POV-Ray : Newsgroups : povray.general : What use is ifdef ? Server Time
17 Aug 2025 12:56:03 EDT (-0400)
  What use is ifdef ? (Message 1 to 5 of 5)
Subject: What use is ifdef ?
Date: 3 Mar 2014 12:50:00
Message: <web.5314c0a9c473c8865f52a9c30@news.povray.org>
I know what ifdef does (the example below shows me using it)...
//#declare text2use = 2;
box     {
        <-10,0,11>,<10,10,10>
        #ifdef(text2use)
                texture { pigment { White } }
        #else
                texture { pigment { Green } }
.... but I'm struggling to understand when you would use it. Why would you refer
to a variable you've not defined?  Isn't that just sloppy coding.
Has anyone got/had a real-use case for this command? I'd love to know what I'm
missing out on.
Subject: Re: What use is ifdef ?
Date: 3 Mar 2014 12:55:05
Message: <5314c1f9$1@news.povray.org>
Le 03/03/2014 18:49, FNH nous fit lire :
> box     {
>         #ifdef(text2use)
>         #else
>         #end
> missing out on.
you can define variable in code, but also in command line.
the most traditional use is the classical protection of include file: if
the value already exist, skip the definition.
Date: 3 Mar 2014 13:05:01
Message: <web.5314c4368b4b40c85f52a9c30@news.povray.org>
> > box     {
> >         #ifdef(text2use)
> >         #else
> >         #end
> > missing out on.
Excellent, I'll have try using as a command line switch. Thanks :)
Date: 3 Mar 2014 14:45:01
Message: <web.5314dabf8b4b40c872f270270@news.povray.org>
> box     {
>         #ifdef(text2use)
>         #else
>         #end
> missing out on.
It is just to ensure that a certain thing exists. Your code will use this thing
and you can define a default value, if you have not defined it earlier - may be
at the command line or with an earlier include or within the code itself.
Best regards,
Michael
Date: 3 Mar 2014 19:19:00
Message: <53151bf4@news.povray.org>
> box     {
>          #ifdef(text2use)
>          #else
>          #end
> missing out on.
It's often used in includes. Some uses are:
Make sure that you don't re-parse a file that's been included before.
Take a look at the base includes, they all have this construct:
#ifndef(Include_File_Flag)
#declare Include_File_Flag=version;
...body of the include file goes here...
Have some defaults parameters that you can optionaly define before
calling an include or a macro.
