POV-Ray : Newsgroups : povray.general : large city models in povray Server Time
15 May 2025 01:42:49 EDT (-0400)
  large city models in povray (Message 1 to 10 of 13)
Subject: large city models in povray
Date: 18 Nov 2015 17:45:01
Message: <web.564c88fa77681a2fc45346000@news.povray.org>
Hello
I'm new here and in using povray.
I will use povray to render scenes from a large city model. Each object of the
city model is a single wavefront obj-file. There are about 4'500 objects. The
objects are mapped with an image.
I wrote a python-script to convert the files into pov-scenes. Each object in a
single include-file. In the scene-file i include all of this files. When i will
render the scene (just a small section in the camera definition) i have a
problem with the memory, while povray is parsing the scene. It works when i
leave out the image mapping. The Objects are then the just "grey".
Can anybody give me a tip, how i can solve this problem? Is it possible to say
povray, that it should just parse the section in the cameraview?
Thanky you for your help.
Best regards, christian
Subject: Re: large city models in povray
Date: 19 Nov 2015 01:53:34
Message: <564d71ee$1@news.povray.org>
I think that the quick answer is no.
The long answer is it is possible to do it yourself.
A few years ago there was a post of a fly through over a forest. The
trees were billboards (Image map on a box, with transparency) and they
were pre-computed to load when they were in view.
It can be done but it involves more work. :-)
Regards
Date: 19 Nov 2015 03:46:47
Message: <564d8c77$1@news.povray.org>
Am 18.11.2015 um 15:19 schrieb christian:
There are several approaches you could try:
(1) Re-use some objects in multiple places to reduce the number of
objects (and textures) to load. Make sure to load each such object into
POV-Ray only once, using "#declare Foo = mesh2 { ... }", and then
instantiate it multiple times using "object { Foo }".
(2) Re-use the same image maps on multiple objects to only reduce the
number of textures to load. Again, make sure to load each image map only
once, using "#declare Foo = image_map { ... }", and then instantiate it
multiple times using "image_map { Foo }".
(3) Make use of "#if(...) #include "Foo_HighDetail.inc" #else #include
"Foo_LowDetail.inc" #end" to load low-detail versions of your objects
and/or textures if they're far from the camera position (note that
you'll need to provide the low-detail versions yourself), or even
exclude them objects entirely.
Date: 19 Nov 2015 03:47:28
Message: <564d8ca0@news.povray.org>
The quick answer is yes. ;-)
There is indeed a possibility to only render what is shown by the
camera. For this you need to test if a given object is visible within
the camera view field. Gilles Tran developed a macro which allows you to
do this.
Play with the attached scene file. The objects are tested against a
'screen'. I purposefully left this screen smaller than the camera view
so that you can play and learn to use it.
Download 'utf-8' (5 KB)
Date: 19 Nov 2015 04:26:35
Message: <564d95cb$1@news.povray.org>
> do this.
I did not know that. Thanks Thomas.
Regards
Date: 19 Nov 2015 07:16:14
Message: <564dbd8e$1@news.povray.org>
>> do this.
A smart little trick, isn't it?
It is difficult to keep track of all the little utilities developed here
over the years. I am afraid many and more are lost after their initial
release :-(
Date: 19 Nov 2015 09:44:33
Message: <564de051$1@news.povray.org>
>>> do this.
Very. :-)
> release :-(
It is, it is.
Regards
Date: 19 Nov 2015 12:39:46
Message: <op.x8czcbwfufxv4h@xena>
>>>> to
>>>> do this.
> Very. :-)
>> release :-(
> It is, it is.
IIRC  scenes\advanced\blocks also does something similar.
-Nekar Xenos-
Date: 20 Nov 2015 02:53:14
Message: <564ed16a$1@news.povray.org>
>>>>> you to
>>>>> do this.
>> Very. :-)
>>> release :-(
>> It is, it is.
I think you are right.
Date: 24 Nov 2015 05:35:01
Message: <web.56543c12c20c243dc45346000@news.povray.org>
> do this.
> Thomas
Thank you for all your answers. I have now used this macro. I needed some time,
but now it works very well and fast. :-)
I have another question in this context. Is there a smart way to generate normal
maps and depth maps in POV-Ray. Maybe I can use fog for the depth map?
I'm sure you can help me also in this point. Thank you. :-)
Regards Christian
