POV-Ray : Newsgroups : povray.general : using duplicate #include files-- any problems? Server Time
1 Nov 2024 03:14:51 EDT (-0400)
  using duplicate #include files-- any problems? (Message 1 to 2 of 2)
Subject: using duplicate #include files-- any problems?
Date: 22 Apr 2014 20:30:01
Message: <web.535708ab8dde86b0c2d977c20@news.povray.org>
This is one of those questions that I should have asked years ago, but never got
around to it: Does inserting duplicate #include files into a scene cause any
hidden problems? Or extra memory usage? Not that I've noticed anything so far,
I'm just curious (especially regarding macros, and/or defined functions that may
need to be undefined first before being re-#included.)
This would be a 'typical' example...
#include "math.inc"
#include "transforms.inc"
#include "shapes.inc"  // this also has math.inc and transforms.inc
Over the years, I've seen a few newsgroup posts that essentially say: Don't do
this. But aside from 'bad coding practice', is is harmful? I would assume that
using all #locals in the #included files (vs. #declares) would eliminate any
problems(?)
It would be nice to have a definitive answer, though. (I've never seen an
explanation or caveat in the documentation, regarding this.)
Subject: Re: using duplicate #include files-- any problems?
Date: 23 Apr 2014 14:16:07
Message: <53580367@news.povray.org>
> #include "math.inc"
> problems(?)
All standard includes have a construct similar to the following:
At the beggining of the include:
#ifndef(Include_Flag)
#declare Include_flag=version;
Optionaly, version is set to 3.5 or 3.6.
All the code to be included
Need to restore the version number if it have been changed.
#version Include_Flag;
Close the #ifndef statement.
The variable <Include_Flag> is based on the name of the include file and
MUST be absolutely unique.
This insure that you don't reparse the file if it have been oncluded before.
For your own includes, I suggest that you do the same.
There are some cases where an include file actualy set an object WITHOUT
assining it any identifier. In this case, including the file will place
the object in your scene. If you want to move or rotate it, you need to use:
object{ #include "Object File.inc" scale Your_Scale rotate Your_Rotate
translate Your_Transte}
For those, it can be normal to include the file several times. It would
be beter to have this:
#declare Included_Object= object{#include "Object File.inc"}
and, then use that defined object.
