POV-Ray : Newsgroups : povray.general : Light Source Issue Server Time
12 Aug 2025 13:59:01 EDT (-0400)
  Light Source Issue (Message 1 to 10 of 10)
Subject: Light Source Issue
Date: 10 Jan 2018 05:50:00
Message: <web.5a55efc397aeb4fe278d3b70@news.povray.org>
Good morning to all,
I'm focusing on a quite strange issue.
I have simply defined this light source:
    light_source {
                 <0,500,-1000>
                 color rgb <255, 255, 255>
                 fade_distance 1
                 fade_power 0
                 media_interaction off
                 media_attenuation off
and this object:
cylinder {
              <0, 0, 1000>,
              <0, 1000, 1000>,
              (100)
              pigment {rgb <0, 0, 0>}
              finish {
                     ambient 0
                     diffuse 1
                     specular 1
                     emission 0
                     roughness 0.005
                     reflection {
                                0.5
                                metallic
then, gradually I'm moving the light source until z=-100000, leaving the camera
fixed:
          perspective
        location <0,500,0>
        look_at <0,500,1000>
        rotate <0, 0, 0>
        up <0,2,0>
        right <2,0,0>
The strange issue is relative to the behaviour of the light reflected by the
cylinder. It seems to increase when I increase the distance between object and
light source. Why? There is any light attenuation defined.
Anyone have an idea about that?
Thank you
Best regards
Subject: Re: Light Source Issue
Date: 10 Jan 2018 08:15:01
Message: <web.5a561141ee00f7ec659f6d40@news.povray.org>
>     light_source {
>                  <0,500,-1000>
>                  fade_distance 1
>                  fade_power 0
> and this object:
> cylinder {
>               <0, 0, 1000>,
>               <0, 1000, 1000>,
>               (100)
>               finish {
>                      ambient 0
>                      diffuse 1
>                      specular 1
>                      emission 0
>                      roughness 0.005
>                      reflection {
>                                 0.5
>                                 metallic
> fixed:
> camera {
>           perspective
>         location <0,500,0>
>         rotate <0, 0, 0>
>         up <0,2,0>
>         right <2,0,0>
> Thank you
> Best regard
Try a parallel light and the effect vanish. If I use a spotlight, the visible
radius increase with the distance to the object. Same for the point
light_source.
Date: 10 Jan 2018 08:45:01
Message: <web.5a561862ee00f7ece278d3b70@news.povray.org>
> >     light_source {
> >                  <0,500,-1000>
> >                  fade_distance 1
> >                  fade_power 0
> > and this object:
> > cylinder {
> >               <0, 0, 1000>,
> >               <0, 1000, 1000>,
> >               (100)
> >               finish {
> >                      ambient 0
> >                      diffuse 1
> >                      specular 1
> >                      emission 0
> >                      roughness 0.005
> >                      reflection {
> >                                 0.5
> >                                 metallic
> > fixed:
> > camera {
> >           perspective
> >         location <0,500,0>
> >         rotate <0, 0, 0>
> >         up <0,2,0>
> >         right <2,0,0>
> > Thank you
> > Best regard
> light_source.
I don't know...
I've just tried it but it is still different.
Date: 10 Jan 2018 10:25:47
Message: <5a56307b$1@news.povray.org>
Am 10.01.2018 um 11:49 schrieb Motive17:
>     light_source {
>                  <0,500,-1000>
>                  fade_distance 1
>                  fade_power 0
If you move the light source in the z direction only, then as you
increase the distance, the direction of the light source is getting
closer and closer to -z, so the light source gets closer and closer to
being perpendicular to the cylinder's axis.
Thus the lit portion of the cylinder is illuminated more vertically
(with respect to the cylinder surface, not the "world").
The diffuse component of a surface becomes brighter as the surface is
illuminated more vertically.
If it was just a matter of direction, this would be perfectly realistic.
In real life, the illumination from a light source also gets dimmer as
the distance increases. To simulate this properly, you should use
`fade_power 2`.
Date: 10 Jan 2018 16:29:40
Message: <5a5685c4@news.povray.org>
>      light_source {
>                   <0,500,-1000>
>                   fade_distance 1
>                   fade_power 0 //??????
> Thank you
> Best regards
You use fade_power 0. That mean that the light don't fade at all. It
similar to the case where you have a large light source relative to the
distance. By large, I mean about 100 to 1 ratio between the length of a
side of the light relative to the distance.
If you use fade_power 1, you get light fading as a direct factor of the
distance : Double the distance = half of the illumination. Works in a 2D
world. Also a good approximation of a linear light source, where the
length of the light is at least 100 times the distance to the
illuminated object.
If you use fade_power 2, you get real world fading. At twice the
distance, the illumination drop by a factor of 4.
Always use fade_power 2 to get realistic light fading.
Date: 11 Jan 2018 06:10:01
Message: <web.5a57457bee00f7ece278d3b70@news.povray.org>
> >      light_source {
> >                   <0,500,-1000>
> >                   fade_distance 1
> > Thank you
> > Best regards
> illuminated object.
Thank you for the reply, Alain.
Yes, I used fade power=0 because I did not want a realistic light fading, I just
wanted no attenuation of light.
Date: 12 Jan 2018 06:05:00
Message: <web.5a58961eee00f7ece278d3b70@news.povray.org>
> >     light_source {
> >                  <0,500,-1000>
> >                  fade_distance 1
> >                  fade_power 0
> `fade_power 2`.
Thank you for the reply.
I think you convinced me...
Date: 12 Jan 2018 12:35:01
Message: <web.5a58f120ee00f7eca47873e10@news.povray.org>
> world.
Thanks; that clarifies my own misconception of fade_power 1.0. For some reason,
I always assumed that it meant NO fading of the light-- like a typical power law
of, say,
   pow(7,1.0) = 7
Of course, using fade_power 1.0 in a scene DOES fade the light; I just never
knew what that fading value represented. I think the documentation's chart
example threw me off-- it shows a 'curve' for fade_power 1.0, where I was
naively expecting a straight line (at some downward angle, of course.) The
chart's X and Y axes are indeed linear-- but the X-axis represents a more
'compressed' set of values than the Y-axis... a detail that I never paid much
attention to! So the 'curve' is correct. (Personally, I would have preferred a
chart with equal values on the X and Y axes-- to show the fading behavior more
clearly.)
The one detail that's not *specifically* included in the chart is the chosen
fade_distance-- although the documentation seems to indicate that it's also 1.0.
Adding that to the chart itself would remove any ambiguity, IMO.
Date: 12 Jan 2018 16:13:14
Message: <5a5924ea@news.povray.org>
>> world.
> of, say,
>     pow(7,1.0) = 7
For fade_power 1,
it's fade_distance/pow(Distance, 1) = fade_distance/Distance
For fade_power 0,
it becomes fade_distance/pow(Distance,0) = fade_distance/1
> clearly.)
Usually, for an area_light, you want to use fade_distance = size od the
area_light.
Otherwise, you can use fade_distance 1 for large scenes or far lights,
and 0.1 or less for lights that are very close to the closest surface.
Date: 12 Jan 2018 16:29:48
Message: <5a5928cc$1@news.povray.org>
> area_light.
Thanks, I did not know that.
Regards
