I wonder what shapes/objects can be used and manipulated to form a paintbrush on
the canvas, something like
https://cdn.imgbin.com/18/11/4/imgbin-oil-paint-paintbrush-watercolor-painting-paint-purple-paint-sticker-GPeinj6dEyvmi
In the same context, how do you create a spatial object like
https://encrypted-tbn0.gstatic.com/images?q=tbn%3AANd9GcTtlV3vfVdQRULRJrpWyoqVjDFi9Y2faXwYksCJ57Pr1i_qaVE4
The reason I mentioned the latter is its similarity with julia_fractal. Perhaps,
the way julia_fractal is created in POV-Ray can be employed to build the above
images.
> images.
For the first, some creative use of normal could do the trick.
For the second, it can probably be achieved using an isosurface where
you also manipulate the coordinates passed to the function : Having the
X and Z coordinates affected by the sin and cos of the Y coordinate will
cause the shape to twist in a similar way.
Try :
Func(x*sin(y), y, z+cos(y))
to see how it works.
Replace «Func» with some function of your won devising.
mi
When I was looking to do a quick & dirty "painted" effect, I used a bump normal
and just scaled it really big in one direction to stretch it.
I suppose you could actually make a bumpy object and create a loop to make a
sort of sphere sweep, and even vary the bumpiness to give the flexible bristle
effect.
Then just bury it under the surface so some sticks out, or difference away the
irrelevant part.
> images.
Play around here:
http://www.econym.demon.co.uk/isotut/splines.htm
and see what you like.
