POV-Ray : Newsgroups : povray.general : RAM consumption increasing steadily. Rendering 100k images Server Time
4 Mar 2026 02:38:04 EST (-0500)
  RAM consumption increasing steadily. Rendering 100k images (Message 1 to 10 of 14)
Subject: RAM consumption increasing steadily. Rendering 100k images
Date: 5 May 2016 10:25:00
Message: <web.572b572641f9f6078bfd5e7f0@news.povray.org>
I am rendering about 100k frames using an ini file of the same object type, each
having a random (in a box) configuration of the object, no of objects, camera
location, light source, viewing angle etc. Issue is RAM consumption increases
monotonically. I don't know what garbage value isn't being thrown. Is there a
macro to delete stuff manually at the end of a .pov file, or any other good
practices? (new to povray here)
Subject: Re: RAM consumption increasing steadily. Rendering 100k images
Date: 5 May 2016 11:00:56
Message: <572b6028$1@news.povray.org>
Am 05.05.2016 um 16:22 schrieb ratneshmadaan:
What version of POV-Ray are you using, and on what operating system?
Date: 5 May 2016 12:30:00
Message: <web.572b74b5950b0f561605d6c20@news.povray.org>
Crap. I rebuilt povray on a server, and this time I used the master branch,
instead of 3.7 stable branch. Ubuntu 14.04. Could that be the issue?
Date: 5 May 2016 13:12:07
Message: <572b7ee7$1@news.povray.org>
Am 05.05.2016 um 18:28 schrieb ratneshmadaan:
Generally I'd expect the current master branch to have /fewer/ memory
leaks than the 3.7 stable. But there's always the possibility that I
might be mistaken.
If the increase in RAM consumption proses a serious problem, you may
consider rendering the animation in multiple batches, using the +SFn and
+EFn command-line switches.
Date: 5 May 2016 21:25:00
Message: <572bf26c$1@news.povray.org>
Am 2016-05-05 13:12, also sprach clipka:
> might be mistaken.
I can't comment on the /fewer/ than 3.7, but the latest pvengine*.exe
leaks pretty bad.  I mentioned once that my workflow includes exiting
and restarting povwin every couple hundred to 1000 frames rendered.    I
notice about a 50-100KB leak per frame rendered.  Even when the render
job is done is doesn't give back the memory.  After povwin consumes 2GB
of leaked memory, it gets pretty sluggish. (I have 16GB of memory.)
For production, I use povconsole which renders one frame per call, so I
don't care about leaks there.
I was always a little surprised that Jaime didn't weigh in on this
issue. I figured with the heavy complicated scenes he makes, he must
notice this. (Although I've never heard him complain about anything. ;) )
dik
Date: 5 May 2016 22:50:48
Message: <572c0688@news.povray.org>
Am 06.05.2016 um 03:25 schrieb dick balaska:
From what I see, Jaime is mainly into stills, where leaks are certainly
less of a problem, even when the scenes are much more complex.
Also, any observations that might help identify the leaks are more than
welcome. I'd expect most leaks to be specific to the use of particular
features rather than constant per-frame overhead.
My understanding from your description is that memory consumption not
only rises during animation rendering, but remains high even after the
final frame has finished, right?
If you could provide me with a scene that is guaranteed to exhibit lots
of leakage in the most recent Windows binaries and isn't too slow to
render, maybe along with a bit of technical information on how much
leakage you observe, I'd appreciate that as well. I don't do any serious
animations work with POV-Ray myself, so I have only very simple test
scenes to go by, which do not seem to demonstrate any increase in the
memory footprint that would stand out among the normal random
fluctuations seen in the task manager.
Feel free to email any helpful animation scenes to "christoph", at
"lipka-koeln" in the "de" domain.
Date: 6 May 2016 05:04:49
Message: <572c5e31$1@news.povray.org>
> certainly less of a problem, even when the scenes are much more
> complex.
   Yes, I did very few animations, but none recently. With stills I never
noticed anything strange about memory usage. I will try some of my old
animations this weekend, to see if I can confirm this...
jaime
Date: 6 May 2016 15:32:26
Message: <572cf14a$1@news.povray.org>
Am 2016-05-05 22:50, also sprach clipka:
My art is all csg spheres and boxes, cones and torii. No radiosity or
modern features.  I will whip something off. (Maybe I can put 1000
spheres *behind* the camera).
I never thought of the leak as animation specific, just the act of
calling the renderer, which is why I thought of Jaime.  Maybe it is
related to +SF10 +EF20.
dik
Date: 6 May 2016 21:41:36
Message: <572d47d0$1@news.povray.org>
Am 06.05.2016 um 21:32 schrieb dick balaska:
What -- no functions? No macros? No arrays? No spline-based movement? ;)
I wouldn't be surprised if the memory leaks turned out to be related not
so much to /what/ you populate your scene with, but /how/.
Nah, the +SF and +EF options don't have much of an effect on the way
POV-Ray operates; it just changes how it computes the frame_number and
clock, that's all.
Date: 7 May 2016 04:32:57
Message: <572da839$1@news.povray.org>
> not so much to /what/ you populate your scene with, but /how/.
   First, let see if I understand this correctly: in an animation where
there are the same exact number of objects, and only some objects move,
the memory consumption should stay stable from the first frame, isn't?
   If so, I see a little increase from frame to frame on a test I did:
along 1000 frames, the memory increased some 300K. And in this special
case, there is only /what/, not any /how/... the movement was calculated
with the bullet physics playground, and as such there are no
calculations, no functions, no macros, no splines. Only a different
include for each frame with the same objects using different matrix values.
jaime
