POV-Ray : Newsgroups : povray.general : Help importing mesh object Server Time
4 Mar 2026 14:23:46 EST (-0500)
  Help importing mesh object (Message 1 to 10 of 12)
Subject: Help importing mesh object
Date: 5 Aug 2013 15:40:01
Message: <web.51fffefabcdfc83ca39fc0eb0@news.povray.org>
I downloaded this:
and after using stl2pov -s filename > Leg.inc
and including it in a basic scene file as object {Leg rotate x*90}
I get:
Parse Error: Expected '>', undeclared identifier 'IND' found instead
There are a bunch of coordinates listed as -1.#IND
How do I fix this?  How best to interpolate what the actual value should be?
Thanks.
Subject: Re: Help importing mesh object
Date: 5 Aug 2013 15:55:01
Message: <web.520001f182eeb814e47766f0@news.povray.org>
> I downloaded this:
> I get:
> Thanks.
I have not done it to the far end. But import it whith Blender (seems to work
since I see some bones) and than export it to OBJ, convert it with PoseRay to
POV. That should work.
Best regards,
Michael
Date: 5 Aug 2013 16:01:00
Message: <5200047c@news.povray.org>
Am 05.08.2013 21:37, schrieb Bald Eagle:
> I downloaded this:
> I get:
Sounds like the mesh is malformed in some way or another, and stl2pov
fails to properly handle the problem.
You might try some mesh cleanup tool. AFAIK PoseRay has a few tricks up
its sleeves.
Date: 5 Aug 2013 16:05:00
Message: <web.5200051882eeb81a39fc0eb0@news.povray.org>
OMG.
Okay, I'll try that.
My poor little laptop is gonna get a workout!
Thanks, Mike!
Date: 5 Aug 2013 17:35:00
Message: <web.52001a0f82eeb81a39fc0eb0@news.povray.org>
Wicked cool!
Is there a way to declare each individual piece as its own mesh object?
Even if I need to just remodel some of it into simplified CSG primitives, I can
get a lot of work done on this.  In the meantime I will be reading and learning.
Date: 6 Aug 2013 06:28:06
Message: <5200cfb6$1@news.povray.org>
> I downloaded this:
> I get:
There are several bugs in stl2pov, a long time ago I fixed them and
informed the author, but no reply. Since then I wrote my own converter
slp2pov as my CAD software can export both (and slp seemed easier to parse).
Date: 6 Aug 2013 09:20:01
Message: <web.5200f72882eeb81a39fc0eb0@news.povray.org>
Super.
I now have:
Blobman
MakeHuman
POV-Person
Blender
NetFabb
Moray
POV-Ray
.... and who knows what else is lurking in the download folder...
What should I use to easily and quickly separate unattached parts of a large
mesh file into individual mesh components so that I can apply transforms?
Is there a short processing script or is everything GUI?
Can I do CSG on mesh objects?
For example, take a mesh sphere and intersect it with a thin box to get a flat
disk / coin / cylinder?
Thanks
Date: 6 Aug 2013 11:05:23
Message: <520110b3$1@news.povray.org>
On 06/08/2013 14:16, Bald Eagle wrote:
> Super.
> I now have:
> Blobman
> MakeHuman
> POV-Person
> Blender
> NetFabb
> Moray
> POV-Ray
Blender should be able to do it.
Sorry I don't use Blender much, but in theory you should be able to
write a script to separate a mesh into its individual disconnected
parts. Or of course you can do it manually.
OOC where are you getting the STL files from? There might be an easier
or shorter route to get the mesh data into POV in a more useful format.
Yes. You just need to define an "inside_vector" for each mesh, look in
the help for more info.
Date: 6 Aug 2013 11:25:01
Message: <web.5201148f82eeb814876e1cb0@news.povray.org>
> > Super.
> > I now have:
> > Blobman
> > MakeHuman
> > POV-Person
> > Blender
> > NetFabb
> > Moray
> > POV-Ray
Blender should be able to do it. I'm using Wings3D for this (may be in your
download folder...). Your object consists only of one group, which makes it a
bit difficult. I just played with Wings and the OBJ created by Blender. All
bones seems be single meshes but not grouped in the OBJ. With Wings you can
select a face of one bone, hit + as long as no furhter faces will be added and
use "export selected" to export the seperated part. Better save your work with a
new name, delete the exported bone and do the same with the next one. It's a bit
handy work, since they are some bones there.
Best regards,
Michael
Date: 6 Aug 2013 13:01:56
Message: <52012c04$1@news.povray.org>
On 06/08/2013 2:16 PM, Bald Eagle wrote:
> ..... and who knows what else is lurking in the download folder...
There is also Bishop3D, a PovRay modeller similar to Moray. But with the
added advantage that it can import PovRay POV and INC files and you can
work on them in Bishop3D. Unfortunately the developer has gone AWOL so
there are no updates or support. It is not free and costs USD 44 from an
automated script/site. If you decide to give it a try, I can help
support as can StephenS.
Regards
