POV-Ray : Newsgroups : povray.general : best practice question Server Time
10 Jan 2025 07:53:26 EST (-0500)
  best practice question (Message 1 to 6 of 6)
Subject: best practice question
Date: 9 Jun 2020 06:10:01
Message: <web.5edf5e77d148238c4d00143e0@news.povray.org>
hi,
I have a macro which expands to an array, eg
#macro mkArr(...)
array [2] {...}
which gets assigned, repeatedly, to the same '#declare'd variable.  is this ok
wrt memory management, or is it better to '#undef' the elements, and or the
array, before replacing it wholesale?  is there a difference?  do 'mixed' arrays
behave same as "normal" arrays?
regards, jr.
Subject: Re: best practice question
Date: 10 Jun 2020 13:24:35
Message: <5ee11753$1@news.povray.org>
Le 2020-06-09 à 06:07, jr a écrit :
> hi,
> #macro mkArr(...)
> array [2] {...}
> #end
> regards, jr.
Whenever you assign a new value to any variable, the new value simply
replace the old one in the same memory space.
The only issue that may arise for memory management, is when you assign
a string that don't always have the same length.
So, you don't need to #undef.
I don't know for mixed arrays.
You may need to #undef if you want to assign a new value of a different
type like float to vector or string.
Date: 11 Jun 2020 03:55:00
Message: <web.5ee1e222701429d44d00143e0@news.povray.org>
hi,
> > #macro mkArr(...)
> > array [2] {...}
> > #end
no strings in this project.  still not quite clear what happens when "...simply
replace the old one in the same memory space".  does POV-Ray do "garbage
collection" at this point, or is the previous value orphaned?
(I ask because the example is a simplification.  the array returned is dynamic
and may contain hundreds of results/elements.  my main "problem" is that the
documentation does not give me any clues.)
currently I simply "#declare Arr = array {};", ie overwrite (?) the previous
content, hence want/need to know what happens to the old values.
regards, jr.
Date: 12 Jun 2020 14:34:04
Message: <5ee3ca9c$1@news.povray.org>
On 6/11/20 3:49 AM, jr wrote:
> hi,
>>> #macro mkArr(...)
>>> array [2] {...}
>>> #end
I'm not familiar with the new-ish array / dictionary functionality or
code, but I think POV-Ray will let you know if an undef is required. You
cannot redefine functions for example, without first an undef(2).
It should be the previous memory gets freed(1) on the new declare if
POV-Ray allows it. Perhaps proceed as if all OK, and worry about undefs
if you see memory growth? In such a case, I'd consider the lack of a
parser error message (or not freeing memory automatically) a bug.
(1) - IIRC memory use is higher with the newer features. Both because
mixed array elements are all of a size which accommodates the largest.
And on growth the increments are in some sort of multiple of the
existing size. Again, not familiar with the code and I have not myself
used it. All Christoph's work.
(2) - Undefs are are not going to help with memory fragmentation over
time in any case supposing you are allocating and freeing a large number
of varying arrays.
Aside: Anyone else find the #declare, #undef (un-define) pairing
inconsistent. ;-)
Bill P.
Date: 12 Jun 2020 16:15:00
Message: <web.5ee3e14a701429d44d00143e0@news.povray.org>
> POV-Ray allows it.
agree.
is what I'm doing now, fingers crossed, "flying by the seat of the pants".  :-(
both mixed arrays and dynamic arrays are used, together.
(will 'clipka' be able to chip in, at some point?  (I must have missed what
happened))
> of varying arrays.
had not considered fragmentation.  how does it work, POV-Ray allocates all in
advance and doles out, or allocates on demand?  with relatively large arrays
being created/overwriting an existing, is there a rule of thumb for estimating
memory consumption[*]?
[*] another thing missing completely in the documentation.
(will 'povr' provide at least some introspection tools?)
> inconsistent. ;-)
I don't think it too bad since it covers '#declare'd and '#local's, but I really
think it should allow multiple identifiers, ie
  #undef A1, A2, ...
(with or without commas)
regards, jr.
Date: 13 Jun 2020 08:44:47
Message: <5ee4ca3f$1@news.povray.org>
> happened))
Don't know. Time will tell. Communication stopped over a year ago as you
know.
>> of varying arrays.
I thought fragmentation was probably your first concern when you
mentioned garbage collection :-). Garbage collection in terms of 'stop
and do it sometimes' isn't really a POV-Ray SDL / c++ thing.
The code allocates and frees as needed. Memory management is left to
libc's malloc et al. Perhaps possible to do better here - jemalloc? Way,
way down on my to-play-with list though.
Some rules of thumb for memory consumption have been described in the
newsgroups over time - Christoph's efforts mostly - but nothing in the
documentation. Such documentation is not easy to keep current. Updates
in povr have already changed things in quite a few places.
Aside: On some level I wonder why undef exists... A long time ago when
memory was precious I can see reason's to make it available to users so
things in include files, for example, could be freed early - while
parsing rather than at post parsing. Today, I'm playing with the idea of
dumping the keyword. It would push us a smidgen more in the functional
language direction - which for a scene description language I think a
good thing. With respect to dynamically executing functions via pointers
within inbuilt functions, not having the keyword would make things
simpler.
Nothing planned short term. A wild idea on which I spent a little time
late last year and early this, is replacing much of the internal povr
backbone code with Redis. It would enable considerable introspection -
while enabling better shape/functional code flow for performance. But
yeah, someday, maybe.
Remembering now, shortly into my first real job, being pulled aside by
an older co-worker after a meeting. A meeting in which I'd been asked
how long it would take me to do a task. I'd blurted out two hours. He
said, "You don't believe it now, but whenever answering how long will it
take questions with respect to technical issues, always bump your first
thought up to the next work-time increment and multiply by two. Two
hours -> day * 2 -> two days. Not sure how he came up with this formula,
but pushing 40 years later it's been remarkably accurate. This rule of
thumb in mind - it doesn't bode well for the Redis idea... :-)
Bill P.
