POV-Ray : Newsgroups : povray.general : How can we get smooth lighting on a reflective surface? Server Time
28 Oct 2024 14:17:50 EDT (-0400)
  How can we get smooth lighting on a reflective surface? (Message 1 to 7 of 7)
Subject: How can we get smooth lighting on a reflective surface?
Date: 28 Jun 2020 21:10:01
Message: <web.5ef93efc3cc7b3c8ecc0fada0@news.povray.org>
When a surface has a high reflection value, distinguishable circles of lighting
appear on the surface (see the linked image)
https://ibb.co/9s3xW7H
for
camera {location <0,0,-3> look_at <0,0,0> angle 45  }
light_source {<0,1,-3>  color rgb<1,1,1>  }
plane{<0,0,1>,0 pigment{ color rgb<0.2,0.2,0.2>} finish{reflection 1 } }
How can we fix this to have smooth and uniform lighting on the surface?
Subject: Re: How can we get smooth lighting on a reflective surface?
Date: 29 Jun 2020 06:26:10
Message: <5ef9c1c2$1@news.povray.org>
> for
Hi, Take a look at output file dithering in the documentation. Color
banding happens due there not being enough color channel depth in most
any output file format - exr being the exception - for close color
gradients. And given display / code limitations, you'll sometimes see
banding with exr viewers too.
The ini settings are Dither=on/off, Dither_Method=??? or you can use the
flag +th??. Just +th, I believe, defaults to the new blue noise in v3.8
over an older less robust method. Christoph did a lot of work on output
dithering for v3.8!
Aside: Dithering is on in the display window which makes POV-Ray itself
a pretty good image file viewer... I posted some sample as-image-viewer
code at the bottom of my pgm depth map patch announcement last year
(asPGMViewer.pov):
http://news.povray.org/povray.unofficial.patches/thread/%3C5cdd97f8%241%40news.povray.org%3E/
which is pretty easily adapted to other image formats. Change the
image_map gammas to sRGB. The gamma 1 was due the depth map usage. Ah, I
see too I left in a background statement - harmless, but it shouldn't be
there.
Bill P.
Date: 29 Jun 2020 06:45:01
Message: <web.5ef9c51ec20b2d284d00143e0@news.povray.org>
hi,
> appear on the surface (see the linked image) ...
> for
running the above with "+q9 +am2 +a0.1 +ag1 -j"  :-), the surface lighting does
look already fairly uniform.  you could add "roughness .01" to the 'finish{}'.
(looks ok here, the '.01' may need tweaking depending on actual surface, etc)
regards, jr.
Date: 29 Jun 2020 11:20:00
Message: <web.5efa068ec20b2d28ecc0fada0@news.povray.org>
> dithering for v3.8!
> (asPGMViewer.pov):
> there.
> Bill P.
Thanks Bill, +TH did the trick. It is nearly perfect. I learnt a lot.
I use the pre-compiled 3.7 on Linux. You motivated me to install 3.8 :-)
Date: 30 Jun 2020 03:19:25
Message: <5efae77d$1@news.povray.org>
Actually, setting the output to 16 bit per color component PNG would be
sufficient and has been available since POV-Ray 3.0.
Thorsten
Date: 30 Jun 2020 10:35:03
Message: <5efb4d97$1@news.povray.org>
It's good to point out the 16 bit per channel png output - and the hdr
output is in that depth class too. The obvious cost to the higher bit
depths over dithering is storage. Certainly there are occasions where
using 16 bit depth output is exactly what's needed.
Aside: I think we too often toss out 16 bits as enough depth for any
POV-Ray related application. In my experience 16 bits is only sometimes
enough channel depth.
It depends on what you are doing with the image after output or with one
as input. Also on what sort on image it is and what dynamic range it
represents.
When I was playing with lidar elevation files some years ago I needed 19
bits to not see banding/posterization in the local isosurface window. I
wrote some custom image/function code to implement that depth.
Recently I was playing with 3 image outputs(1) of parametrics both as a
possible alternative approach to Jerome's new UVMeshable approach and as
a possible alternative representation. Even the floats of the exr format
are not enough for the parametric -> 3ximages -> isosurface without
banding (shadow artifacts) in the isosurface. The 23 bits worth of steps
is not enough for surfaces/surface-portions with curvature.
(1) - In povr I can create images representing the positive and negative
function values using two color channels.
If we want someday to represent user defined / function defined cameras
with point sets easily transformable with good performance we are going
to need a 64bit double depth format storage accessible to functions -
and so parsing - whether it be 'psuedo-image' based or something custom.
I've played a lot with df3 based isosurfaces and the 8 and 16 bit depths
are sometimes just not enough. The more blob-y the interpolations of
povr can sometimes hide the banding, but then less is re-presentable.
Anyway... I'll get off my 16 bits isn't always enough soapbox, as folks
say. :-)
Bill P.
Date: 30 Jun 2020 12:49:17
Message: <5efb6d0d$1@news.povray.org>
> represents.
The 16 bit per channel don't have a greater range, it have a finer tone
resolution.
