POV-Ray : Newsgroups : povray.general : 3D Glass-like block and problem with inner faces Server Time
22 Mar 2026 07:35:13 EDT (-0400)
  3D Glass-like block and problem with inner faces (Message 1 to 10 of 18)
Subject: 3D Glass-like block and problem with inner faces
Date: 21 Nov 2014 04:40:05
Message: <web.546f077ea1efff3d4a99f14a0@news.povray.org>
Dear friends,
I'm beginner in POV-Ray and I have a little problem with rendering my scene.
I have just one object in my scene, which is a 3D block.
The block is made by several 3D adjacent boxes and each box is made by 8
vertices and six faces (or 12 triangles, 2 per face).
The whole block is a "Mesh2" type object (just one), in which I have defined a
vertex vectors for all the vertices and the face_indices for the triangles.
            mesh2 {
                  vertex_vectors {
                                  80,
                                  <0,0,0>, <0.5,0,0>, <0.5,0.5,0>
                  face_indices {
                                120,
                                <0,1,2>
In short, I have a 3D block made by several triangles.
For rendering, I have also applied a transparent color to my object, as I wish
to be able to see the depth of my bock (like an glass block).
The problem is that the whole block do not appear as "one" object as I wish and
we  see unfortunately all the inner faces in the block and I don't have the
glass-like effect.
I have also tried to do a "Merge", but it didn't work. I think it's because I
have defined just one object ( a "Mesh2" one).
Do you have any idea how to solve this problem?
Thank you all in advance
P.S. I have POV-Ray version 3.6.
Subject: Re: 3D Glass-like block and problem with inner faces
Date: 21 Nov 2014 07:32:29
Message: <546f30dd$1@news.povray.org>
Not sure what your problem is, but I guess it is the texture you use.
Have you tried the glass materials in textures.inc? For instance try
this for your cube, after including the textures file:
#include "textures.inc"
material {M_Yellow_Glass}
That should do the trick. Glass has a different ior from air which is 1.
That is why you need to define a material with a glass ior=1.5.
Have a look at the Docs about the use of materials
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_5_5_3
Also, you should switch to version 3.7 which is the latest and best
version to date as many issues still present in version 3.6 has been
corrected, and many new features added.
To better explain your problems, post an image on
povray.binaries.images. That may help us a lot to determine how to
improve your scene.
Welcome, by the way, to this community.
Date: 21 Nov 2014 08:43:14
Message: <546f4172$1@news.povray.org>
On 21/11/2014 09:35, Saman wrote:
> Dear friends,
[Snip]
> glass-like effect.
Hi Saman and welcome.
My reading of the first two sentences is that you have lots of blocks in
the shape of a block. So what you are seeing is correct.
I always try to visualise what it would look like in reality.
You would need to build your big block with squares if what I think you
want is right.
But as Thomas said post an image.
Regards
Date: 26 Nov 2014 07:40:00
Message: <web.5475c964569da8754a99f14a0@news.povray.org>
Thanks for the answers, here is the link of my scene:
https://www.dropbox.com/s/au2t9g5l7btmhqu/Block3D.png?dl=0
As you can see, some faces are shared between two cubes.
The whole block is defined by one "mesh2" object, in which I have defined
several triangles to make a cube. The whole block is made of these cubes.
The problem is, that I have a transparent block and I would like these inner
faces do not appear. I have also tried to apply the "merge" function to my whole
block but it didn't work.
I'm looking forward to read you.
Date: 26 Nov 2014 07:40:01
Message: <web.5475c9bd569da8754a99f14a0@news.povray.org>
Date: 26 Nov 2014 07:58:18
Message: <5475ce6a$1@news.povray.org>
The image is a bit small to see clearly with my old eyes. :-) Please
make a 640x640 pixel image (for instance) and post it at p.b.i.
First, can you tell us how you obtained the mesh2 object? Did you write
the triangles yourself or did you make an object first using an external
modeller? This info might be important to find a solution.
Note that mesh2 has been specifically designed for conversion from other
formats, not for direct building.
Second, have you tried to load your mesh2 file into Poseray? That might
help to see how the triangles behave and if all common vertexes for
instance are merged.
Date: 26 Nov 2014 08:25:01
Message: <web.5475d402569da8754a99f14a0@news.povray.org>
Here is a very simple example with just two cubes which share a common face:
Link to the image:
https://www.dropbox.com/s/rfkcvxlerko3qmw/Mesh2%28merged%29.png?dl=0
I have used the "merge" function to merge the two cubes, but as you can see,
the shared inner face still appears.
I have defined two cubes as follow:
//POV-Ray
background { color rgb < 0.8945, 0.8945, 0.8945 > }
camera { location <20, 5, -20>   look_at  <5, 5,  5> }
light_source { <100, 0, 0> color White}
merge{
  mesh2{ //Box 1
 vertex_vectors {
  8,
  <0,0,0>, <5,0,0>, <0,5,0>, <5,5,0>,
  <0,0,5>, <5,0,5>, <0,5,5>, <5,5,5>,
 face_indices{
  12,
  <0,1,2>, <1,2,3>,
  <4,5,6>, <5,6,7>,
  <0,2,4>, <6,2,4>,
  <1,3,5>, <7,3,5>,
  <0,1,4>, <5,1,4>,
  <2,6,3>, <7,6,3>,
    texture { pigment {color Black transmit 0.9} finish {phong .8} }
  mesh2{ //Box 2
 vertex_vectors {
  8,
  <5,0,0>, <10,0,0>, <5,5,0>, <10,5,0>,
  <5,0,5>, <10,0,5>, <5,5,5>, <10,5,5>,
 face_indices{
  12,
  <0,1,2>, <1,2,3>,
  <4,5,6>, <5,6,7>,
  <0,2,4>, <6,2,4>,
  <1,3,5>, <7,3,5>,
  <0,1,4>, <5,1,4>,
  <2,6,3>, <7,6,3>,
Date: 26 Nov 2014 08:57:10
Message: <5475dc36$1@news.povray.org>
That is because the face *is* there. You can reduce the impact by making
the material less reflective. (Also make sure that the max trace level
is greater than the number of faces that the rays trace).
Think of building your big block with real small glass blocks. You will
see the insides in Real Life. It is the same with Povray
The only way to get what you want is to do a difference of the big block
and a scaled (0.999) copy of itself.
#declare CSG1 =
difference {
object{ Big_Block}
object {
Big_Block
scale     <0.999,0.999,0.999>
texture{ Glass0 }
Regards
Date: 26 Nov 2014 09:03:23
Message: <5475ddab$1@news.povray.org>
On second thoughts I think that this is a max_trace_level.
What have you set it to in Global Settings?
Regards
Date: 26 Nov 2014 11:05:01
Message: <web.5475fa06569da8755e7df57c0@news.povray.org>
Window glass and max trace level tutorial:
http://www.f-lohmueller.de/pov_tut/interior/interior_03e.htm
