POV-Ray : Newsgroups : povray.general : CSG with sphere sweeps Server Time
27 Mar 2026 22:15:53 EDT (-0400)
  CSG with sphere sweeps (Message 1 to 8 of 8)
Subject: CSG with sphere sweeps
Date: 21 Apr 2021 09:30:00
Message: <web.6080282a9709008e8de81c16a8f0b95@news.povray.org>
OK, it has been a long time since I have used POV for anything but have I
forgotten a rule about using sphere_sweeps with CSG operations?
Below code has exactly the same sphere_sweep but when viewed at the lower angle
I see artifacts:
#version 3.7;
  location  <0, 0.0,-5.0>
  look_at   <0, 0, 0>
// create a regular point light source
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <-20, 40, -20>
// Set a color of the background (sky)
background { color rgb< 1, 1, 1> }
difference {
 box { <-2, -5, -0.1> <2, 5, 0.1> }
union {
sphere_sweep {
    b_spline
    5,
    < 2.2, -1.75, 0>, 0.45,
    < 0, 0, 0>, 0.45,
    <-0.50, 1.25, 0>, 0.35,
    <0.65, 2.5, 0>, 0.025,
    < 0.45, 5.0, 0>, -0.35
    tolerance 0.1
    scale <0.5, .5, 2>   rotate<0,0,0>
   }  // end of sphere_sweep --
sphere_sweep {
    b_spline
    5,
    < 0, 0, 0>, 0.45,
    tolerance 0.1
    scale <0.5, .5, 2>   rotate<0,0,0>  translate<-0.55,-2.1,0>
material {
pigment { rgb <0.01, 0.51, 0.51> }
finish { specular albedo .1 roughness 0.001 brilliance 2 diffuse  albedo 0.9
reflection { 0.05, .1 fresnel on } conserve_energy }
interior { ior 1.6 }
Download 'tmp.png' (20 KB)
Preview of image 'tmp.png'
Subject: Re: CSG with sphere sweeps
Date: 21 Apr 2021 09:51:31
Message: <60802de3$1@news.povray.org>
> I see artifacts:
I'm not aware of any rule.
The scene renders fine with the current v3.8 master branch.
You don't have a cubic sweep, but I think you are very likely(1) hitting
a closed(fixed) issue for a problem Yadgar reported and Christoph fixed
back in 2017.
https://github.com/POV-Ray/povray/issues/287
(1) - I don't have a compile handy at the fix commit to 100% confirm it.
In any case, the current v3.8 is OK.
Bill P.
Date: 22 Apr 2021 02:25:00
Message: <web.60811645a82c9a50e8de81c16a8f0b95@news.povray.org>
Thanks Bill, is there a pre-compiled/binary version of 3.8 or do I need to build
it from source?
Date: 22 Apr 2021 06:30:00
Message: <web.60814f75a82c9a501f9dae3025979125@news.povray.org>
> it from source?
http://www.buckosoft.com/qtpovray/
or compile from source for standard use.
Date: 22 Apr 2021 07:40:00
Message: <web.60816080a82c9a50e8de81c16a8f0b95@news.povray.org>
> > it from source?
Thanks for the link, only seems to be linux based version, is there a Windows
version anywhere?
Date: 22 Apr 2021 08:28:17
Message: <60816be1$1@news.povray.org>
>>> it from source?
> version anywhere?
You can find a collection of pre-compiled versions at:
https://github.com/POV-Ray/povray/releases
marked as pre-releases. I think Development build
v3.8.0-alpha.10064268+av691 was the last non-otherwise experimental one.
Unfortunately, there are known bugs not fixed in these windows binary
releases. Something truer for the newer parser changes related to
dictionaries and arrays. Others (Thomas?) likely know which binary
releases work best for what features.
Bill P.
Date: 24 Apr 2021 02:21:39
Message: <6083b8f3$1@news.povray.org>
Op 22/04/2021 om 14:28 schreef William F Pokorny:
>>>> need to build
>>>> it from source?
>> Windows
>> version anywhere?
That is also the version I use. Afaik, it works fine for everything but
I certainly have not used every feature in its most stressful option. ;-)
Date: 26 Apr 2021 08:50:00
Message: <web.6086b64ca82c9a50e8de81c16a8f0b95@news.povray.org>
Thanks Bill/Thomas,
Will download from there and give it a go.
Sean
