POV-Ray : Newsgroups : povray.general : No matching } in 'image_map', undeclared identifier 'gamma' found instead Server Time
17 Aug 2025 03:31:54 EDT (-0400)
  No matching } in 'image_map', undeclared identifier 'gamma' found instead (Message 1 to 6 of 6)
Subject: No matching } in 'image_map', undeclared identifier 'gamma' found instead
Date: 19 Sep 2014 06:55:00
Message: <web.541c0b069ebbba2545f6c5070@news.povray.org>
Hi all,
I tried to render a scene containing several objects, it ran correctly with
Povray 3.7, but got an error under Povray 3.6:
Parse Error: No matching } in 'image_map', undeclared identifier 'gamma' found
instead
The yellow line which shows the error is as following:
//Map definitions
#declare p_map1=pigment {image_map{jpeg "banana1_www.cgtsj.com__1_.jpg" gamma
srgb  transmit all 0 } }
Any suggestions?
Thank you.
Gfans
PS: I have to use Povray 3.6, so please do not just tell me to use 3.7 instead,
thanks.
Subject: Re: No matching } in 'image_map', undeclared identifier 'gamma' found instead
Date: 19 Sep 2014 07:00:08
Message: <541c0cb8$1@news.povray.org>
On 09/19/2014 06:52 AM, Gfans wrote:
> Hi all,
> instead
> //Map definitions
> Any suggestions?
> Thank you.
> Regards,
> Gfans
> thanks.
well sorry to tell you but that /is/ the case ... gamma handling was
/not/ implemented until v3.7
Subject: Re: No matching } in 'image_map', undeclared identifier 'gamma' found inste=
Date: 19 Sep 2014 07:10:00
Message: <web.541c0ed34bebc45345f6c5070@news.povray.org>
> > Hi all,
> > instead
> > //Map definitions
> > Any suggestions?
> > Thank you.
> > Regards,
> > Gfans
> > thanks.
Thanks, James. Are there any workarounds with v3.6?
Date: 19 Sep 2014 07:15:45
Message: <541c1061@news.povray.org>
>>> Hi all,
>>> instead
>>> //Map definitions
>>> Any suggestions?
>>> Thank you.
>>> Regards,
>>> Gfans
>>> thanks.
other than not using gamma or srgb keywords ... no
Date: 19 Sep 2014 07:30:00
Message: <web.541c12d782a779b845f6c5070@news.povray.org>
> >>> Hi all,
> >>> instead
> >>> //Map definitions
> >>> Any suggestions?
> >>> Thank you.
> >>> Regards,
> >>> Gfans
> >>> thanks.
Well, I will delete these keywords. Thanks. :-)
Date: 19 Sep 2014 09:23:33
Message: <541c2e55$1@news.povray.org>
Am 19.09.2014 13:09, schrieb Gfans:
>>> Hi all,
>>> instead
>>> //Map definitions
>>> Any suggestions?
>>> Thank you.
>>> Regards,
>>> Gfans
>>> thanks.
Step 1: If you're using "assumed_gamma 1.0", convert the image from sRGB
gamma to linear gamma.
In an image editing software like Photoshop or Gimp, you can do this by
first assigning the sRGB colour space to it, then converting it to a
custom colour space with sRGB primaries but a gamma of 1.0.
Alternatively, use a software that can perform power-law tonemapping,
such as LILYsoft's IC (highly recommended!), applying an exponent of
2.2. (This does not give exactly the same result, but should be good
enough in most cases.)
I recommend converting the image to 16 bit colour channel depth before
applying the gamma change, in order to avoid colour banding. Most
software may also require to save the image with this bit depth (which
in turn requires an image format other than jpeg, such as png); IC
performs dithering to avoid this, so saving with 8 bit colour channel
depth will do.
Step 2: Strip the "gamma srgb" statements from the POV-Ray code.
If you converted to a different file format in step 1, you'll of course
also need to change the file name and file type in the statement.
Step 3: In the long run, figure out why POV-Ray 3.6 is a requirement,
and how it can be replaced with POV-Ray 3.7 after all.
Note that without Step 1, the image map will inevitably appear washed
out in POV-Ray 3.6 when used with "assumed_gamma 1.0".
