POV-Ray : Newsgroups : povray.general : Spline vector function Server Time
17 May 2025 03:52:21 EDT (-0400)
  Spline vector function (Message 1 to 10 of 10)
Subject: Spline vector function
Date: 19 Nov 2016 13:40:00
Message: <web.58309bfd590a407fa7cafab50@news.povray.org>
I am experimenting with this:
#version 3.7 ;
  global_settings {assumed_gamma 1.0 }
    camera {location <-10,40,-40> angle 4 look_at <0,0,0> }
    light_source {<-5,20,-20> colour rgb<1,1,1>}
  background { color rgb<0.2, 0.4, 0.8>  }
#declare Place = function {
  spline {
    linear_spline
//    -4, <-10,0,-2>
    -2, <0,0,-1>
    0, <1,0,0>
    2.0, <0,1,1>
 sphere {Place(-1),.1 pigment {color rgb < 1, 0, 0>}}
 sphere {Place(-.5),.1pigment {color rgb < 1, 1, 0>} }
 sphere {Place(-0),.1 pigment {color rgb < 0, 1, 0>}}
 sphere {Place(+.5),.1 pigment {color rgb < 1, 0, 1>}}
 sphere {Place(+1),.1 pigment {color rgb < 0, 0, 1>}}
This seems to work but if I add another point by deleting the // I get an error
which does not make sense (to me).
Should it be possible to do arbitarily long bezier splines?
Subject: Re: Spline vector function
Date: 19 Nov 2016 14:36:53
Message: <5830a9d5$1@news.povray.org>
> #version 3.7 ;
>   spline {
>     linear_spline
> //    -4, <-10,0,-2>
>     -2, <0,0,-1>
>     0, <1,0,0>
>     2.0, <0,1,1>
Hi John,
Yes, you should be able to have arbitrarily long splines. I've certainly
had much longer.
To me this looks like a parse bug going back to at least 3.6.1 where a
negative index value in other than the first entry fails.
A scene file with just this works:
#declare MySpline =
  spline {
  linear_spline
  -4, <-10,0,-2>
  0, <0,0,-1>
  1, <1,0,0>
  2.0, <0,1,1>
but this doesn't:
#declare MySpline =
  spline {
  linear_spline
  -4, <-10,0,-2>
  -0, <0,0,-1>
  1, <1,0,0>
  2.0, <0,1,1>
That said, I'll let this sit a bit in case those around longer know
something I do not and want to chime in.
Otherwise, I'll open up an issue for it in a day or two.
Bill P.
Date: 19 Nov 2016 14:55:34
Message: <5830ae36$1@news.povray.org>
Am 19.11.2016 um 19:37 schrieb John Greenwood:
>   spline {
>     linear_spline
> //    -4, <-10,0,-2>
>     -2, <0,0,-1>
>     0, <1,0,0>
>     2.0, <0,1,1>
It's not a bug, it's a feature.
Re-formatting gives the following code:
    spline {
    linear_spline
      -4, <-10,0,-2>-2,
      <0,0,-1> 0,
      <1,0,0> 2.0,
      <0,1,1>
Since `<-10,0,-2>-2` is a valid vector expression, that's how POV-Ray
will interpret it.
Using more commas should fix the ambiguity of the code and thus solve
the problem.
Date: 19 Nov 2016 15:00:01
Message: <web.5830aefdf8564a279c5d6c810@news.povray.org>
Using a comma after each vector also works okay.
Date: 20 Nov 2016 05:00:00
Message: <web.5831737ff8564a27a7cafab50@news.povray.org>
Works for me too.
Thanks everyone for the help.
Date: 20 Nov 2016 07:46:26
Message: <58319b22$1@news.povray.org>
>     spline {
>     linear_spline
>       -4, <-10,0,-2>-2,
>       <0,0,-1> 0,
>       <1,0,0> 2.0,
>       <0,1,1>
> will interpret it.
> the problem.
Ah, yes... Thanks.
Bill P.
Date: 20 Nov 2016 10:35:01
Message: <web.5831c28cf8564a279c5d6c810@news.povray.org>
> > will interpret it.
> > the problem.
I see I replied less than 5 minutes after this was said, posting delay got me.
I just wanted to point something out. A comma after *every* vector is apparently
possible, I just hadn't actually said that before. I was surprised it didn't
cause a parse error.
Looking at the documentation, spline examples leave out the trailing commas but
the spline definition denotes them as optional (without final comma).
So to be sure other things don't allow a final comma, which is what I had
expected, I tried doing that with sor, lathe and sphere_sweep. Sure enough,
parse error. No doubt countless times I've dealt with this comma error thing in
the past.
I wonder if spline is the only thing allowing that last ,
And wondering if it makes more sense to allow that for everything listing
vectors or exclude the possibility. Of course I would have to lean toward
allowing it, thinking if sections of vector lists were generated externally and
added or subtracted somehow, else the error would occur.
Date: 20 Nov 2016 10:56:35
Message: <5831c7b3$1@news.povray.org>
Am 20.11.2016 um 16:34 schrieb omniverse:
> the past.
I'm a bit surprised about your findings, as it was my impression that
POV-Ray generally allowed a final comma.
Can you report your findings as an issue on
https://github.com/POV-Ray/povray/issues so we don't lose track of this?
Thanks.
Date: 20 Nov 2016 12:05:02
Message: <web.5831d773f8564a279c5d6c810@news.povray.org>
> > parse error.>
Done, whatever way I'm going about it there is probably another matter.  :)
https://github.com/POV-Ray/povray/issues/153
And now found prism and polygon complain with that final comma added.
Not so with polynomial. I'm not sure what else might be considered similar
enough to these objects or functions.
Date: 20 Nov 2016 17:30:07
Message: <583223ef@news.povray.org>
> #version 3.7 ;
>   spline {
>     linear_spline
> //    -4, <-10,0,-2>
>     -2, <0,0,-1>
>     0, <1,0,0>
>     2.0, <0,1,1>
You should add some comas in your points list. Your second component is
starting with -2. This cause the whole statement to be interpreted as:
-4, <-10,0,-2>-2, <0,0,-1>,...
whitch becomes:
-4, <-12, -2, -4>, <0,0,1>,...
Remember, spaces, tabs and new lines/cariage returns et NOT terminal
separators.
