POV-Ray : Newsgroups : povray.general : povray #read fails with "0" Server Time
4 Mar 2026 10:54:53 EST (-0500)
  povray #read fails with "0" (Message 1 to 10 of 10)
Subject: povray #read fails with "0"
Date: 28 Jan 2014 09:50:01
Message: <web.52e7c2a578523e5b37d25c810@news.povray.org>
I was reading a CSV file successfully until povray ran into the next to  last
line below. (There were dozens of lines before it which were read successfully
as well, dozens after of similar format to the last line. )
-0.126,-2.53681E-06,49668.6783795397
-0.108,-2.14271E-06,50403.4610376579
-0.09,-1.77115E-06,50814.442593795
-0.072,-1.42709E-06,50452.3190548599
-0.054,-1.05761E-06,51058.5187356398
-0.036,-6.98572E-07,51533.7001769324
-0.018,-3.47316E-07,51826.0028331548
0,-1.8643E-09,0
0.018,3.49041E-07,51569.8728802634
Error message,
// "huhnomarks2.csv" line 52: Parse Error: Expected 'float, vector, or string
literal', ,  found instead
//  Render failed"
I'm not at all confident I have the code below in a concise or correct solution
to the problem.  I also have read in some doc or wiki that the CSV file quoted
above is not in the correct format.  Just sad that it got this far and then
bombed.
 #fopen MyFile "huhnomarks2.csv" read
 #debug "got to line  7 \n"
 #declare Vee=array[300]
 #declare I2=array[300]
 #declare I3=array[300]
 #declare I4=array[300]
 #declare n=0;
#while(n<300)
 #declare Vee[n]=0;
 #declare I2[n]=0;
 #declare I3[n]=0;
 #declare I4[n]=0;
 #declare n=n+1;
 #declare JunkText=""
#read(MyFile)
 #read(MyFile)
 #debug "got to line  18 \n"
 //#read(MyFile,JunkText,",")
 #debug "got to line  22 \n"
// #read(MyFile,JunkText,CurveTitle)
   #read (MyFile,Vkeed,Ik2d,Ik3d)
 //#read(MyFile,IsitV,IsitI2,IsitI3,IsitI4)
 #debug "got to line  25 \n"
 #declare n=0;
 #while (defined(MyFile))
   #read (MyFile,Veed,I2d,I3d)
   #declare Vee[n]=Veed;
   #declare I2[n]=I2d;
   #declare I3[n]=I3d;
   #declare n=n+1;
Subject: Re: povray #read fails with "0"
Date: 28 Jan 2014 10:12:15
Message: <52e7c8cf$1@news.povray.org>
> 0,-1.8643E-09,0
> Error message,
> //  Render failed"
I don't use #read very often so I might be wrong but shouldn't there be
commas after all the values even at the end of the lines?
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 28 Jan 2014 11:40:01
Message: <web.52e7dc40cd36004937d25c810@news.povray.org>
> John
Yes, I understand, ideally. Put this CSV is auto-generated by an electrical test
tool and I was hoping to get povray to auto-import the data, if I were to find
the correct povray syntax. The "mouse clicks" to fix the CSV are probably more
than would be required to just use Excel.
I was disappointed however that povray offered no complaint at
yet crashed with seeing
0,-1.8643E-09,0
I was hoping there were a small tweak to my code that could fix all this. (If
not a possible improvement to povray that could be suggested).
But you know, I guess I *do* have the power to just make sure there are no "0"
entries in the CSV. Will try that.
Date: 28 Jan 2014 12:00:00
Message: <web.52e7e16ccd36004937d25c810@news.povray.org>
With even more experimentation, I see that the code fails with the first
transition from negative to non-negative number, and not because of the "0".  It
was successfully reading all the values until then.
Date: 28 Jan 2014 12:48:04
Message: <52e7ed54@news.povray.org>
Am 28.01.2014 15:45, schrieb gregjohn:
> 0,-1.8643E-09,0
Using #read, POV-Ray interprets this as:
   -1.42709E-06, 50452.3190548599 - 0.054,
   -1.05761E-06, 51058.5187356398 - 0.036,
   -6.98572E-07, 51533.7001769324 - 0.018,
   -3.47316E-07, 51826.0028331548   0,
   -1.8643E-09,                 0   0.018,
    3.49041E-07, 51569.8728802634
And yes, it /does/ compute the differences.
To my knowledge you could even use variable names in there, or functions.
Date: 28 Jan 2014 12:54:52
Message: <52e7eeec$1@news.povray.org>
... which is why you need the commas.
John
Protect the Earth
Date: 28 Jan 2014 13:15:00
Message: <web.52e7f334cd36004937d25c810@news.povray.org>
Actually, it goes like this:
Here's a block from my CSV
-0.001,-1.8643E-09,51877.
0.818,3.49041E-07,51569.8728802634
0.036,6.66051E-07,54049.9150965917
0.054,9.48796E-07,56914.236569294
Here's what variable values actually made it into my scene.
 0.0900  -1.7712E-06  50814.4426
 0.0720  -1.4271E-06  50452.3191
 0.0540  -1.0576E-06  51058.5187
 0.0360  -0.6986E-06  51533.7002
 0.0180  -0.3473E-06  51826.0028
 0.0010  -0.0019E-06  51877.0000
"huhnomarks3.csv" line 51: Parse Error: Expected 'float, vector, or string
I still might be attempting, to use a recent friend's analogy, to use a Ferrari
as a snowplow, but the fact that I'm so close that I'm hopeful I could just make
a few more tweaks.
Date: 28 Jan 2014 15:23:03
Message: <52e811a7@news.povray.org>
You can put #declares, #macros and, in general, almost any # commands
in a file you are reading with #read, and those commands will be
processed normally.
Date: 28 Jan 2014 15:25:09
Message: <52e81225@news.povray.org>
POV-Ray will interpret "1 2" as two numbers, but "1 -2" as a subtraction,
resulting in one number. Thus the comma is not *strictly* necessary when
the next number has no binary operator in front of it, but it's
nevertheless a good idea.
This will work the same in normal .pov files as well. (In fact, the exact
same parser is used to interpret .pov files and input files read using
the #read command.)
Date: 28 Jan 2014 17:05:00
Message: <web.52e8295fcd36004937d25c810@news.povray.org>
This is disproven by my example above.
