POV-Ray : Newsgroups : povray.general : Vector comparison Server Time
4 Mar 2026 17:34:08 EST (-0500)
  Vector comparison (Message 1 to 9 of 9)
Subject: Vector comparison
Date: 27 Dec 2012 13:30:01
Message: <web.50dc9273db110770f192a6e30@news.povray.org>
Well, i try to change color with  vector's comparison. Subtraction , or equal
can't give a result to change color.
And  substraction (Pos_-Pos_compare) can't be recognize. I want to change color
when the two vectors are the same, in substraction equal to 0 ,=0.
I use trace() for one vector.
#declare PointA = VEq(Pos_,Pos_compare);
sphere{Pos_,.25
 #if (0=PointA)
 pigment{White}
#else
 pigment{Gray30}  #end }
Thanks so
Subject: Re: Vector comparison
Date: 27 Dec 2012 14:05:08
Message: <50dc9be4$1@news.povray.org>
Le 27/12/2012 19:28, Albun nous fit lire :
Caveat: 3D vectors are using floating point arithmetic, strict equality
is unlikely to occurs due to noise on floating point operations. (e.g. :
A=<2,4,5>/10; B=<2,4,5>/20; C=B+B+B; D=A+B; ... does D == C ? not sure!)
I would recommend computing the square length of the difference, and
testing it for "small enough" (not =0).
#declare DeltaLenSquared = vdot((Pos_ - Pos_compare),(Pos_ - Pos_compare));
#if (DeltaLenSquared < 0.01)
If you want slower (due to a square root):
#declare DeltaLen = vlength(Pos_ - Pos_compare);
#if (DeltaLen < 0.1)
> sphere{Pos_,.25
>  #if (0=PointA)
>  pigment{White}
> #else
> Thanks so
Date: 28 Dec 2012 03:40:47
Message: <50dd5b0f@news.povray.org>
I think that povray already does that.
Date: 28 Dec 2012 06:00:01
Message: <web.50dd7a9b64cb6c105749dd3d0@news.povray.org>
So, for good result i find the 'near zero value', .25 and .5, not less. I think
it's a gremlin's fake who make noise on floating point operations...
#if (DeltaLenSquared < 0.25)
#if (DeltaLen < 0.5)
Thanks a lot
Date: 30 Dec 2012 01:20:08
Message: <web.50dfdbdb64cb6c10c2d977c20@news.povray.org>
That's something fundamental that I didn't know. But I just always assumed that
POV-Ray took care of the floating-point discrepancy internally (as Warp
indicates), i.e. safely truncating the errors in some way. Put a different way:
I haven't *noticed* any oddities in my scenes.
Using an even simpler case:  something like #if(1/1 = 1) would cause havoc if it
was only 'statistically' TRUE due to floating-point errors. *Hopefully* that's
not the situation! :-O
It raises a question in my mind, though: Given a particular math equation on an
unchanging set of values, are the floating point errors always the same? As in,
frame-by-frame animation?
Date: 30 Dec 2012 01:30:07
Message: <web.50dfdf4064cb6c10c2d977c20@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> Using an even simpler case:  something like #if(1/1 = 1) ...
Actually, a more appropriate example might(?) be #if(pi/pi = 1)
Date: 30 Dec 2012 12:30:01
Message: <web.50e0790a64cb6c10bfeb9b920@news.povray.org>
Due to that thing, a constant appear in my 'near-by after sequence' and resolve
the problem.
Date: 2 Jan 2013 04:02:43
Message: <50e3f7b3@news.povray.org>
Am 30.12.2012 07:14, schrieb Kenneth:
Depends.
The floating point errors are deterministic, so with one and the same
POV-Ray build they are always the same from frame to frame.
However, they may differ between builds, depending on floating point
compiler settings; for instance, the old x87 instruction set allows for
either 64-bit or 80-bit interim results, while SSE2 always uses 64-bit;
and depending on optimization settings, very small numbers may or may
not be truncated to zero. So if you split up an animation on a
heterogenous render farm, results may differ between frames. (This is
true for both SDL math and the actual render math.)
Date: 2 Jan 2013 21:25:03
Message: <web.50e4eae964cb6c10c2d977c20@news.povray.org>
Yeah, after my post, I dimly recalled that this topic was discussed long ago; I
should have remembered this fact.
> compiler settings... So if you split up an animation on a
I would imagine that huge render farms (hundreds to thousands of machines, as in
the professional CGI effect companies) would have to be strenuously maintained
to have the same builds etc., across the board, if only to minimize or eliminate
this very situation.
