POV-Ray : Newsgroups : povray.general : Cubic syntax pb Server Time
12 Aug 2025 10:55:39 EDT (-0400)
  Cubic syntax pb (Message 1 to 8 of 8)
Subject: Cubic syntax pb
Date: 16 May 2018 19:15:01
Message: <web.5afcbab9b0bae1867a63dc9f0@news.povray.org>
If I understand the documentation, the following code for the texture shoulde be
OK, as it is a identifier + a pigment. However I have the following error
message :Parse Error: No matching } in 'texture',
 pigment found instead
Any idea of the pb ?
Thanks,
#declare cubicOak = texture {cubic texture{pigment {image_map {png "chene.png"
}} rotate -90*y } ,texture{pigment {image_map {png "chene.png"  }} rotate -90*x
} ,texture{pigment {image_map {png "chene.png"  }}  } ,texture{pigment
{image_map {png "chene.png"  }} rotate -90*y } ,texture{pigment {image_map {png
"chene.png"  }} rotate -90*x } ,texture{pigment {image_map {png "chene.png"  }}
light_source {<-3.0,-4.0,10.0>color rgb <0.3864,0.3864,0.3864> spotlight }
//Unnamed Object
box {
<0.0,0.0,0.0>,<1.0,1.0,1.0> matrix <0.3 , 0.0 , 0.0 , 0.0 , 0.4 , 0.0 , 0.0 ,
0.0 , 0.5 , 0.0 , 0.0 , 0.0>texture {cubicOak pigment {White  }}}
Subject: Re: Cubic syntax pb
Date: 16 May 2018 20:59:42
Message: <5afcd3fe$1@news.povray.org>
On 05/16/2018 07:11 PM, lelama wrote:
> Hi,
> Thanks,
one more closing brace after the comma
> //Unnamed Object
> box {
Date: 16 May 2018 21:00:54
Message: <5afcd446$1@news.povray.org>
>> Hi,
>> shoulde be
>> Thanks,
>> "chene.png"
>> rotate -90*x
>> {image_map {png
>> "chene.png"  }}
after the /last/ comma
>> spotlight }
>> //Unnamed Object
>> box {
>> , 0.0 ,
Date: 17 May 2018 04:00:01
Message: <web.5afd358e884f5cc97a63dc9f0@news.povray.org>
Thank you Jim for the answer. However, the parenthesis seem correct to me.
Here is the same example in a simpler form to avoid checking parenthesis.
The problem seems specific to cubic since when I replace the first box by the
second the code works perfectly.
#declare pb = pigment {Blue}
#declare pw = pigment {White}
#declare cubicOak = texture {cubic texture{pb} ,texture{pb} ,texture{pb }
,texture{pb } ,texture{pb} ,texture{pb}   }
#declare myGlass = texture { Glass3 }
box {
<0.0,0.0,0.0>,<1.0,1.0,1.0> texture {cubicOak  pw }}
//box {
//<0.0,0.0,0.0>,<1.0,1.0,1.0> texture {myGlass  pw }}
Date: 17 May 2018 04:18:24
Message: <5afd3ad0$1@news.povray.org>
Am 17.05.2018 um 01:11 schrieb lelama:
> Hi,
> Thanks,
> //Unnamed Object
> box {
Wow, that's wild.
I highly recommend adding some more structure to your scene code, by
making use of indentation, for example like so:
      cubic
      texture{
          image_map { png "chene.png" }
        rotate -90*y
        rotate -90*x
        rotate -90*y
        rotate -90*x
Also, another word of wisdon: Avoid using the same image over and over
again, as it unnecessarily eats memory and parsing time. Instead, use
something like:
    #declare OakBase = pigment {
      cubic
      texture{
        pigment { OakBase }
        rotate -90*y
        pigment { OakBase }
        rotate -90*x
        pigment { OakBase }
        pigment { OakBase }
        rotate -90*y
        pigment { OakBase }
        rotate -90*x
        pigment { OakBase }
This way, the image gets loaded only once, and is shared between the
different textures that make use of it.
But your problem is of a different kind:
    box {
              0.0 , 0.4 , 0.0 ,
              0.0 , 0.0 , 0.5 ,
              0.0 , 0.0 , 0.0>
        cubicOak
        pigment { White }
According to the documentation, section 3.4.6 "Texture", the
`PLAIN_TEXTURE` syntax is as follows:
      [TEXTURE_IDENTIFIER]
      [PNF_IDENTIFIER...]
      [PNF_ITEMS...]
with `PNF_ITEMS` being either of:
    PIGMENT | NORMAL | FINISH | TRANSFORMATION
Thus, the construct
      TEXTURE_IDENTIFIER
      PIGMENT
should be valid according to these rules.
However, in `cubicOak` you're using a pattern, so the variable does
/not/ qualify as a regular `TEXTURE_IDENTIFIER`, but rather as a
`PATTERNED_TEXTURE_ID`, and thus the `PATTERNED_TEXTURE` syntax applies:
      [PATTERNED_TEXTURE_ID]
      [TRANSFORMATIONS...]
(or some other variants that don't fit here)
Note that this syntax only allows for transformations, not pigment (or
normal or finish) overrides.
Date: 17 May 2018 06:12:28
Message: <5afd558c$1@news.povray.org>
well for sure your example wouldn't parse as is ... when i added that
last closing brace it /did/ ... found it by (as suggested) structuring
things ;-)
Date: 17 May 2018 06:30:01
Message: <web.5afd592b884f5cc97a63dc9f0@news.povray.org>
>     texture {
Thank you, this is very clear !
Sorry for the indentation, this was output from python.
Date: 17 May 2018 06:32:02
Message: <5afd5a22$1@news.povray.org>
Am 17.05.2018 um 12:12 schrieb Jim Holsenback:
>> me.
> things ;-)
That's odd, because my structuring attempts ended up with well-balanced
braces.
I guess this only goes to show how important it is to structure things
-- ideally right from the beginning, because sometimes errors occur even
in the process of trying to structure stuff later.
