as part of
the documentation. (Some seem to think that programming in POV-Ray's SDL is a
continuous short code contest.)
But the macros in question are not so big and complicated, so I have followed
your advice and removed all but one of the local variables that are only
referenced once.
I have also rewritten a few of the macros slightly and added some new ones.
> A millsion calls.
Tor Olav
http://subcube.com
