POV-Ray : Newsgroups : povray.general : 3.2.1.6.5 in docs--clarification needed Server Time
15 May 2025 22:34:37 EDT (-0400)
  3.2.1.6.5 in docs--clarification needed (Message 1 to 10 of 24)
Subject: 3.2.1.6.5 in docs--clarification needed
Date: 27 Feb 2013 04:40:01
Message: <web.512dd32aaffa69f8c2d977c20@news.povray.org>
I've been using functions in POV-Ray for years now (successfully)--pigment
functions, functions for isosurfaces, etc. Yet I've never been able to make
sense of the examples given in the docs at 3.2.1.6.5  "Declaring User-Defined
Color Functions". It's not the set-up of the functions themselves that are
mysterious, but the examples of their use.
Here are the two code lines given there:
#declare Vec = foo(1,2,3)
and
#declare Val = foo(2,3,4).gray
What do the values (1,2,3) and (2,3,4) represent? There's no explanation given,
and I can't figure it out intuitively. (Is it simply a shorthand way of saying
(1*x,2*y,3*z)?) I've read and re-read the sections preceding this one, yet still
don't have a clue.
Subject: Re: 3.2.1.6.5 in docs--clarification needed
Date: 27 Feb 2013 07:39:50
Message: <512dfe96$1@news.povray.org>
On 27-2-2013 10:34, Kenneth wrote:
> 3.2.1.6.5  "Declaring User-Defined Color Functions".
A bit difficult to find ;-)
in the 3.7 RC7 offline Docs: 3.3.1.8.5
in the online wiki Docs: 2.3.1.8.5
That said, I have been a bit confused too. I suppose the numbers stand
for the x,y,z parameters of the function.
Date: 27 Feb 2013 09:43:10
Message: <512e1b7e@news.povray.org>
That's where I find them as well, so I don't know where Ken got his
annotation ... perhaps 3.6 but hey that's ancient history right? It's
usually more meaningful to say ... e.g: in the Reference 3.1.8.5
As far as the content at Reference 3.1.8.5 ... user defined functions is
an advanced technique. If you've gotten that far there does seem to be a
build in assumption ... not that big of a leap IMHO.
Date: 27 Feb 2013 10:05:01
Message: <web.512e207def3a5b5981c811d20@news.povray.org>
In the 3.7 RC6 help file that opens up for me it is section 3.2.1.6.5
I suppose I should be installing RC7.
For what it does:
#declare Vec = foo(1,2,3) returns the rgb value at the (x,y,z) coordinate
(1,2,3)
#declare Val = foo(2,3,4).gray does the same thing, but then converts it to a
single gray value based on rgb->grey conversion formula.
-tgq
Date: 27 Feb 2013 10:07:08
Message: <512e211c$1@news.povray.org>
As for me, I have not gotten that far myself.  ;-)
Date: 27 Feb 2013 11:14:10
Message: <512e30d2@news.povray.org>
> and
They mean whatever the function wants them to mean. The function
constructs the vector from those values.
Date: 27 Feb 2013 12:43:19
Message: <512e45b7$1@news.povray.org>
apologies Ken ... history but not so ancient ;-)
Date: 27 Feb 2013 12:51:14
Message: <512e4792$1@news.povray.org>
Oh and if you guys haven't already noticed the Reference has undergone a
bit of a re-organization
Date: 27 Feb 2013 13:55:02
Message: <web.512e5673ef3a5b5981c811d20@news.povray.org>
Is there a reason for the reorganization?  Usually reference standards try to
preserve their organization and clause numbering where possible to maintain
continuity.  Certainly people using the newest version can use the new reference
and be followed, however, if people are reading back at old postings on various
topics, it can cause some confusion.
-tgq
Date: 27 Feb 2013 14:07:20
Message: <512e5968$1@news.povray.org>
>> and
Do you mean that you could write:
#declare Vec = foo(A,B,C)
#declare Val = foo(X,Y,Z).gray
or
#declare Val = foo(1,2,3).gray
even
And that would the same as writing:
Regards
