POV-Ray : Newsgroups : povray.general : torus arrows Server Time
4 Mar 2026 01:05:02 EST (-0500)
  torus arrows (Message 1 to 10 of 18)
Subject: torus arrows
Date: 8 Nov 2016 21:50:00
Message: <web.58228e15512a2627116828db0@news.povray.org>
Dear  povray community,
I am totally new to Povray, but am very interested to learn how to draw
torus arrows, like the second figure on
 http://www.povray.org/documentation/view/3.6.1/15/
(Does anyone have the script for this figure?)
I found a script like this
union
//  cone {-2*z,0.0, -2*z+1*x,0.3 }
  cone {-2*y-2*x,0.0, -2,0.3 }
  difference {
    torus { 2,0.1 }
    box { <1,-1,0>,<-2,1,6> }
  pigment { Green  }
 no_shadow
 translate <4,4,0>
  // apply texture as needed
But the arrow does not go to the location that I want. Also I do not understand
cone(-2*z,0.0, -2*z+1*x,0.3).
Any help is greatly appreciated!
Best regards,
Guoping Zhang
Subject: Re: torus arrows
Date: 8 Nov 2016 23:25:00
Message: <web.5822a4c6329b68a89c5d6c810@news.povray.org>
Don't know if that script exists anywhere but you probably need a simple
explanation using a correct scene. Read and render this:
union
 // axis
 cylinder {-3*y,3*y,0.1 pigment{blue 1}}
 // put pointer at cut curve end <0,0,2>
  cone {x+(2*z),0.0, z*2,0.3 } //add pointed end with length x
  // and match base (0.3 wide) position with curve end
  difference {
    torus { 2,0.1 } // curves on y plane
     // cut with box from center outward past edge
     // with cuts of curve at <0,0,2> and <2,0,0>
    box { <0,-0.11,0>,<2.11,0.11,2.11> }
  pigment { green 1 }
  //finish {emission 1} // make visible glow without light
 no_shadow
 // no rotation shows left-handed y rotation
 // rotate <90,0,0> // shows left-handed z rotation
 // rotate <-90,-90,0> // shows left-handed x rotation
 // move away from origin to see with default camera
 translate <0,0,5>
light_source{<10,10,-10>,1}
camera{location <4,4,-2> look_at <0,0,5>}
Date: 9 Nov 2016 08:00:01
Message: <web.58231cd4329b68a8b488d9aa0@news.povray.org>
If you're new to povray,
1.  Welcome!   :)
and
2. if you want to do stuff like that,
http://www.f-lohmueller.de/pov_tut/pov__eng.htm
http://www.f-lohmueller.de/pov_tut/a_geo/a_geo__e.htm
and checking out the INSERT menu included with POV-Ray, which has a lot of
pre-written scene fragments.
The subdirectories of your POV-Ray installation will likely have a lot of sample
scenes and .pov, .ini, and .inc files.
Date: 9 Nov 2016 19:28:51
Message: <5823bf43$1@news.povray.org>
> union
>   difference {
>     torus { 2,0.1 }
>   pigment { Green  }
>  no_shadow
>  translate <4,4,0>
First, the object defined above:
It's a torus with a chunk removed by the box.
To it, is added a cone.
The center of the torus start at the origin and is later moved to the
location <4,4,0> or 4 unit to the right or +X and 4 units up or +Y.
There is no displacement along the Z axis, the zero value.
The "no_shadow" purpose is to suppress the casting of a shadow by the
object. It may not be usefull to you and can be removed.
> cone{-2*z,0.0, -2*z+1*x,0.3}.
> Best regards,
> Guoping Zhang
For "cone(-2*z,0.0, -2*z+1*x,0.3)", you are seeing an alternate notation
that take advantage of some shortcuts.
It evaluate as :
  cone{ <0, 0, -2>, 0, <1, 0, -2>, 0.3}
That's a cone pointing right with a base radius of 0.3 unit and tapering
to a tip of 0 unit radius. It's length is 1 unit parallel to the X axis.
Note : a cone can take a negative radius. In this case, you'll get a
double cone. You can try this :
cone{2*x, 2, -2*x, -2 pigment{rgb 1} inside_texture{pigment{rgb<0,0,1>}}}
Yes, the left part IS blue.
The complete object is a 3/4 of a torus with a major radius of 2 units
and a minor radius of 0.1 unit and a cone making a circular arrow
indicating a clockwise rotation. It start at the origin, but gets mooved
away from it by the translate<4,4,0>.
Start by removing the translate. This put the object back around the
origin. Give it a name like :
#declare Circular_Arrow = union{...}
If you need to, use "rotate <XRot, YRot, ZRot> to orient it like you
want. You may want to first rotate it around the Y axis, then tilt it.
It can be done as follow :
rotate Angle*y rotate <XTilt, 0, ZTilt>
Finally, move it to where you want it to be using your own translate
statement.
translate My_Location or translate <XPosition, YPosition, ZPosition>
Date: 10 Nov 2016 20:10:01
Message: <web.58251a3e329b68a8116828db0@news.povray.org>
Dear Ominverse, Bald Eagle and Alain,
Thank you so much!
This is extremely helpful to me. I have read your comments carefully.
I found an example "a_geo_lin02.pov" from  http://wwww.f-lohmueller.de. I also
followed Ominverse's and Alain suggestions to rotate.
Alain, Thanks a lot for your explanation about this -2*z,0.0, -2*z+1*x,0.3. In
physics, x,y,z are called unit vectors.
Here is my first pov file. If you render it, you will find that the arrows that
I have for the moment are not entirely straightforward, because of "difference"
commend cutoff. I really struggle a lot on this since I could not find an easy
to know what the box should be.
I wonder whether you have some idea or can modify my following script, so my
script does not have this problem.
Thank you very much!
Best regards,
Guoping
// PoVRay 3.7 Scene File "a_geo_lin02.pov"
// Author: Friedrich A. Lohmueller, 2004/2009/2011
// email: Fri### [at] t-onlinede
// homepage: http://wwww.f-lohmueller.de
global_settings{ assumed_gamma 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
#include "stones.inc"
#include "woods.inc"
#include "shapes.inc"
#include "shapes2.inc"
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
#declare Camera_0 = camera {                                 // xy-view
                             angle 20
                             location  <0.0 , 0.0 ,-38.0>
                             look_at   <0.0, 0.0 , 0.0>
#declare Camera_1 = camera {                                // diagonal view
                             angle 9
                             location  <40.0 ,40.5 ,-40.0>
                             look_at   <0.3 , 1.5 ,-0.2>
#declare Camera_2 = camera {                               // yz-view
                             angle 20
                             location  <31.0 , 7.0 ,1.0>
                             look_at   <1.5 , 1.4 , 1.0>
#declare Camera_3 = camera {
                             angle 20
                             location  < 0.0 , 37.5 ,-0.0001>
                             look_at   <0 , 0 , 2.0>
#declare Camera_4 = camera {
                             angle 20
                             location  < 0.0 , 37.5 ,-0.000>
                             look_at   <0 , 0 , 00>
#declare Camera_5 = camera {
                             angle 5
camera{Camera_1}
// sun -------------------------------------------------------------------
light_source{<1500,2500,-2500> color White}
// sky -------------------------------------------------------------------
sky_sphere{ pigment{ gradient <0,1,0>
                     color_map{ [0   color rgb<1,1,1>         ]//White
                                [0.4 color rgb<1,1,1>]//~Navy
                                [0.6 color rgb<1,1,1>]//<0.14,0.14,0.56>]//~Navy
                                [1.0 color rgb<1,1,1>         ]//White
                     scale 2 }
           } // end of sky_sphere
// This is my arrow first.
#declare xdir=-1.5;
#declare ydir=-3.5;
#declare zdir=-1.5;
union{
union{
cone {
    <xdir, ydir-1, zdir>, 0.0    // first three number are x,y,z coordinates,
and the last number is radius. Center and radius of one end
    <xdir, ydir, zdir>, 0.3    // Center and radius of other end
                pigment{color rgb<1,0.55,0.0>}
              finish {ambient 0.15 diffuse 0.85 phong 1}
     no_shadow
 cylinder {
    <xdir,ydir,zdir>,     // Center of one end
    <xdir,ydir+3.5, zdir>,     // Center of other end
    0.1                     // Radius
    open           // Remove end caps
              pigment{color rgb<1,0.55,0>}
 no_shadow
 rotate <0,0,0> // shows left-handed x rotation
//translate <-3,-1,0>
//plane { <0, 1, 0>, -10
  //  pigment {
//      checker color Blue, color White
//checker color rgb < 0.05, 0, 0.35>, color White
union
  cone { 1.5*z,0.3, 1.5*z+1*x,0 }
  difference {
    torus { 1.5,0.1 }
    box { <0,-0.5,-1>,<2,0.5,2> }
//  pigment { Green  }
texture {pigment{ color rgb<0.2,0,0.3>}
         finish { phong 0.8}}
 no_shadow
 rotate <180,0,0> // shows left-handed x rotation
translate <-3,-3,0>
//===========================second arrow===============
union{
cone {
     no_shadow
 cylinder {
    0.1                     // Radius
 no_shadow
translate <2,-5,0>
union
  difference {
    torus { 1.5,0.1 }
    box { <0,-1,0>,<4,1,4> }
//  pigment { Red  }
texture {pigment{ color rgb<1,0,0>}
 no_shadow
 rotate <0,120,0> // shows left-handed x rotation
translate <2,0.,0>
translate <0,3.5,0>
union{
 box { <-3,-0.8,-2>,<3,-1.0,2> }
checker color rgb < 0.45, 0, 0.15>, color White
 no_shadow
//==================++++END===========================
> > union
> >   difference {
> >     torus { 2,0.1 }
> >   pigment { Green  }
> >  no_shadow
> >  translate <4,4,0>
> > Best regards,
> > Guoping Zhang
> It evaluate as :
> statement.
> Alain
Date: 11 Nov 2016 06:10:10
Message: <5825a712$1@news.povray.org>
Hi
I do not understand what you think is wrong.
Do you mean the the vertical arrows are not in the centre of the torus
arrows?
If that is the case, you might get a better idea of your scene if you do
a render from the top, front and side. To adjust the translations and
see what is happening.
Another thing that might be confusing is PovRay's coordinate system.
Normally the Y axis is up. Some other programs use the Z axis for up.
Regards
Date: 11 Nov 2016 07:50:00
Message: <web.5825bdf5329b68a8b488d9aa0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
>... you might get a better idea of your scene if you do
Yes.
Take all of your objects and put them inside one big union{}
#declare Scene = union {
(all of your scene objects)
Then you can:
object {Scene translate x*10 rotate  y*90}
object {Scene translate y*10 rotate -x*90}
to get 3 orthogonal views.
Stephen's suggestion about mapping out the axes so that you can keep track is a
great one - it helps keep everything straight when you're trying to write SDL
and get all the parameters right.
Also, when using a difference, I find it helpful to define the object being
subtracted as a separate object, then use it in the difference{}, but also PLACE
IT into the scene with something like pigment {rgbt <1, 0, 0, 0.95>} so that it
shows up as a transparent thing that you can see.   Because sometimes you make a
mistake and the thing you want to subtract isn't in the right place or
orientations at all, and this helps debug the scene.
Great work so far - keep it up   :)
Date: 11 Nov 2016 12:37:45
Message: <582601e9$1@news.povray.org>
I define Front, side, Top orthogonal cameras and a free moving camera
for taking the image. Duplicating the set up of a technical drawing.
Bald Eagle's idea of using transparent textures for unions is very useful.
Regards
Date: 14 Nov 2016 19:50:06
Message: <web.582a5a7a329b68a8116828db0@news.povray.org>
Thank all of you so much for your great help!
This is an awesome platform. My skill grows everyday. Now, I am able to use most
of techniques that you introduced.
Here comes with a new challenge. I want to read data from a file on my disk. The
data file has something like this
1.0, 2.0,3.0, 4.0, 5.0, 6.0
7.0, 8.0, 9.0, 10.0,11.0,12.0
I want to draw an arrow from
Vector (1,2,3) to Vector (4,5,6)
and so on.
I read most of the 2.8.4.3 File Input/Output, and one post on the forum.
This is my first script.
//---------------------Head------------------------
#declare Vector1 = array[2][3] //2 rows and 3 columns
#declare Vector2 = array[2][3]
#fopen MyFile "data" read
#fopen MyFile1 "data.out" write
#while (defined(MyFile))
#read (MyFile,VECTOR_IDENTIFIER,Vector1,Vector2)
#write (MyFile1,VECTOR_IDENTIFIER,Vector1,Vector2)// check what I am reading in
any data
//---------------------end--------------------------------
Hey, this does not work. It only reads one line, and even the output has a wrong
number.
I would appreciate it if you could point out my mistakes.
Thanks a lot again!
Best wishes,
Guoping
> Yes.
> Then you can:
Date: 15 Nov 2016 08:25:01
Message: <web.582b0bf9329b68a8b488d9aa0@news.povray.org>
I'm at work now, but give this a look and see if this example scene helps
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.56d702f78f8162b55e7df57c0%40news.povray.org%3E/
