"Bald Eagle" <cre### [at] netscape net> wrote:
> > You can create splines using Inkscape. I also have a set of LOGO turtle macros
> > that can be used to create splines...
> I like it. How do I take the points from the path generated by Trace Bitmap and
> import those coordinates into POV-Ray?
I'm not sure. I've never used it myself, but if you can export as either an svg
file or rawtext, you can copy the points directly using a text editor.
> LOGO. I wouldn't have thought of that. I like the simple stuff.
> Does it work well?
I created them so I could do some experiments with 2D fractals; Things like Koch
flakes and Gosper islands. I've included a DUMP() macro which takes a single
argument that will dump the contents of the lSpline array to a file as a natural
spline.
before using any of the other macros you need to call Init() - this sets up the
environment variables for the "turtle". Calling Init() again will reset the
environment, so you can construct multiple splines in one file.
the fd() and
The logo_prism object is, as the name suggests, a prism made from the lSpline
array.
points are only appended to lSpline if _Draw_ = true, you can use pu() and pd()
to set that. (This is handy for making complex splines)
I haven't played with these in a while, so they're a bit rough around the edges.
Feel free to tinker with the code.
I hope you find them useful.
A.D.B.
#include "kolors.inc"
#include "math.inc"
#include "arrays.inc"
#macro init()
#ifdef(logo_prism)
#undef(logo_prism)
#declare _cP_ = <0.0, 0.0, 0.0>;
#declare _cD_ = 0;
#declare _DRAW_ = true;
#declare _MAX_SIZE_ = 100000000;
#declare _SPLINE_SIZE_ = 0;
#declare lSpline = array[1] {<0,0>};
// Pen Up
#macro pu()
#declare _DRAW_ = false;
// Pen Down
#macro pd()
// left turn (degrees)
#macro lt(d)
#declare _cD_ = _cD_ + d;
#if(_cD_ > 360)
#declare _cD_ = _cD_ - 360;
// right turn (degrees)
#macro rt(d)
#declare _cD_ = _cD_ - d;
#if(_cD_ < -360)
#declare _cD_ = _cD_ + 360;
// foreward (length)
#macro fd(l)
#local _pL_ = _cP_;
#declare _cP_ = _cP_ + l*<cosd(_cD_), sind(_cD_), 0>;
#if(_DRAW_)
// cylinder { _pL_, _cP_, 0.015625 pigment {Orange}
// finish { ambient 0.6 diffuse 0.3 } }
#if(_SPLINE_SIZE_ = 0)
#declare lSpline[0] = <_pL_.x,_pL_.y>;
// #debug concat("adding " vstr(2,_cP_,", ",0 ,4) " to lSpline\n")
#else
Resize_Array(lSpline, _SPLINE_SIZE_ + 1)
#declare lSpline[_SPLINE_SIZE_] = <_cP_.x,_cP_.y>;
#declare _SPLINE_SIZE_ = _SPLINE_SIZE_ + 1;
// #debug concat("current point = " vstr(2,lSpline[_SPLINE_SIZE_-1],",
",0 ,4) "\n")
// #debug concat("moving to: " vstr(2,_cP_,", ",0 ,4) "\n")
#macro DUMP(fName)
#local OPEN = concat("spline {\nnatural_spline\n", str(_SPLINE_SIZE_,0,0), "\n")
#local CLOSE = "\n}\n";
#fopen DUMP_FILE fName write
#write(DUMP_FILE, OPEN)
#local j = 0;
#while(j < _SPLINE_SIZE_)
#local OUTPUT = concat(str(j/_SPLINE_SIZE_,0,4)", <"str(lSpline[j].u,0,4)
", " str(lSpline[j].v,0,4) ">\n")
#write(DUMP_FILE, OUTPUT)
// #debug OUTPUT
#local j = j + 1;
#write(DUMP_FILE, CLOSE)
#fclose DUMP_FILE
#macro PRISM(i, f)
#declare logo_prism =
prism {
linear_sweep
linear_spline
i, f, _SPLINE_SIZE_
#local c = 0;
#while(c < _SPLINE_SIZE_)
<lSpline[c].u, lSpline[c].v>
#local c = c + 1;
