POV-Ray : Newsgroups : povray.general : text with background Server Time
10 Jan 2025 15:18:20 EST (-0500)
  text with background (Message 1 to 4 of 4)
Subject: text with background
Date: 4 Aug 2019 15:05:00
Message: <web.5d472b3237fd6e25ecc0fada0@news.povray.org>
I know I can put a text object on a geometrical shape by techniques such as
"difference", but in this case, I need to know the width of the text to create
an object with the same size?
How can I set a background for a text object when I don't know the width/length
of the text?
Subject: Re: text with background
Date: 5 Aug 2019 07:09:04
Message: <5d480e50$1@news.povray.org>
> of the text?
Hi. There are min_extent(), max_extent() object bounding box commands.
For what you are doing though, the object pattern using your text as the
object is perhaps easier. See the shipped sample scene
<install dir>/scene/advanced/object_pattern.pov
or the more interesting abyss.pov where the PERSISTENCE text is written
on the submarine (not perfectly aligned) using the object pattern.
You can find the most current sample scenes online at:
https://github.com/POV-Ray/povray/distribution.
Bill P.
Date: 5 Aug 2019 12:33:30
Message: <5d485a5a$1@news.povray.org>
> of the text?
I By using min_extent(), max_extent(), you'll get the extent of your
text object.
In fact, you only need to use max_extent(TextObject).x in the present
context as text objects start at x=0 and build top the right, or +x
direction.
(max_extent(TextObject).y - min_extent(TextObject).y) will return the
height. Using min_extent is needed to take into account the descender of
some letters :«y», «q», «j» and «g».
Date: 5 Aug 2019 13:45:06
Message: <web.5d486a40a6d63a3a4eec112d0@news.povray.org>
Just throwing this reference ink in in case some of these directives may help
with anything else you're doing.
http://wiki.povray.org/content/Reference:Strings
It's often helpful to make a second object {} or transparent box or a wire box
(shapes2.inc) as a marker or placeholder when you're doing differences, since
all of the things you're differencing from the parent object don't show up....
Just in case that saves you some headaches...
