POV-Ray : Newsgroups : povray.general : Strange behavior Server Time
15 May 2025 05:13:53 EDT (-0400)
  Strange behavior (Message 1 to 5 of 5)
Subject: Strange behavior
Date: 15 Jan 2015 22:10:00
Message: <web.54b87fbda54f2dcbd92286f0@news.povray.org>
Say I have a macro that returns values:
#macro someMacroReturningAValue(params)
    #local _RESULT = foo;
    // do stuff here...
    _RESULT
I can use this macro in a computation, thusly:
object { bar translate someMacroReturningAValue(params)*x }
but I cannot set the macro as the rValue of a declaration, like so:
#declare blah = someMacroReturningAValue(params);
because povray doesn't see the semicolon at the end of the declaration.  I can
add the semicolon inside the macro, and the declaration works, but the first
usage breaks.
in order to make the declaration work without breaking the first usage, I have
to encapsulate the macro call in parentheses:
#declare blah = (someMacroReturningAValue(params));
Which, obviously, forces the macro to be evaluated first, but I have no idea why
it makes a difference, and it makes for a very confusing error.
Any explanations?
A.D.B.
Subject: Re: Strange behavior
Date: 16 Jan 2015 03:01:42
Message: <54b8c566$1@news.povray.org>
>      // do stuff here...
>      _RESULT
> #end
The below code runs fine here, does it work ok on your installation?
What are you doing differently (eg what is "params" defined as?). Can
you produce just a few lines that others can run to reproduce the problem?
     #local _RESULT = params * 2;
     _RESULT
#local p = 1;
#declare blah = someMacroReturningAValue(p);
Date: 16 Jan 2015 20:10:00
Message: <web.54b9b549ec0f5b601591f79b0@news.povray.org>
> >      // do stuff here...
> >      _RESULT
> > #end
>      _RESULT
> #end
> #local p = 1;
hallo
this fail
#declare rndx=seed(123);
#macro rnr(nrx,mii,mxx)
 #if(mii>=0)
   (rand(nrx)*(mxx-mii+1)) + mii
 #else
   mii+(mxx-mii)*rand(nrx) /////////  LINE 40
#local d=0;
#local d=rnr(rndx,-20,20);
 line 40: Parse Error: All
 #declares of float, vector, and color require semi-colon ';' at end if the
 language version is set to 3.5 or higher. Either add the semi-colon or set the
 language version to 3.1 or lower.
Fatal error in parser: Cannot parse input.
Render failed
this work ok
 #if(mii>=0)
 #else
#local d=<0,0,0>;
#local d=<rnr(rndx,-20,20),0,0>;
Date: 16 Jan 2015 22:50:01
Message: <54b9dbe9$1@news.povray.org>
Am 17.01.2015 um 02:05 schrieb eticre:
> this fail
>   #if(mii>=0)
>   #else
>   #end
> #end
> #local d=0;
This is a known issue rooted deep in the current parser (and not due to
be fixed before implementation of a brand new parser); to work around,
first assign the expression to a local variable, then finally "return" that:
     #if(mii>=0)
       #local result = (rand(nrx)*(mxx-mii+1)) + mii;
     #else
       #local result = mii+(mxx-mii)*rand(nrx);
     result
The issue reported by the OP, however, is that this construct allegedly
doesn't always seem to work either; but for the time being I presume
that Anthony accidently did something wrong.
Date: 16 Jan 2015 23:20:01
Message: <web.54b9e246ec0f5b60bd92286f0@news.povray.org>
> > this fail
> >   #if(mii>=0)
> >   #else
> >   #end
> > #end
> > #local d=0;
>      #if(mii>=0)
>      #else
>      #end
>      result
>    #end
I could have been certain that I did exactly this, but I suppose that
considering the complexity of what I was working on, there was something I
missed.
my simple test, also works for both cases:
#version 3.7;
light_source { <5, 10, -30> rgb 1 }
  perspective
  location <0.0, 0.0, -10.0>
  up y
  right x*(image_width/image_height)
  look_at 0
#macro mrav(V)
  #local result = V;
  // stuff and junk...
  result
#declare myval = mrav(5);
sphere { 0.0 0.125 pigment { rgb 1 } translate mrav(5)*x }
A.D.B.
