POV-Ray : Newsgroups : povray.general : something doesn'w work with concat and str Server Time
15 May 2025 14:59:25 EDT (-0400)
  something doesn'w work with concat and str (Message 1 to 10 of 10)
Subject: something doesn'w work with concat and str
Date: 1 Dec 2013 08:25:01
Message: <web.529b388226be7f8bbb6ddff20@news.povray.org>
// The name of the pics is si101 to si200
  // They are all in the directory Temp3, where also the this fil is.
  // If I render just one pic, all works well
  // but something doesen't work, when I try to render the 100 pics.
  // Strange is, it worked, years ago, with an older pov Version
  // Can someone help me?
camera{   location -z*10.1    look_at  <0,0,0>
light_source{ <20,20,50> rgb <1,1,1> }
 #declare Count = 0;
  #while (Count <= 9)
  #declare X = Count ;
    #declare anzahl = 200-(X*10);
   #declare Bount = 0;
  #while (Bount <=9)
  #declare Y = Bount ;
    #declare name = anzahl -Y ;
   box {<-1,-1,-.001>,<1,1,.001>
     // one pic to render
    //    pigment {image_map {png "Temp3\si100.png"   map_type 0 interpolate 2 }
    pigment {image_map {png concat ("Temp3\si",str(name,0,0),".png")   map_type
0 interpolate 2 }
        scale 2
       translate <1,1,0>      }
           finish {ambient 1 }
          scale <1.333,1,.1>
          scale <.47,.47,.1>
          translate <(4.5*1.333)-Y*1.333,X-4.5,0> }
  background {color rgb <.9,.9,.9>}
 #declare Bount = Bount + 1 ;
 #declare Count = Count + 1 ;
Subject: Re: something doesn'w work with concat and str
Date: 1 Dec 2013 10:14:51
Message: <529b526b$1@news.povray.org>
>   #declare Count = 0;
>    #while (Count <= 9)
>     #declare Bount = 0;
>    #while (Bount <=9)
> 0 interpolate 2 }
>          scale 2
>         translate <1,1,0>      }
>             finish {ambient 1 }
>            scale <1.333,1,.1>
>            scale <.47,.47,.1>
>    #end
>    #end
I think you should try this (double backslash):
       pigment {image_map {png concat ("Temp3\\si",str(name,0,0),".png")
Date: 1 Dec 2013 10:24:18
Message: <529b54a2$1@news.povray.org>
I had to think a bit deeply to find the /why/ of this; it has to do with
the way string literals are interpreted. See the off-line docs section
3.3.1.9.1 String Literals, or in the online wiki:
http://wiki.povray.org/content/Reference:Strings#String_Literals
Date: 1 Dec 2013 15:25:00
Message: <web.529b9a928810de5d89b5ac30@news.povray.org>
> Thomas
This is a natural effect of using escaped characters in strings (special
characters like non-printing characters \t and \n or \b).  One of the dumber
things windows does is use back-slash instead of forward-slash in directory
paths, so you have to escape the backslash "\\" to get it to render properly in
a string.
A.D.B.
Date: 1 Dec 2013 16:23:13
Message: <529ba8c1$1@news.povray.org>
>> Thomas
> a string.
> Regards,
> A.D.B.
It seems that it's not well known, but Windows _does_ accept forward slashes in path
strings,
when they come from a program.  It's the Windows command processor that only accepts
the back
slashes -- that is, when you are typing a command directly in Windows.
When the string comes from a program and not directly from the keyboard, the command
processor
is bypassed, and both forms are accepted.  Definitely saves the headaches of trying to
remember
to double the backslashes in path strings in a source-code file.
      -=- Larry -=-
Date: 1 Dec 2013 17:53:31
Message: <529bbdeb@news.povray.org>
Am 01.12.2013 22:23, schrieb Larry Hudson:
> slashes in path strings, when they come from a program.  It's the
> Windows command processor that only accepts the back slashes -- that is,
Better yet: Even the command processor (cmd.exe) is perfectly fine with
forward slashes.
Date: 2 Dec 2013 02:14:57
Message: <529c3371@news.povray.org>
> Better yet: Even the command processor (cmd.exe) is perfectly fine with forward
slashes.
 From my memory, it used to be that it did not.  But perhaps that was command.com in
DOS.  I
have to confess I haven't checked this myself recently -- I currently use Linux only
and rarely
use Windows.  But since I believe most people aren't aware of it, I did want to point
out that
forward slashes are acceptable (and more convenient) in Windows.  Thanx for the
updated info.
      -=- Larry
Date: 2 Dec 2013 14:30:18
Message: <529cdfca$1@news.povray.org>
> forward slashes.
I'm not sure it works for all commands ... also for example
auto-completion does not seem to work if you type
cd aaa/b
and then hit tab to complete the name of directory bbb (Windows 7 x64).
Date: 2 Dec 2013 15:33:55
Message: <529ceeb3$1@news.povray.org>
>> Thomas
> a string.
> Regards,
> A.D.B.
And windows use the back-slash because DOS 1.0, that did not support
folders, used the slash as an option prefix while using a + or - would
have been beter.
Remember dir /w...
dir -w or dir +w would have been preferable.
Date: 2 Dec 2013 16:01:04
Message: <529cf510@news.povray.org>
Am 02.12.2013 20:30, schrieb Christian Froeschlin:
>> with forward slashes.
> cd aaa/b
Worked fine here when I tried.
