POV-Ray : Newsgroups : povray.general : GtkSourceView 2.0 language file for 3.7 Server Time
17 Aug 2025 19:52:24 EDT (-0400)
  GtkSourceView 2.0 language file for 3.7 (Message 1 to 7 of 7)
Subject: GtkSourceView 2.0 language file for 3.7
Date: 2 Dec 2013 23:30:01
Message: <web.529d5c003b56bacf89b5ac30@news.povray.org>
here: http://pastebin.com/NaCa4MwD
it might be missing a few keywords still.  I modified it  (and did some cleanup)
from one that I've been using for a while so that it correctly identifies .pov
and .inc files and preselects the PoV-Ray 3.7 language file.
If you find any keywords that are missing, let me know and I'll fix it.
--tested in gedit.
I can post a copy of the file in utilities if anyone is interested.
Let me know what you think.
A.D.B.
Subject: Re: GtkSourceView 2.0 language file for 3.7
Date: 3 Dec 2013 05:30:00
Message: <529db2a8$1@news.povray.org>
> --tested in gedit.
> Regards,
> A.D.B.
you must have missed my post dated 01/14/2011 in p.b.utilities "new
syntax highlighting for gedit"
Date: 3 Dec 2013 09:40:00
Message: <web.529debc07b96886e89b5ac30@news.povray.org>
> > --tested in gedit.
> > Regards,
> > A.D.B.
perhaps.  This was a file I had found some time ago, but it was missing the
metadata block, and the <definition></definition> tags, among other things...  I
didn't bother looking for a better version before cleaning it up.
A.D.B.
Date: 3 Dec 2013 14:30:00
Message: <web.529e2fbb7b96886e7a3e03fe0@news.povray.org>
> --tested in gedit.
> Regards,
> A.D.B.
Hi!
I download povray37.lang and replace it in
/usr/share/gtksourceview-2.0/language-specs
Don't work! Gedit, Geany...
Date: 3 Dec 2013 20:20:01
Message: <web.529e831f7b96886e89b5ac30@news.povray.org>
> > --tested in gedit.
> > Regards,
> > A.D.B.
> Hi!
works for me in gedit, using the Cobalt theme.  screenshot in p.b.i
Interesting thing about most gtk themes i've seen:  They all incorrectly define
net-address-in-comment whereas the def:comment identifier uses the "underlined"
style for email and web addresses in comments.  There is no
"def:net-address-in-comment" as far as I can tell.
the fix is to edit your theme before installing it, and change the line that
defines "net-address-in-comment" to define "underlined" instead
A.D.B.
Date: 4 Dec 2013 11:40:01
Message: <web.529f59ce7b96886e7a3e03fe0@news.povray.org>
No! Not work in Gedit.
View/Mode highlight sintax: cannot search povray lang
Date: 4 Dec 2013 19:05:01
Message: <web.529fc2277b96886e89b5ac30@news.povray.org>
And I'm telling you that it does work for me.  It automatically selects POV-Ray
3.7 syntax highlighting whenever I open a .pov or .inc file.
In addition, it appears right where it should under:
    View->Highlight Mode->Sources->POV-Ray 3.7
If it isn't working for you, then I don't know what's wrong.
my language file is in the same place as yours:
    /usr/share/gtksourceview-2.0/language-specs/povray37.lang
however, when I downloaded it from pastebin, it had an extra .txt extension on
it.  If you didn't remove that extension then it probably won't work.
A.D.B.
