POV-Ray : Newsgroups : povray.general : Struggling to understand diffuse Server Time
28 Mar 2026 18:49:04 EDT (-0400)
  Struggling to understand diffuse (Message 1 to 6 of 6)
Subject: Struggling to understand diffuse
Date: 2 Mar 2014 05:10:01
Message: <web.53130302924e72735f52a9c30@news.povray.org>
In the following scene I expect the white sphere to show a hint of red or green
across its surface, thrown up by the nearby objects. Can anyone tell me what
I've misunderstood about diffuse? Is there something that needs to be added to
the sphere's texture?
#version 3.7;
global_settings{ assumed_gamma 1.0 }
camera {/*ultra_wide_angle*/ angle 75      // front view
                            location  <0.2 , 1.7 ,-3.2>
                            look_at   <0.3 , 1.0 , 0.0>}
light_source{<-1500,2500,-2500> color White}
light_source{ <-1000, 800, 3000>
              color White
plane { <0,1,0>, 0
        texture { pigment{ color Green} finish { diffuse 1 }
light_source { <-11,103,0>, White}
cylinder{
        <-1,0,0>,
        <-1,0,5>,
        1
                pigment { Red }
                finish  {
                        diffuse 1
                        brilliance .2
                        reflection 0.1
sphere  {
        <1,1,1.2>,1
                pigment { White }
                finish { ambient 0 diffuse 1}
Subject: Re: Struggling to understand diffuse
Date: 2 Mar 2014 05:18:55
Message: <5313058f$1@news.povray.org>
Le 02/03/2014 11:08, FNH nous fit lire :
Study the scene radiosity/cornell.pov
(from the delivered scenes with povray)
Date: 2 Mar 2014 06:06:33
Message: <531310b9@news.povray.org>
As Le Forgeron hinted, it's not additions to texture you need, but
radiosity. Add the following into your global_settings:
radiosity{
    pretrace_start 0.04
    pretrace_end 0.01
    count 200
    recursion_limit 3
    nearest_count 10
    error_bound 0.5
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 2 Mar 2014 07:10:00
Message: <web.53131f434ef600025f52a9c30@news.povray.org>
> radiosity{
>     pretrace_start 0.04
>     pretrace_end 0.01
>     count 200
>     recursion_limit 3
>     nearest_count 10
>     error_bound 0.5
> John
> Protect the Earth
Thank you! Totally missed that!
Date: 2 Mar 2014 07:15:49
Message: <531320f5@news.povray.org>
As I've said before to others, you're welcome. We learn by making mistakes.
John
Protect the Earth
Date: 2 Mar 2014 18:27:58
Message: <5313be7e@news.povray.org>
> radiosity{
>      pretrace_start 0.04
>      pretrace_end 0.01
>      count 200
>      recursion_limit 3
>      nearest_count 10
>      error_bound 0.5
> John
That's a rather high quality radiosity setting.
You can get descent results using only radiosity{} to enable radiosity
using the default parameters.
For a test render, it's often enough.
The radiosity defaults are:
radiosity{
pretrace_start 0.08
pretrace_end 0.04
count 35
nearest_count 5
error_bound 1.8
low_error_factor 0.5
minimum_reuse 0.015
recursion_limit 2
normals off
media off
