For my recent and continuing 'city buildings' scene, I needed a way to load a
bunch of consecutively-numbered image_maps into an array. The only things that
change in the image_map titles are their numbers. Like...
my image 1 example (with, say, a .jpg extension)
my image 2 example
etc.
So I came up with some string-code to make the task very easy, which might be
useful to others here. (If you have already done this kind of thing previously,
please ignore-- you are smarter than I am!)
For, say, 50 different image_maps...
#declare MY_ARRAY = array[50]; // to create the initial empty array-- the index
is from zero to 49
#for(i,1,50)
#declare MY_STRING =
concat("my image"," ",str(i,0,0)," ","example.jpg")// the i is the re-created
image number. Note the added spaces between the extra double-quotes, to match
the image titles.
#declare MY_ARRAY[i - 1] =
pigment{image_map{jpeg MY_STRING interpolate 2}}
Of course, you could further simplify the #for loop by inserting the entire
concat(...) string into the pigment itself, eliminating the
#declare MY_STRING = ...
To use an image_map later...
pigment{MY_ARRAY[27]}
By the way, if you are using an older version of POV-ray (prior to the #for-loop
addition), a #while loop will work just as well,
hi,
> bunch of consecutively-numbered image_maps into an array. ...
or use a macro and dispense with the array altogether?! eg.
#macro mkPigment(i_)
pigment {image_map {jpeg concat("my image ",str(i_,0,0)," example.jpg")
interpolate 2}}
(hopefully no typos)
regards, jr.
> interpolate 2}}
> #end
That's an interesting idea, and didn't occur to me. It *looks* like it would
work; now I want to test it! Gee, thanks, another test to do :-P
> interpolate 2}}
> #end
Oops, I just noticed the difference between this macro and my array idea-- the
macro doe not actually pre-#declare the image, whereas the array does. The main
reason for the initial ARRAY is that it essentially #declares all of the images
at the outset-- and its main 'reason for being' is that the various images might
be used *repetitively* in a scene (which I forgot to mention!) Pre-#declaring
the images saves a tremendous amount of RAM memory later, when the array
elements are called. Their repetitions are essentially 'instances' of the
image_maps, with little to no increase in memory use. The macro, on the other
hand, would load the image into memory every time it's invoked.
For the macro, I came up with a slight change which *might* make it work
likewise... but I don't think so:
#declare IMG =
interpolate 2}}
That would just re-#declare the image for each macro call, with the same(?)
memory increase...unless each 'newly-#declared' identical IMG just takes the
place of the previous one in memory?
hi,
> Oops, I just noticed the difference between this macro and my array idea-- ...
> the various images might be used *repetitively* in a scene (which I forgot to
> mention!)...
ouch, yes. although I've followed the thread(s), I completely lost sight of the
> #declare IMG =
> interpolate 2}}
> IMG
> #end
not sure, would expect the old to be de-allocated. in case it helps, the name
too could be supplied, eg:
#macro mkPigment(n_, i_)
#local n_ = pigment {...};
but wrt reducing memory, (guessing) an array will be best.
regards, jr.
In this case, you can (easily) do both, since you use numbered image files.
Use the macro, but have the macro update a global array flag with the numbered
entries.
#ifdef () can check to see if an entry has been used, and if so then the macro
can just return the image_map that is already declared, else create a new
(needed) one.
Without numbered filenames, you could just compare the text filenames to see if
they've been used before.
> > [Kenneth wrote]:
> > idea-- ...
> > I forgot to mention!)...
Your comments and posts never waste time, have no fear ;-) They always get me to
think 'outside of my own box'.
