POV-Ray : Newsgroups : povray.general : Hardware Server Time
15 Aug 2025 21:17:06 EDT (-0400)
  Hardware (Message 1 to 4 of 4)
Subject: Hardware
Date: 26 Aug 2016 12:55:01
Message: <web.57c073fe7ef8bb6b488d9aa0@news.povray.org>
I might be able to get something like a Dell PowerEdge M905
with 4 x AMD Opteron or 4 x Xeon 2.00GHz/18M/6.40
Can I effectively run POV-Ray on something like this?
What OS, pros / cons, etc...
Subject: Re: Hardware
Date: 27 Aug 2016 17:52:21
Message: <57c20b95$1@news.povray.org>
> Thanks   :)
Windows pro support 1 or 2 CPUs and up to 256 cores, dont'know about the
server version. Lesser versions only support single multi-core CPU.
Linux can probably cope with that.
POV-Ray will run correctly on that hardware, as long as the OS correctly
support it.
Date: 29 Aug 2016 10:10:01
Message: <web.57c4411115fbfc0b3f0c86ab0@news.povray.org>
> Thanks   :)
i do not have any specific knowledge about that unit but it appears to be a
blade so it would require an enclosure.  also it appears to be for opteron 8000
series; the best of that series that passmark (cpubenchmark.net) lists is 8439
se which has a somewhat insipid score.
  also what alain mentioned, and that these servers sometimes have proprietary
drivers.  using linux flavors could be problematic.
Date: 29 Aug 2016 19:20:01
Message: <web.57c4c24f15fbfc0b5e7df57c0@news.povray.org>
"green" <rov### [at] gmailcom> wrote:
Right, it's a blade, though some have the Xeon in them, and I figured even if it
wasn't an amazing processor, there would be _24_ cores and room for like 96 GB
of memory, which would sort of make up for that  ;)
I'm not sure if I could power and cool it without the enclosure (it's _massive_
- and we have 6  :O ) and Alain's point about the proprietary drivers, etc.  is
something I was concerned about.
Thanks for your input!  :)
