POV-Ray : Newsgroups : povray.general : POV-Ray Installation thread Server Time
25 May 2024 15:57:37 EDT (-0400)
  POV-Ray Installation thread (Message 32 to 41 of 61)
Subject: Re: POV-Ray Installation thread
Date: 15 May 2021 07:53:59
Message: <609fb657$1@news.povray.org>
On 5/15/21 7:48 AM, William F Pokorny wrote:
> '/home/pokorny/bin/povr --version'
Grumble... No idea why I was adding single quotes to many of the
commands. Run the commands without them. Old brain glitching. :-(
Bill P.
Date: 15 May 2021 12:35:00
Message: <web.609ff80c2344a9a179819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> The cannot create state file is what I got too - with 'povr' - when
> trying reproduce your fork issue last night and not having permissions
> to write to the current directory.
had never seen a cannot create file error until reading this, then got one when
preparing to try TdG's granite macro.  :-)  turns out, having a (now)
non-existing directory in the .ini file "works" too.
regards, jr.
Date: 15 May 2021 13:10:00
Message: <web.609fff5d2344a9a11f9dae3025979125@news.povray.org>
> Let's start the debugging with the commands above.
> Bill P.
bald@Alienware ~/povray38/scenes/objects $ which povr
/home/bald/bin/povr
bald@Alienware ~/povray38/scenes/objects $ echo $PATH
/home/bald/bin:/home/bald/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local
/games:/snap/bin
bald@Alienware ~/povray38/scenes/objects $ /home/bald/bin/povr --version
bald@Alienware ~/povray38/scenes/objects $ ls -lt /home/bald/bin/povr
lrwxrwxrwx 1 bald bald 50 May 14 15:37 /home/bald/bin/povr ->
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povr
Date: 15 May 2021 14:59:41
Message: <60a01a1d$1@news.povray.org>
>> Bill P.
> /home/bald/bin/povr
> /games:/snap/bin
Thanks.
OK, so it looks like you established a symbolic link from
to:
/home/bald/bin/povr
There isnt' a bin directory shipped with
povray-3.8.0-x.povr_b0bcf6c0 so guessing you created it and the povr
script/command within the directory?
I've spent some time trying to reproduce the null result and I can
indeed do it if the file:
is empty, but, the read and execute bits are set true. The command then
just does nothing. So, a guess would be the file is empty - or just does
nothing.
To run the in-place compiled code, that link target file should contain
something like:
#!/bin/sh
COMPILEDIR=/tmp/povray-3.8.0-x.povr_b0bcf6c0
unset POVINI
export POVINC=${COMPILEDIR}/include
${COMPILEDIR}/unix/povray $@
Something else which could be tried if you think the contents of the
file look OK, is to point your bin directory link at say the 'ls'
command. My 'which ls' returns /bin/ls. So
ln -fs /bin/ls /home/bald/bin/povr
Then run again:
It should be it returns the ls command version. This would be a sanity
test that nothing otherwise off with system sym links or something.
Bill P.
Date: 15 May 2021 15:45:00
Message: <web.60a0246c2344a9a179819d986cde94f1@news.povray.org>
hi,
just chiming in on this point.  the script I provided installed povr, as a
package, in '/home/povray/povray-3.8.0-x.povr_b0bcf6c0/'.  (installed and owned
by "regular user" BE)
regards, jr.
Date: 15 May 2021 16:39:53
Message: <60a03199$1@news.povray.org>
On 5/15/21 3:43 PM, jr wrote:
> hi,
Ah, OK. Then my guess is the sym link should be to the file:
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povray
and that Bill can probably run
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povray --version
In other words, he isn't really using the 'povr' wrapper script?
...I'm left, though, not understanding why he isn't getting a "command
not found" message if the file:
doesn't really exist on his system...
Bill P.
Date: 15 May 2021 17:10:00
Message: <web.60a0385a2344a9a179819d986cde94f1@news.povray.org>
hi,
agree that the executable should run invoked that way.  will not "butt in"
further, but, as I understand, the symlink in ~/bin points to a bona fide 'povr'
script.  (which only serves to deepen the mystery :-()
regards, jr.
Date: 15 May 2021 18:11:22
Message: <60a0470a$1@news.povray.org>
On 5/15/21 5:08 PM, jr wrote:
> hi,
Do please speak up if you think of more, I'm reasonably lost as to what
might be up. :-)
Bill P.
Date: 15 May 2021 18:15:00
Message: <web.60a046ba2344a9a11f9dae3025979125@news.povray.org>
Sorry for the delay.
Seems that somehow the povr script got deleted but the file was still there.
I redownloaded the file and edited it to read:
#!/bin/sh
INSTALLDIR=/home/povray/povray-3.8.0-x.povr_b0bcf6c0
export POVINC=${INSTALLDIR}/share/povray-3.8/include
#export POVINI=${INSTALLDIR}/etc/povray/3.8/povray.ini
unset POVINI
${INSTALLDIR}/bin/povray $@
exit $?
Seems to render the blob scene fine now.
Not sure how THAT happened.
Thanks for all the suggestions - that helped track down the issue.
Maybe I will do some more fine tuning on this tomorrow.
It's always something ridiculous.
Date: 15 May 2021 19:51:12
Message: <60a05e70$1@news.povray.org>
> #!/bin/sh
> unset POVINI
> exit $?
Good to hear you've made progress.
I just popped back on because I just had the thought on the "failed to
fork" message first reported. One thing which could cause the OS to run
out of resources would be a script calling itself recursively - in an
infinite way. Maybe?
Bill P.
