POV-Ray : Newsgroups : povray.general : POV-Ray Installation thread Server Time
17 May 2024 22:07:22 EDT (-0400)
  POV-Ray Installation thread (Message 31 to 40 of 61)
Subject: Re: POV-Ray Installation thread
Date: 15 May 2021 07:48:14
Message: <609fb4fe$1@news.povray.org>
On 5/14/21 6:31 PM, Bald Eagle wrote:
> William F Pokorny <ano### [at] anonymousorg> wrote:
>>> The 'cannot fork' stuff usually happens when a unix/linux system has run
>>> out of resources to start another process. Lack of memory/swap space,
>>> /tmp, /var - maybe. There are sometimes limits on the number of
>>> processes in place, but this in my experience is not all that common.
>>> For starters you could try running the 'df' command and look at disk
>>> usage. The command 'free -m' can be useful too.
>> - What was your entire command line with flags & ini ?
> Er, for what?
No idea. I'm fishing for cause. :-)
The 'no output at all' you now see makes as little sense to me - as a
likely problem - as did the unable to fork message.
The cannot create state file is what I got too - with 'povr' - when
trying reproduce your fork issue last night and not having permissions
to write to the current directory.
As I expect you know by now, directories installed system wide as
packages or with 'make install' / 'sudo make install' almost always have
an owner of root. Further they are read only except for the owner. Those
permissions should be left as is to prevent accidental corruption.
Normal users - even those able to play as 'root' should work elsewhere
in directories and with files they do own.
The povr script ships in the root build directory but must be modified
and installed somewhere in your PATH. If you type the command:
'which povr'
what do you see?
I see: /home/pokorny/bin/povr because I copied the povr script to my
/home/pokorny/bin directory - which is part of my PATH environment
variable by default. Plus, I updated the contents of 'povr' to point to
the build location directory. You can point the 'povr' script to an
install directory too, if you configured with
--prefix=<eventual_install_dir> before building and after a successful
'make install'.
'echo $PATH'
shows the contents of the search path used for executable commands.
You can execute commands with the full path assuming the permissions are
set for an executable. For example, no matter the current directory
permissions, I can type:
'/home/pokorny/bin/povr --version'
and see in the output:
POV-Ray (povr) 3.8.0-x.povr_19812865.unofficial
This is an unofficial version compiled by: wfp
Further, such a full path command should run in any directory no matter
permissions so long as the permission bits are set correctly. When I use
the command:
ls -lt /home/pokorny/bin/povr
I see:
-rwxr-xr-x 1 pokorny pokorny 806 May 14 17:53 /home/pokorny/bin/pov
Let's start the debugging with the commands above.
Aside: As a general aim I'm thinking most unix/linux users should
install packages maintained for their OS distributions.
For those wanting to play with code branches, a goal of the povr branch
is to NOT use or need 'root' or 'admin' authority at all. Further, to be
able to run as many versions side by side as they wish in local,
smallish, directories without cross interactions - something long an
issue. There are tentative code changes in the povr branch to support
this aim. For more see, for example:
https://github.com/POV-Ray/povray/issues/374
The povr script as shipped is a template, and for users in the playpen,
like me, I have many such scripts pointing to different versions. Where
'povr' as a command is how I execute my most current code and compile.
Bill P.
Date: 15 May 2021 07:53:59
Message: <609fb657$1@news.povray.org>
Grumble... No idea why I was adding single quotes to many of the
commands. Run the commands without them. Old brain glitching. :-(
Bill P.
Date: 15 May 2021 12:35:00
Message: <web.609ff80c2344a9a179819d986cde94f1@news.povray.org>
hi,
had never seen a cannot create file error until reading this, then got one when
preparing to try TdG's granite macro.  :-)  turns out, having a (now)
non-existing directory in the .ini file "works" too.
regards, jr.
Date: 15 May 2021 13:10:00
Message: <web.609fff5d2344a9a11f9dae3025979125@news.povray.org>
> Bill P.
bald@Alienware ~/povray38/scenes/objects $ which povr
/home/bald/bin/povr
bald@Alienware ~/povray38/scenes/objects $ echo $PATH
/home/bald/bin:/home/bald/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local
/games:/snap/bin
bald@Alienware ~/povray38/scenes/objects $ /home/bald/bin/povr --version
bald@Alienware ~/povray38/scenes/objects $ ls -lt /home/bald/bin/povr
lrwxrwxrwx 1 bald bald 50 May 14 15:37 /home/bald/bin/povr ->
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povr
Date: 15 May 2021 14:59:41
Message: <60a01a1d$1@news.povray.org>
>> Bill P.
> /home/bald/bin/povr
> /games:/snap/bin
Thanks.
OK, so it looks like you established a symbolic link from
to:
/home/bald/bin/povr
There isnt' a bin directory shipped with
povray-3.8.0-x.povr_b0bcf6c0 so guessing you created it and the povr
script/command within the directory?
I've spent some time trying to reproduce the null result and I can
indeed do it if the file:
is empty, but, the read and execute bits are set true. The command then
just does nothing. So, a guess would be the file is empty - or just does
nothing.
To run the in-place compiled code, that link target file should contain
something like:
#!/bin/sh
COMPILEDIR=/tmp/povray-3.8.0-x.povr_b0bcf6c0
unset POVINI
export POVINC=${COMPILEDIR}/include
${COMPILEDIR}/unix/povray $@
Something else which could be tried if you think the contents of the
file look OK, is to point your bin directory link at say the 'ls'
command. My 'which ls' returns /bin/ls. So
ln -fs /bin/ls /home/bald/bin/povr
Then run again:
It should be it returns the ls command version. This would be a sanity
test that nothing otherwise off with system sym links or something.
Bill P.
Date: 15 May 2021 15:45:00
Message: <web.60a0246c2344a9a179819d986cde94f1@news.povray.org>
hi,
just chiming in on this point.  the script I provided installed povr, as a
package, in '/home/povray/povray-3.8.0-x.povr_b0bcf6c0/'.  (installed and owned
by "regular user" BE)
regards, jr.
Date: 15 May 2021 16:39:53
Message: <60a03199$1@news.povray.org>
On 5/15/21 3:43 PM, jr wrote:
> hi,
Ah, OK. Then my guess is the sym link should be to the file:
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povray
and that Bill can probably run
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povray --version
In other words, he isn't really using the 'povr' wrapper script?
...I'm left, though, not understanding why he isn't getting a "command
not found" message if the file:
doesn't really exist on his system...
Bill P.
Date: 15 May 2021 17:10:00
Message: <web.60a0385a2344a9a179819d986cde94f1@news.povray.org>
hi,
agree that the executable should run invoked that way.  will not "butt in"
further, but, as I understand, the symlink in ~/bin points to a bona fide 'povr'
script.  (which only serves to deepen the mystery :-()
regards, jr.
Date: 15 May 2021 18:11:22
Message: <60a0470a$1@news.povray.org>
On 5/15/21 5:08 PM, jr wrote:
> hi,
Do please speak up if you think of more, I'm reasonably lost as to what
might be up. :-)
Bill P.
Date: 15 May 2021 18:15:00
Message: <web.60a046ba2344a9a11f9dae3025979125@news.povray.org>
Sorry for the delay.
Seems that somehow the povr script got deleted but the file was still there.
I redownloaded the file and edited it to read:
#!/bin/sh
INSTALLDIR=/home/povray/povray-3.8.0-x.povr_b0bcf6c0
export POVINC=${INSTALLDIR}/share/povray-3.8/include
#export POVINI=${INSTALLDIR}/etc/povray/3.8/povray.ini
unset POVINI
${INSTALLDIR}/bin/povray $@
exit $?
Seems to render the blob scene fine now.
Not sure how THAT happened.
Thanks for all the suggestions - that helped track down the issue.
Maybe I will do some more fine tuning on this tomorrow.
It's always something ridiculous.
