POV-Ray : Newsgroups : povray.general : povray vs uberpov am3 Server Time
28 Oct 2024 14:17:38 EDT (-0400)
  povray vs uberpov am3 (Message 1 to 10 of 33)
Subject: povray vs uberpov am3
Date: 14 Sep 2020 04:45:00
Message: <web.5f5f2ce827df3c2dd797883e0@news.povray.org>
Hello everybody,
when I use am3 (stochastic anti-aliasing) in the latest version (10064738), it
is about 5 times slower then in uberpov:
Persistence of Vision(tm) Ray Tracer Version 3.8.0-x.10064738.unofficial (g++ 7
@ x86_64-pc-linux-gnu)
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       0 hours 20 minutes  4 seconds (1204.944 seconds)
              using 4 thread(s) with 4542.093 CPU-seconds total
UberPOV Raytracer Version 1.37.1.0-beta.10 (g++ 7 @ x86_64-pc-linux-gnu)
Render Time:
  Trace Time:       0 hours  3 minutes 52 seconds (232.382 seconds)
              using 4 thread(s) with 907.615 CPU-seconds total
Command line is:
povray +d +p +q9 +am3 +a0.1 +ac0.9 +r6 AntiAliasingTest.pov
uberpov +d +p +q9 +am3 +a0.1 +ac0.9 +r6 AntiAliasingTest.pov
Does anybody have a clue why povray is so much slower?
Ton
Subject: Re: povray vs uberpov am3
Date: 14 Sep 2020 12:35:57
Message: <5f5f9bed$1@news.povray.org>
On 9/14/20 4:42 AM, Ton wrote:
> Hello everybody,
> Render Time:
> Render Time:
> Command line is:
> Cheers
> Ton
Are the results more or less similar?
I know uber differs in code structure. I've myself run across an am3
case in v3.8 where the run time - on a solid color change - increased
100x. Not yet dug into the latter. Beyond that, no idea.
If the AntiAliasingTest.pov scene is relatively small and self
contained, could you post a copy? I'll at least put it in my issues
directory, though who knows when I might take a look at it.
Bill P.
Date: 14 Sep 2020 17:30:07
Message: <web.5f5fe019aa461a8cd797883e0@news.povray.org>
> Bill P.
Wow, a hundred times slower, and I was complaining about 5 times!
Here is my little test file:
#version 3.7;
global_settings
    assumed_gamma 1
    noise_generator 2
background
    color srgb <0, 0, 0>
union
    #for (I, -25, 25, 1)
        cylinder
            <-20, 0, 0>, <20, 0, I>, 0.01
    pigment
        color srgb<1, 1, 1>
light_source
    <25, 8, 0>, rgb<1, 1, 1>
camera
   location <25, 8, 0>
   right <image_width / image_height, 0, 0>
   look_at <12, 0, 0>
Ton
Date: 15 Sep 2020 10:25:53
Message: <5f60cef1$1@news.povray.org>
>> Hello everybody,
>> (10064738), it
>> Render Time:
>> Render Time:
>> Command line is:
>> Cheers
>> Ton
> Bill P.
i've been using the am3 anti-aliasing in POV-Ray 3.8.0-alpha.10064268 in
conjunction with area lights... i'm able to use adaptive 0 then use am3
to cleanup edges etc... so i'd appreciate you finding /some/ time to see
if some speed gains can be found
Date: 15 Sep 2020 18:25:00
Message: <web.5f613e1caa461a8cd98418910@news.povray.org>
[snip}
on Windows 7...
I don't know if this is useful, but I ran your test scene in three different
version of POV-Ray, using your command-line switches. 800 X 600 render.
1) the experimental build you used (Windows version) which is the most recent--
v3.8.0x.10064738+av694
     render time: 19 seconds
2) the latest development build-- v3.8.0-alpha.10064268+av691
     render time: 23 seconds
3) v3.7.1-beta 9 (which isn't really useful as a comparison-- I had to delete
"ac0.9" from the command line, as this version didn't recognize it)
     render time: 93 seconds
The two 3.8.0 versions produce relatively close render times in Windows... so it
seems that the LONG render time might be Linux-specific(?)
Date: 15 Sep 2020 19:38:40
Message: <5f615080$1@news.povray.org>
> [snip}
> on Windows 7...
linux POV-Ray 3.8.0-alpha.10064268 at 800 x 600 ... 16.116 seconds
Date: 15 Sep 2020 19:44:23
Message: <5f6151d7$1@news.povray.org>
>> [snip}
>> on Windows 7...
>> different
>> recent--
>> delete
>> Windows... so it
when i change version to 3.8 (from 3.7) in the supplied test file...
it's consistently 3 seconds faster
Date: 16 Sep 2020 03:08:41
Message: <5f61b9f9@news.povray.org>
>> Bill P.
Had to recompile my uberpov. The system libraries had changed since I
last compiled. Compiling uber now a bit of a pain as a good many code
and header updates are needed...
Whining ahead of my first morning coffee I guess. :-)
I'll post an image to binary.images, but answering my initial question -
the results are not similar. p380 is am3 working better with your flag
set than is uberpov. This I believe explains the run time difference(1).
Running compiles of the latest commit of both versions, I see the
following slow down uber to v3.8:
2.4 -> 13.02 ---> 442.50%
I also see a bug because in v3.8 we are getting the am3 stats:
...Samples: 0   Smpls/Pxl: 0.00
where we should see >0 samples and samples/pixel >1.0.
(Jim, I see a slight difference v3.7 to v3.8 scene version too 0.5% or
so - not sure what's up there. For performance I run single threaded.
I'd need to do runs forcing longer run times to be sure how real that
difference is I guess - another day perhaps)
Bill P.
(1) - I have a mental itch there was some difference in flag usage
between uberpov and the initial v3.8 implementation - but it's just not
coming to me. Anyone else recall something? Looking at the commit for
v3.8 where am3 came in, it did have additional changes to the base over
uberpov in planning for better interaction with other features like
media. What has or has not been done in that respect for am3 support I
do not know.
Date: 17 Sep 2020 12:25:01
Message: <web.5f638c34aa461a8cd98418910@news.povray.org>
in Windows 7--
I finally downloaded UberPOV from Github after all these years(!), to give it a
try-- the 'plug-in' version that runs within v3.7.0. But I'm running into
problems with Ton's test scene, specifically his command-line settings of
The "+ac.0.9" command is not being recognized. (And yes, I specified #version
3.8 in the test scene itself, in global_settings). That seems strange, as Ton
gets his scene to work in UberPOV...at least in Linux.
The version of UberPOV I'm using is the 'latest' v1.37 (as of late 2016 I
think). Within v3.7.0, it actually shows up as "v3.8.0-alpha.9811560+av591"
But there is also a stand-alone version of UberPOV with its own installer that
Clipka created at an earlier date. I haven't tried that one yet.
Is there an operational difference between the plug-in version I'm using and the
stand-alone version, concerning the "ac0.9" command?
Date: 17 Sep 2020 13:55:24
Message: <5f63a30c$1@news.povray.org>
Le 2020-09-17 à 12:21, Kenneth a écrit :
> in Windows 7--
The «plugin» version need to reside in a sub-folder of another
installation. It piggy back on another installed version.
The «stand alone» is similar but come with all the other files of a
standard version. As the stand alone  version is older, it may contain
some bugs that where fixed in the later version, and lack some
optimizations and features.
You may want to install the standalone version, then, replace the
executable with the latest version.
