POV-Ray : Newsgroups : povray.general : Radiosity question Server Time
4 Mar 2026 05:47:45 EST (-0500)
  Radiosity question (Message 1 to 8 of 8)
Subject: Radiosity question
Date: 10 Aug 2015 03:25:01
Message: <web.55c850f9a69161dc2aaea5cb0@news.povray.org>
In an effort to speed the render of the scene I'm working on, I reduced the
radiosity settings to default, but wound up with large patches of pure white
with jagged edges.  I managed to fix some of it by increasing the number of
pretrace steps, but there are still large ambient areas in the render.
Can anybody tell me what causes this, and which settings I might adjust to fix
it? I can't find anything about this in the documents or tutorials.
A.D.B.
Subject: Re: Radiosity question
Date: 10 Aug 2015 17:09:48
Message: <55c9131c$1@news.povray.org>
Am 10.08.2015 um 09:21 schrieb Anthony D. Baye:
An image might help to better diagnose the issue. Are the "patches of
pure white light" isolated splotches, or do you have a general problem
with jagged edges in the radiosity gradients?
Generally, jagged edges are an indication that a lot of radiosity
samples are taken during the main render.
Whenever a sample is taken during the main render, some nearby pixels
have already been rendered with the presumption that the new sample
doesn't exist, using a different set of samples to interpolate between
than any pixel rendered later, so you get a discontinuity in the
gradient where the additional sample was taken. This isn't much of a
problem if the set of samples to interpolate between is large already,
as the discontinuity will be low in amplitude; but as the percentage of
samples taken during the main render grows, so does both the total
number /and/ amplitude of such discontinuities.
Among the report POV-Ray displays after finishing a render, there is a
table listing how many radiosity samples were taken during which pass at
which recursion depth, like this:
       Pass     Depth 0           Total
       1            148             148
       2            583             583
       3           2067            2067
       4           2028            2028
       Final       2571            2571
       Total       7397            7397
       Weight     0.282
As a rule of thumb, the number of top-level samples ("Depth 0") taken
during the main render ("Final" pass) should be less than half the
number of top-level samples taken in total.
If the number of samples taken during the main render is too high, this
indicates that your pretrace coverage is too low, and you may need to do
the following:
- Set "always_sample" to "off" (this is the default if "#version 3.7" or
higher is specified); this will cause POV-Ray to only take samples
during the main render if it absolutely needs them. If you instead set
this to "on", artifacts are almost guaranteed.
- Set "nearest_count" to a reasonably large value; this will cause
POV-Ray to aim for a higher pretrace coverage. A value of 5 is ok, but
10 is better, and I personally always use 20 except for test renders.
- Decrease "low_error_factor"; this will also cause POV-Ray to aim for a
higher pretrace coverage, while at the same time making it less picky
when it comes to re-using samples during the main render. (Note that
this comes at the cost of "blurring" the radiosity effect; but when a
low pretrace coverage is your problem, then that's probably your least
concern.)
- Increase the number of pretrace steps by decreasing "pretrace_end"
("pretrace_start" usually has only a small impact on the pretrace
coverage, as long as it's reasonably large). If the number of pretrace
steps is too low, POV-Ray will be unable to achieve the pretrace
coverage as requested by the other parameters.
If "pretrace_end" is already at the lowest effective value (the inverse
of the image size) and the number of pretrace steps is still lower than
necessary to achieve the pretrace coverage prescribed by the other
parameters, the following settings may also help; they all affect the
pretrace coverage POV-Ray needs, but also the one it aims for:
- increase "error_bound" to reduce the required and aimed-for coverage
in general.
- Increase "minimum_reuse" to reduce the required and aimed-for coverage
near corners.
*BUT*
if your issue is isolated bright splotches, then the main problem is
most certainly entirely different, namely that you have some
comparatively small but very bright object in your scene. In that case,
you only have two viable options: Up your radiosity "count" parameter,
or try to replace that bright object with a conventional point or area
light source (maybe with a looks_like object).
Date: 10 Aug 2015 22:20:12
Message: <op.x26l3qwcufxv4h@xena>
>> the
>> white
>> number of
>> to fix
>        Pass     Depth 0           Total
>        1            148             148
>        2            583             583
>        3           2067            2067
>        4           2028            2028
>        Final       2571            2571
>        Total       7397            7397
>        Weight     0.282
> the following:
> concern.)
> in general.
> near corners.
> *BUT*
This should be added to the docs.
-Nekar Xenos-
Date: 10 Aug 2015 22:20:13
Message: <op.x26l3qvrufxv4h@xena>
>> the
>> white
>> number of
>> to fix
>        Pass     Depth 0           Total
>        1            148             148
>        2            583             583
>        3           2067            2067
>        4           2028            2028
>        Final       2571            2571
>        Total       7397            7397
>        Weight     0.282
> the following:
> concern.)
> in general.
> near corners.
> *BUT*
-Nekar Xenos-
Message: <op.x26l3qwoufxv4h@xena>
>> the
>> white
>> number of
>> to fix
>        Pass     Depth 0           Total
>        1            148             148
>        2            583             583
>        3           2067            2067
>        4           2028            2028
>        Final       2571            2571
>        Total       7397            7397
>        Weight     0.282
> the following:
> concern.)
> in general.
> near corners.
> *BUT*
-Nekar Xenos-
Date: 10 Aug 2015 22:22:50
Message: <op.x26l74d4ufxv4h@xena>
Oh no. Opera Mail is spamming my messages again.
:P
-Nekar Xenos-
Date: 11 Aug 2015 15:17:02
Message: <55ca4a2e@news.povray.org>
>> reduced the
>> white
>> number of
>> adjust to fix
> *BUT*
In this case, using importance can help.
Add:
#default{radiosity{importance 0.001}}
or
#declare Average_Count = 75;
#declare High_Count = 160000;
#default{radiosity{importance Average_count/High_Count}}
In the radiosity block, set count to a large value:
count 160000
or
count High_Count // With declared indentifier
In your small and bright object(s), add this:
radiosity{importance 1}
That way, on average, you'll use about 160 samples for most of the
render, but up to 160000 for those problematic small and bright objects.
Date: 31 Aug 2015 23:25:00
Message: <web.55e5197f41eb7d7f69dae6480@news.povray.org>
> >> reduced the
> >> white
> >> number of
> >> adjust to fix
> > *BUT*
> Add:
> or
> count 160000
> or
It sounds useful.
