POV-Ray : Newsgroups : povray.general : transparency per thickness Server Time
4 Mar 2026 14:24:45 EST (-0500)
  transparency per thickness (Message 1 to 7 of 7)
Subject: transparency per thickness
Date: 21 Aug 2013 18:25:01
Message: <web.52153dd15f9de86e831975e00@news.povray.org>
how about making pigment transparency dynamic based on the distance the ray
travels through the object, or are fogs intended for this function?
Subject: Re: transparency per thickness
Date: 21 Aug 2013 18:48:48
Message: <521543cf@news.povray.org>
Use fade_power, fade_distance and fade_color in the 'interior' block of
the object.
Date: 22 Aug 2013 17:08:12
Message: <52167dbc$1@news.povray.org>
The easiest way, and fastest to render, is to use fading (fade_distance,
fade_power and fade_color) as Warp stated.
This will not realy obscure what is behind the object, just tint it.
You can also fill the object with some scattering media. It will
significantly increase the render time, but will allow you to have
non-uniform absorbtion. To enable an object to contain media, you need
to add "hollow" to that object.
Date: 25 Aug 2013 08:28:13
Message: <5219f85d$1@news.povray.org>
This has always struck me as somewhat strange. I think it would
be reasonable to have container objects (those that actually specify
use of media in their own interior) hollow by default.
Date: 2 Sep 2013 07:40:01
Message: <web.522477f6eb6ccbd3b5de64d0@news.povray.org>
It sounds easy to use...
I didn't use these features.
Date: 2 Sep 2013 13:04:15
Message: <5224c50f$1@news.povray.org>
Easy to use, yes.
Be warned that if you scale an object using those features it's aspect
WILL change as the distance a ray travel through the object will change.
For the media, it's the fine tuning that can be tricky.
The defaults for media are:
sampling method: 3 (adaptive sampling)
intervals: 1 (MUST be kept at that value, larger values hugely increase
the rendering time)
samples: 10 (must be at least 3 for the adaptive feature to work)
samples use ONLY 1 value (the two values syntax is for sampling method 1
and 2). If a second value is provided, it will be silently ignored.
Date: 4 Sep 2013 11:00:02
Message: <web.52274a53eb6ccbd3cfff61040@news.povray.org>
> Easy to use, yes.
> the rendering time)
Uh...thanks for this old hand response. I am just fascinate with POV-Ray for
some time, and can study it a while.
