POV-Ray : Newsgroups : povray.general : How can we speed up the saving process? Server Time
23 Sep 2025 07:27:03 EDT (-0400)
  How can we speed up the saving process? (Message 1 to 10 of 17)
Subject: How can we speed up the saving process?
Date: 10 Jul 2020 00:20:01
Message: <web.5f07ec455a3258a7ecc0fada0@news.povray.org>
I create a series of simple 4K scenes with 16/32 cores/threads. Each takes 10s
from which the parsing process is <1s, and the rendering process is 9s.
In the rendering time, my CPU threads are used in the first 3s (technically, 1s
as it is a peak). This is exactly the period in which the temporary file
"pov-state" exists.
It takes about 5s to save output.png when almost no CPU resource is used.
Obviously, I hope to reduce this period.
Since the file is small 5-7MB, disk speed cannot be the bottleneck, but I
checked the saving with an SSD and no difference.
I use v3.8 on Ubuntu, and my command is
povray +Iinput.pov -GA +Q11 +MB +UL +UV +A -D -V +TH +W3840 +H2160 +UA
Alternatively, do you have any idea for parallelising multiple processes? In the
above scenario, I have enough resources to run 3-5 POV-Ray commands at the same
time, but the peaks may overlap.
Memory is not an issue at all, as I have abundant, and as you can tell the scene
is not memory-intensive.
Subject: Re: How can we speed up the saving process?
Date: 10 Jul 2020 12:00:01
Message: <web.5f08902e1af26a0660e0cc3d0@news.povray.org>
If this is small, what do you consider large?
Date: 10 Jul 2020 12:42:49
Message: <5f089a89$1@news.povray.org>
> "pov-state" exists.
Those 5 seconds are almost entirely consecrated to the encoding and
compression of the PNG file with only a small bit actually used to
access the drive. It's almost all single thread, sequential data access,
analysis and manipulation.
I'm afraid that it can't get reduced by much, unless you are willing to
reduce the compression factor, resulting in a larger file.
Date: 10 Jul 2020 14:05:00
Message: <web.5f08ada21af26a06ecc0fada0@news.povray.org>
With any modern HDD, writing 5-7MB of data occurs within a fraction of a second.
Date: 10 Jul 2020 14:30:00
Message: <web.5f08b3561af26a06ecc0fada0@news.povray.org>
> > "pov-state" exists.
You are right! I was able to reduce this period by changing the output format.
It is not a matter of compression but data handling since the shortest time was
to save as a lossy JPEG.
Anyhow, I should find a way to do this single-thread process in the background
while starting next rendering.
Date: 11 Jul 2020 00:20:00
Message: <web.5f093d611af26a06ecc0fada0@news.povray.org>
> > "pov-state" exists.
As an update, if it might be beneficial to others.
In my experience, the slowest format to save is PNG. Of course, PNG is the best
and common format in terms of quality and size.
Saving in JPEG is the fastest though it is highly compressed. Unfortunately, a
heavily lossy format like JPEG is not suitable for the purpose of ray tracing.
JPEG with 100% quality is close to PNG (POV-Ray see 85% by default). The
official document emphasises that even with 100% quality, there might be some
artefacts. I am inspecting this failure but haven't found any yet. JPEG with
100% quality is about 40% of PNG size.
As a side note, I believe the default value of compression in POV-Ray (85%) is
too low. The default value in ImageMagick for conversion to JPEG is 92%. It does
not make sense to use many resources to ray trace a scene and save it as a
heavily lossy format.
Date: 12 Jul 2020 06:53:33
Message: <5f0aebad$1@news.povray.org>
Thanks for the information. I found myself thinking about your post...
Where did exr output come out size and performance wise?
There are formats other than exr which don't compress on output - ppm is
another I think, and you can set the depth there to 16 bits per color
channel too. If the uncompressed output is much faster, perhaps use one
of those formats and compress/convert with external scripts?
I'm no image format expert (Christoph was the guy there) - and I haven't
spent much time in the image file handling code. Still, I'll risk adding
a few POV-Ray code related comments. :-)
- The jpeg output doesn't dither which may be part of the speed
difference relative to png.
- The jpeg library itself looks to support a no-compression jpeg output
by setting the quality to 0, but the current POV-Ray wrap maps <=1
values (the default compression value is -1) to 85%.
- I'd say 85% jpeg compression is sometimes suitable. :-) Just depends
on what one is doing with POV-Ray. Aside: IIRC 85% was chosen to line up
with the effective compression relative to some previous jpeg output,
not because it was considered the best quality choice.
- POV-Ray mostly uses standard external libraries when reading and
writing images so the compression de-compression isn't POV-Ray per sa.
The compression approaches are not all the same - with higher quality
and lossless compression tending to be the most expensive. Which you
probably knew...
Aside:
The jpeg library efforts are somewhat fractured. Most support no
compression option I believe, some lossless too, etc. There is though
one library better optimized for modern CPUs (turbo something?) and it's
not currently the library used by POV-Ray. I think google did much of
the work IIRC. A bit of a tangle in any case.
Somewhere (github?) I ran across a highly optimized for simd
architectures png library with benchmarks that looked great compared to
the common png library. But, during my glance, it wasn't clear how much
real world use of it there was.
Anyway... I guess, it's somewhat meaningless practically, but there are
image libraries out there which - perhaps - could enable better image
input/output performance in POV-Ray.
Bill P.
Date: 12 Jul 2020 08:20:01
Message: <web.5f0aff9b1af26a06ecc0fada0@news.povray.org>
> probably knew...
> Aside:
> Bill P.
Thanks for the detailed description.
As the number of available cores/threads, it is vital to reduce this
single-thread process when creating many scenes (e.g., for animation). I am
experimenting with different cases to better understand possible outlets.
Compression is not the key factor. In the case of tga, it is only 40% faster to
use the uncompressed output as compared with the compressed one.
ppm and exr both are faster than png but not close to JPEG.
I reckon a key factor (if not the main) is the absence of alpha channel in JPEG.
Quality 0 will lead to the default 85%. Non-compression is the quality of 100%.
Technically, it is not compressed by the JPEG standard, but it is still
compressed because of the JPEG architecture algorithm (leading to the
possibility of artefacts).
I am trying to find out the chance of artefacts when using JPEG. If it is
negligible, then I believe JPEG 100% is a better choice than PNG when
transparency is not required.
Date: 12 Jul 2020 08:45:08
Message: <web.5f0b05511af26a06fb0b41570@news.povray.org>
I really haven't looked into graphics file formats in a long time, so I'll just
ask this and see what happens.  ;)
What about BMP or GIF?
I also never see anyone use RAW file formats - except for professional
photographers, and it seems a bit --- complex.
Date: 12 Jul 2020 10:35:01
Message: <web.5f0b1f451af26a06ecc0fada0@news.povray.org>
RAW is technically useless (at least not beneficial). In a digital camera, RAW
formats store the exact information received by the sensor. Then, the image is
simulated from the lights sensed by the sensor.
POV-Ray simulates the color of each pixel by ray tracing. For this reason,
POV-Ray has dropped supporting RAW.
BMP like PPM and TGA is a binary map of pixels (bitmap). PNG has the same
information (almost) but with better size management and zip-compression (not
affecting the information stored).
The best format (in terms of size and accuracy) is PNG.
Of course, POV-Ray is not slow in producing PNG. As I tested, converting an
uncompressed format to PNG takes the same time. As Bill correctly mentioned,
POV-Ray uses other libraries for producing each image format.
