POV-Ray : Newsgroups : povray.general : clone/duplicate of a union Server Time
14 May 2025 01:32:44 EDT (-0400)
  clone/duplicate of a union (Message 1 to 7 of 7)
Subject: clone/duplicate of a union
Date: 25 May 2018 08:20:01
Message: <web.5b07fe921258309a3ce674f0@news.povray.org>
It is probably a ridiculous question, but imagine we have created a union as
#declare obj_u1 =
    union {
        obj1
        obj2
how can we create clones of obj_u1 and apply different transformations?
For example, how can we transform three independent copies of obj_u1 as
translate obj_u1
scale obj_u1
rotate obj_u1
Subject: Re: clone/duplicate of a union
Date: 25 May 2018 09:49:24
Message: <5b081464$1@news.povray.org>
> #declare obj_u1 =
>      union {
>          obj1
>          obj2
> translate obj_u1
> scale obj_u1
> rotate obj_u1
Once you have declared it. Call it by using:
object{ obj_u1
	rotate <a,b,c>
	scale <l,m,n>
	translate <x,y,z>
Repeat as many times as you want with different transformations and
textures.
Regards
Date: 25 May 2018 12:50:01
Message: <web.5b083e9ba6a9132710874a080@news.povray.org>
POV-Ray has a somewhat steep learning curve, so these things aren't really
ridiculous.
> #declare obj_u1 =
>     union {
>         obj1
>         obj2
> translate obj_u1
> scale obj_u1
> rotate obj_u1
What you want to do is use the
object {} "directive" or whatever this type of SDL command is properly called.
So, assuming you've declared values for x1, y1, and z1, you could use the
following structures:
object {obj_u1 translate <x1, y1, z1>}
object {obj_u1 translate x*10}
object {obj_u1 scale <x1, y1, z1>}
object {obj_u1 scale 3}
object {obj_u1 rotate <x1, y1, z1>}
object {obj_u1 rotate y*degrees}
Date: 25 May 2018 15:30:43
Message: <5b086463$1@news.povray.org>
> ridiculous.
And there are no stupid questions only stupid answers.
Regards
Date: 25 May 2018 16:12:07
Message: <5b086e17$1@news.povray.org>
>> really
>> ridiculous.
well i'm glad to see that i'm not the only cranky old man here...sounds
Date: 25 May 2018 16:16:18
Message: <5b086f12@news.povray.org>
> #declare obj_u1 =
>      union {
>          obj1
>          obj2
> translate obj_u1
> scale obj_u1
> rotate obj_u1
Very simple.
You can simply place the object multiple times into your scene :
object{obj_u1 translate SomeTranslation}
object{obj_u1 scale SomeScalling}
object{obj_u1 rotate SomeRotation}
Or, you can make transformed copies :
#declare obj_t1 = object{obj_u1 translate SomeTranslation}
#declare obj_t2 = object{obj_u1 scale SomeScalling}
#declare obj_t3 = object{obj_u1 rotate SomeRotation}
Date: 25 May 2018 16:41:42
Message: <5b087506$1@news.povray.org>
>>> really
>>> ridiculous.
And where is Shelly when you need her. ;-)
Regards
