POV-Ray : Newsgroups : povray.general : ImageWidth not declared? Server Time
31 Oct 2024 10:20:24 EDT (-0400)
  ImageWidth not declared? (Message 1 to 10 of 14)
Subject: ImageWidth not declared?
Date: 15 Jan 2018 11:15:01
Message: <web.5a5cd31e3ef6c1e2e82f82270@news.povray.org>
So it's been a few years since I last used Povray, and I started on a scene
today...only for my first command to throw an error.  Here's the source:
 location <3, 1, 3>
 look_at 0
 right x*ImageWidth/ImageHeight
 up y
Here's the error:
Persistence of Vision(tm) Ray Tracer Version 3.7.0.unofficial (g++ 5.2.1 @
 i686-pc-linux-gnu)
File 'what.pov' line 4: Parse Error: Expected 'numeric expression', undeclared
 identifier 'ImageWidth' found instead
Fatal error in parser: Cannot parse input.
Render failed
I verified the format by comparing it to the official documentation.  Checking
further, I found that ImageHeight throws the same error.  As I said, it's been a
few years.  Has somebody decided that ImageWidth and ImageHeight no longer need
to exist?  Or have I forgotten something?
Subject: Re: ImageWidth not declared?
Date: 15 Jan 2018 11:27:45
Message: <5a5cd681$1@news.povray.org>
> camera {
>   location <3, 1, 3>
>   look_at 0
>   up y
> Here's the error:
>   i686-pc-linux-gnu)
> Render failed
Try:
All built in POV-Ray keywords are lower case. I find myself using the
online keywords index all the time. You can find it at:
http://wiki.povray.org/content/Reference:Keywords
Bill P.
Date: 15 Jan 2018 11:30:03
Message: <web.5a5cd63cac415efc5cafe28e0@news.povray.org>
You forgot that capitalization means something.
The correct reserved internal variable names are:
image_width
image_height
You CAN do something like
#declare ImageHeight = image_height;
#declare ImageWidth = image_width;
and then go from there.
Date: 15 Jan 2018 12:35:00
Message: <web.5a5ce615ac415efce82f82270@news.povray.org>
> image_width
> image_height
Yeah, that was it.  As an excuse, I mention this web page:
http://www.povray.org/documentation/view/3.6.2/153/
which uses ImageWidth and ImageHeight.  Perhaps it needs to be updated?
Date: 15 Jan 2018 12:56:32
Message: <5a5ceb50$1@news.povray.org>
Unsure the 3.6 docs will be touched at this point. The 3.7/3.8
equivalent page:
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_19
has been updated with the correct keywords. It also strongly discourages
use of the keywords to a degree with which I don't agree.
Bill P.
Date: 15 Jan 2018 18:35:00
Message: <web.5a5d3a82ac415efc5cafe28e0@news.povray.org>
I think it's been mentioned that the wiki is the best place to keep up with the
documentation.  I only use online help for posting links, for "real" help I use
the F1 Help, or the Insert Menu examples, or Friederich Lohmueller's site.
You might keep in mind that reserved internal variable names are highlighted in
that purple color - so if you reach the end of the variable name, and it doesn't
turn purple...   Sometimes I can't remember if there's an underscore for certain
ones....
Date: 16 Jan 2018 02:57:54
Message: <5a5db082$1@news.povray.org>
Am 15.01.2018 um 18:34 schrieb Robert Kennedy:
The code snippet in that section is a "general way to set the correct
aspect ratio piece of documentation", indicating that (or at least being
consistent with the interpretation that) "ImageWidth" and "ImageHeight"
are intended to be placeholders for the values you used for the INI
settings of the same names.
Date: 16 Jan 2018 03:24:05
Message: <5a5db6a5$1@news.povray.org>
Am 15.01.2018 um 18:56 schrieb William F Pokorny:
> equivalent page:
You're not the only one.
That's why POV-Ray 3.8.0-alpha will even use `right
x*image_width/image_height` as the default (provided you specify
`#version 3.8` at the very start of the file).
The reasons stated do have their merit, but I think they warrant no more
than to just advise some caution.
It should also be noted that scene authors worried about the issues can
use a construct like the following to enforce the intended aspect ratio:
    #if (image_width/image_height != 4/3)
      #error "Scene is designed for 4:3 aspect ratio!\n"
Users who may need to render to a non-square pixel format should indeed
opt for a fixed aspect ratio, and use a variation of the above test to
warn rather than abort:
      right x*4/3
      #warning "Scene is designed for 4:3 aspect ratio!\n"
      #warning "Rendering for non-square pixels.\n"
Date: 17 Jan 2018 14:40:00
Message: <web.5a5fa64fac415efcfd3cadc90@news.povray.org>
> > image_width
> > image_height
It is meant to explain that you should insert the image height and width - 3.6
had no image width and height keywords.
Date: 18 Jan 2018 01:22:26
Message: <5a603d22@news.povray.org>
Unfortunately, Google prefers the POV 3.6 docs to the wiki.
Mike
