POV-Ray : Newsgroups : povray.general : Understanding isosurface, difference between negative and positive Server Time
15 May 2025 11:23:44 EDT (-0400)
  Understanding isosurface, difference between negative and positive (Message 1 to 9 of 9)
Subject: Understanding isosurface, difference between negative and positive
Date: 28 Dec 2013 08:45:00
Message: <web.52bed4f3fa5e84cdcbe7ea7c0@news.povray.org>
After reading some tutorials and viewing examples I thought I understood
isosurfaces, however when trying to create them myself, I run into problems.
I understand that function {(x*x + y*y + z*z - 1)} would create a sphere, but
why doesn't function {(x*x + y*y + z*z + 1)} (plus instead of minus)?
According to my reasoning it should generate exactly the same sphere, using plus
or minus should not make any difference in this formula, it only mirrors the
coordinates which results in the same sphere right?
What am I missing?
Subject: Re: Understanding isosurface, difference between negative and positive
Date: 28 Dec 2013 09:20:20
Message: <52bede24@news.povray.org>
Le 28/12/2013 14:41, Louis nous fit lire :
> What am I missing?
The fact that the whole formula is evaluated to find the frontier of the
shape at the value of threshold (default to 0.0).
So, x*x + y*y + z*z - 1 threshold 0 is identical to x*x + y*y + z*z + 1
threshold 2.
Indeed, the simplest sphere is x*x + y*y + z*z, threshold r*r.
(r being the radius of the sphere).
Date: 28 Dec 2013 09:56:07
Message: <52bee687$1@news.povray.org>
Am 28.12.2013 14:41, schrieb Louis:
> What am I missing?
The isosurface's surface is the set of all points satisfying f(x,y,z)=0.
(That is, unless a different threshold than 0 is specified.)
The set of solutions to the equation
     x^2 + y^2 + z^2 - 1 = 0
is the set of all points having a distance of 1 to the coordinate origin
- in other words, the surface of the unit sphere.
The equation
     x^2 + y^2 + z^2 + 1 = 0
has no solutions at all (in the domain of real numbers, to be precise),
as any number squared is >= 0, so the left side of the equation is
always >= 1.
Date: 28 Dec 2013 10:21:55
Message: <52beec93$1@news.povray.org>
>> What am I missing?
> threshold 2.
I'll add if you are looking for the inverse function, to mirror about
the 0.0 threshold of your first equation, the function would be :
-((x*x + y*y + z*z) - 1)
This will look like your container unless you set up your container
definition to cut across the inverted sphere. Or put your camera and
light inside the inverted sphere. However, the latter will be hard to
see as anything but a background color without noise or patterning on
the isosurface too.
Perhaps as another aid to understanding, I'll throw in that you can
create an isosurface, spherical, shell shape by setting up both your
sphere and inverted sphere function with a small offset then
intersecting the two function's slightly overlapping negative coordinate
spaces with max(). This would look like:
#declare F0     = function (x,y,z) {  ((x*x+y*y+z*z)-1)-0.025 }
#declare F0_inv = function (x,y,z) { -((x*x+y*y+z*z)-1)-0.025 }
#declare F = function (x,y,z) { max(F0(x,y,z),F0_inv(x,y,z)) }
with F as the final isosurface function and the threshold at 0.0.
Bill P.
Date: 28 Dec 2013 11:45:01
Message: <web.52befed0b61b6914cbe7ea7c0@news.povray.org>
> The equation
> always >= 1.
Thanks! that cleared it up! I looked over the fact that squared dimensions are
always positive. Ouch.
Date: 28 Dec 2013 17:24:49
Message: <52bf4fb1@news.povray.org>
We've all done it (or something similar)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 4 Jan 2014 20:30:01
Message: <web.52c8b427b61b6914cbe7ea7c0@news.povray.org>
> John
> Protect the Earth
I must be doing something similar again, I've spent some hours looking, but I
can't spot my error:
// Rotate a position 1 km above earths surface to some coordinate
#declare test=vrotate(<0,0,-6372>, <35.201352,111.639249,0>);
#debug concat("position = <",str(test.x,0,3),
",",str(test.y,0,3),",",str(test.z,0,3), ">\n")
#debug
concat("height=",str(pow(pow(test.x,3)+pow(test.y,3)+pow(test.z,3),(1/3)),0,3),
"\n") // This should be 6372, rotating about the origin <0,0,0>
The result is:
position = <-4839.809,3673.150,1920.052>
height=-1.#IO
I'm not sure why height is printed out like that (-1.#IO), is it trying to use
imaginary numbers? Any way, if I calculate it on a calculator:
cube(4839.809) + cube(3673.15) + cube(1920.052) = 170003198137.853207737
cuberoot(170003198137,853207737) = 5539,6929949498910498665819311567
So how did my altitude get burried down under the earths crust in hot lava? I'd
expect the length of the vector to stay 6372, regardless of how it rotates.
Am I misunderstanding vrotate? When I do:
translate <0,0,-6372>
rotate <35.201352,111.639249,0>
It does end up at the expected location.
The reason I want to use vrotate, is because I want the camera's look_at
position to be at that location (and I can't translate and rotate the look_at
position without translating and rotating the entire camera).
What am I missing?
Date: 5 Jan 2014 01:42:12
Message: <52c8fec4$1@news.povray.org>
Am 05.01.2014 02:23, schrieb Louis:
>> John
>> Protect the Earth
> #debug
> The result is:
> height=-1.#IO
> imaginary numbers?
No; the "-1.#IO" is probably a failed attempt to round either "-1.#INF"
or "-1.#IND" to 3 fractional digits. Printing the height to a precision
of at least 4 fractional digits should give you more information (you
can specify "-1" as the number of fractional digits to let POV-Ray decide).
Note that you're not doing exactly the same thing, as you're dropping
the sign of the first value. As you're raising it to a power of 3, the
sign is kept. Moreover, the sum of all three cubes is also negative.
POV-Ray's implementation of pow() is based on the standard C math
library, which doesn't like raising a negative value to the power of any
non-integer, even if the exponent is the reciprocal of an integer (not
to mention that the binary floating-point representation of 1/3 isn't
exactly 1/3 due to rounding).
No, but you're misunderstanding distance computations in 3D space ;-)
You probably thought that with distance computations in 2D space using
squares and square roots, 3D space would call for cubes and cubic roots,
but this is not the case at all; the proper formula should indeed be:
   #declare length = sqrt(pow(test.x,2)+pow(test.y,2)+pow(test.z,2));
or, even simpler yet (and less prone to errors ;-)):
   #declare length = vlength(test);
Date: 6 Jan 2014 13:40:01
Message: <web.52caf857b61b6914cbe7ea7c0@news.povray.org>
Thanks,
Finally found the error, using coordinates as positions somewhere.
I should have been able to reason squares instead of cubes, guess Pythagoras
used some more time to think about it than I did :-)
Cheers,
Louis
