POV-Ray : Newsgroups : povray.general : Usage of Povray for Raytracing of Radio Wave Propagation Server Time
4 Mar 2026 10:53:54 EST (-0500)
  Usage of Povray for Raytracing of Radio Wave Propagation (Message 1 to 6 of 6)
Subject: Usage of Povray for Raytracing of Radio Wave Propagation
Date: 16 Jan 2014 02:35:00
Message: <web.52d78aecc904bcaff8726d560@news.povray.org>
Hello everyone!
My field of research makes it necessary to build site-specific propagation
models for indoor wireless communication. Unfortunately - to my knowledge - no
open source raytracing engine currently exists.
Would it be possible to use POV-Ray to predict for example signal strength/delay
for an indoor scenario? If not, what would be necessary to achieve this?
Thank you all for your ideas!
Cheers,
Daniel
Subject: Re: Usage of Povray for Raytracing of Radio Wave Propagation
Date: 16 Jan 2014 03:39:14
Message: <52d79ab2@news.povray.org>
Am 16.01.2014 08:31, schrieb pfefferk:
> Hello everyone!
I suspect that at the frequencies involved, the wavelike nature of the
electromagnetic radiation becomes too much of an issue to simulate its
propagation by means of raytracing. If that is the case, then POV-Ray is
a poor starting point for what you're trying to achieve.
Date: 17 Jan 2014 21:13:11
Message: <52d9e337$1@news.povray.org>
>> Hello everyone!
>> propagation
>> knowledge - no
>> strength/delay
In that case, a wave tank simulation could be a better tool.
Another possibility could be some acoustic propagation simulator.
Date: 20 Jan 2014 05:45:00
Message: <web.52dcfd4e69f09249f8726d560@news.povray.org>
> > Hello everyone!
Yes, the wavelengths and therefore effects differ. What I am interested in is
whether POVray was written to support wave-length-based calculations and is
extensible in that direction.
I guess for a start it would be sufficient to ignore the phase information and
work only with magnitude. As the radiated wave passes through a concrete wall
for example, its power is reduced by 7 dB. The sum of power introduced by all
rays at a certain spot equals the simulated received power.
Does anyone know whether or how this could be achieved?
-- Daniel
Date: 20 Jan 2014 09:52:37
Message: <52dd3835$1@news.povray.org>
Not really. There are a few special places where wavelength is
considered (but mostly fake) to emulate refracted color effects.
You could set up the transmitter as a light source and the receiver
you either need to model the light source as a bright emissive sphere
or enclose the camera in a double_illuminate'd sphere. Then overall
brightness of (hdr) image should be a kind of "magnitude".
Walls can be partially transparent to allow some light through.
Depending on whether the energy loss occurs at material boundary
or traversing material you can set a transparent pigment or a
fade_distance in the interior.
Diffuse reflection + radiosity could model indirect paths - this
is probably more appropriate than specular reflection + photons?
Of course the approximation may be poor because the light model
used does not reflect your true wave propagation. Also I must say
I never tried double_illuminate with radiosity, not sure this
actually has an effect there.
Date: 20 Jan 2014 16:29:58
Message: <52dd9556$1@news.povray.org>
Am 20.01.2014 15:52, schrieb Christian Froeschlin:
It does work fine. You may need to increase the recursion limit though.
Still, it leaves the problem that ray tracing, even complemented with
photons and radiosity, can only model linear propagation of
electromagnetic energy, corresponding to a particle model, leaving /any/
effects unaccounted for that arise from the wave-like nature of EM.
Interference is only the most obvious of such effects; a much simpler
one is the ability of long-wavelength radiation to travel around corners.
