Here I am again!
#fopen MyFile "niks.txt" write
#declare i=1;
#while (i <= 5)
#write (MyFile, i,",")
#declare i=i+1;
#end // while
#fclose Myfile
#fopen MyFile "niks.txt" read // Here parse error!
#declare i=1;
#while (i <= 5)
#read (MyFile, i)
#declare i=i+1;
#end // while
#fclose Myfile
This piece of code gives a parse error on the indicated line:
Cannot read from file niks.txt because the file is open for writing only
What is wrong here?
I'm using Windows 7
Paul
Le 17/04/2014 17:17, pbrants nous fit lire :
> Here I am again!
> #declare i=1;
> #while (i <= 5)
> #declare i=i+1;
> #end // while
> #fclose Myfile
> #declare i=1;
> #while (i <= 5)
> #read (MyFile, i)
> #declare i=i+1;
> #end // while
> #fclose Myfile
> What is wrong here?
> I'm using Windows 7
You closed Myfile, but opened MyFile. Typo! (Camel vs Pascal)
Le_Forgeron <jgr### [at] free fr> wrote:
> > #fclose Myfile
Which raises the question of why POV-Ray doesn't give an error if you
use #fclose with an undefined identifier.
> > Here I am again!
> > #declare i=1;
> > #while (i <= 5)
> > #declare i=i+1;
> > #end // while
> > #fclose Myfile
> > #declare i=1;
> > #while (i <= 5)
> > #read (MyFile, i)
> > #declare i=i+1;
> > #end // while
> > #fclose MyFile
> > What is wrong here?
> > I'm using Windows 7
Sorry, it was a typo indeed, but it gives the same error with the typo
corrected!
Paul
Sorry again, it was a typo in the original program, all works OK now!
Paul
>> > Here I am again!
>> > #declare i=1;
>> > #while (i <= 5)
>> > #declare i=i+1;
>> > #end // while
>> > #fclose Myfile
>> > #declare i=1;
>> > #while (i <= 5)
>> > #read (MyFile, i)
>> > #declare i=i+1;
>> > #end // while
>> > #fclose MyFile
>> > only
>> > What is wrong here?
>> > I'm using Windows 7
> corrected!
> Paul
What is the content of niks.txt if you open it in text editor?
Ger
> corrected!
> Paul
I didn't see that typo for about half an hour(!), while playing with your code.
Prior to noticing it, I was trying everything under the Sun-- eventually
re-writing your code verbatim. I was just getting ready to post the same
'solution.' ;-)
BTW, the #write and #read blocks can have *different* 'file handle identifiers'
and still work OK (I've never seen any problems when doing so.)
#fopen ABC "niks.txt" write
#write(ABC, ... )
#fclose ABC
#fopen XYZ "niks.txt" read
#read(XYZ, ...)
#fclose XYZ
>>> Here I am again!
>>> #declare i=1;
>>> #while (i <= 5)
>>> #declare i=i+1;
>>> #end // while
>>> #fclose Myfile
>>> What is wrong here?
>>> I'm using Windows 7
> corrected!
IF I read your code above, you corrected the typo in the #read but not
in the #write section...
As a side note, be aware that in your #read section, you use the
parameter i for two different things at the same time. Except if
intended, you may get strange results. An alternative would be:
#while (defined (MyFile))
#read (MyFile, i)
do here what you want to do with i
#end // while
#fclose MyFile
