POV-Ray : Newsgroups : povray.general : Transforming matrix question Server Time
4 Mar 2026 12:41:41 EST (-0500)
  Transforming matrix question (Message 1 to 6 of 6)
Subject: Transforming matrix question
Date: 23 Dec 2013 19:50:00
Message: <web.52b8d924de711b8ccbe7ea7c0@news.povray.org>
I have read the documentation and the excellent tutorial on
http://evilsnack.byethost22.com/matrix.htm but I must admit that I cannot fully
grasp the concept and have great difficulty visualizing or predicting the
effect.
The last mathemagical example in the tutorial (the saddle) showed off a nice
curved shape, and lead me to think that the matrix transform can do some
spline-like transforms, like pinch, barrel and maybe even extruding an object
into a helix-formed shape, but when experimenting I'm getting confusing results.
Could someone provide an example of a cube with the top rotated 90 degrees while
the base stays in it's place? And would it be possible to have the edges have an
S form instead of a straight line using a matrix transform?
I tried using formulas inside the matrix, for example:
matrix <  1,  0.5*(sin(z.z*2*pi)),  0,
            0,  1,  0,
            0,  0,  1,
            0,  0,  0 >
But I never see any curves, while I was expecting to see some wobble in at least
one of the edges. Probably I'm misunderstanding the whole concept?
Subject: Re: Transforming matrix question
Date: 24 Dec 2013 03:58:53
Message: <52b94ccd@news.povray.org>
Transformation matrices only allow for affine transformations. That's
transformations where every straight line in the original object
remains straight after the transformation. (In practice this means
translations, rotations, scalings, and any combination of those.)
Thus no twists are possible.
Date: 24 Dec 2013 17:40:01
Message: <web.52ba0c6d2d7d0efacbe7ea7c0@news.povray.org>
Thanks for clearing that up. I also realized that z.z in my example would be a
constant 1 instead of the z-input into the function. Also, the Saddle example
was using a quadric instead of a cube. It also seems like all parallel lines
will remain parallel, so trapeziums are also impossible to create by
matrix-transforming a cube. The "magic" is slowly disappearing.
Date: 28 Dec 2013 08:30:01
Message: <web.52bed1c22d7d0efacbe7ea7c0@news.povray.org>
"Louis" <nomail@nomail> wrote:
> I also realized that z.z in my example would be a constant 1 instead of the
I'm confused, will z.z be a constant one in this context, or will it be the the
z- input just like in an ISO-surface-function?
Date: 28 Dec 2013 09:48:42
Message: <52bee4ca$1@news.povray.org>
Am 28.12.2013 14:27, schrieb Louis:
Outside functions, "z" is a predefined vector constant evaluating to
<0,0,1>; thus, "z.z" is the z-component of that vector, i.e. 1.
Inside functions without an explicit parameter list, "z" is the third of
three parameters, which in an isosurface object will be the z-coordinate
of whatever point is currently being examined. Note that with function
parameters always being scalars, "z.z" will generate a parse error when
used inside such a function.
Date: 28 Dec 2013 11:45:03
Message: <web.52beff7e2d7d0efacbe7ea7c0@news.povray.org>
Thanks for clearing that up!
