POV-Ray : Newsgroups : povray.general : How to check if two objects have any intersection? Server Time
28 Oct 2024 16:23:13 EDT (-0400)
  How to check if two objects have any intersection? (Message 1 to 4 of 4)
Subject: How to check if two objects have any intersection?
Date: 30 Jan 2020 16:10:00
Message: <web.5e33452eb572e6a0ecc0fada0@news.povray.org>
I need an if statement to check if two objects have any intersection. I assumed
trace(a, b) should give false when there is no intersection, something like
 #if ( trace(a,b) )
 #else
but apparently, trace return a vector, when if statement needs a numeric
expression.
How can I check if two objects have any overlap in an if statement?
Subject: Re: How to check if two objects have any intersection?
Date: 30 Jan 2020 16:55:00
Message: <web.5e33502f78dd1088451952ca0@news.povray.org>
hi,
>  #if ( trace(a,b) )
>  #else
>  #end
> expression.
I guess you'd need to write a macro which takes the two objects and returns a
bool, true if the bounding boxes overlap (or whichever method you use to
determine "intersection").
regards, jr.
Date: 30 Jan 2020 17:40:00
Message: <web.5e335a3d78dd10884eec112d0@news.povray.org>
> expression.
Well, since trace {} returns <0, 0, 0> as the surface normal if it misses the
object, then you can just add together the x, y, and z components of the vector
to give a scalar value.  Use abs() so nothing cancels out.
#declare TraceBool = abs(Normal.x)+abs(Normal.y)+abs(Normal.z);
http://news.povray.org/povray.binaries.tutorials/thread/%3Cweb.51f61e827603294573fc9ebb0%40news.povray.org%3E/
Gonna be tricky with CSG to look at the right place and get an accurate result.
If they are curves / algebraic surfaces, then I might see about doing the math
to see if there are any intersection points.
Just curious - what if you did:
intersection {
     ObjectA
     ObjectB
and computed the volume of the bounding box?
At the very least, if you're "scanning" with trace{}, then it would give you a
much smaller, and accurate volume to focus on.
Date: 31 Jan 2020 12:01:23
Message: <5e345d63$1@news.povray.org>
>> expression.
> intersection {
>       ObjectA
>       ObjectB
You can test for the length of the normal vector.
If the trace encounter a surface, the length is 1. If it miss, the
length is zero.
So, it become :
#declare TraceBool = vlength(Normal);
