POV-Ray : Newsgroups : povray.general : Rendering multiple images into a single file Server Time
18 Aug 2025 06:12:13 EDT (-0400)
  Rendering multiple images into a single file (Message 1 to 8 of 8)
Subject: Rendering multiple images into a single file
Date: 14 Dec 2012 11:45:00
Message: <web.50cb56636510d5b3fbb940860@news.povray.org>
I have 3 different *.pov files to render. I can render all of them successfully
in the way that I want so there is no problem with that. However, rendering them
individually obviously produces 3 different *.png files. I'd like to have a
single output file (doesn't necessarily have to be *png) with the rendered
images stacked on top of each other, perhaps with simple solid bars between
them. Is there a good way to to do this in POVRAY itself, or am I better off
taking the individual images into GIMP to produce the composite figure?
Thanks,
Brad
Subject: Re: Rendering multiple images into a single file
Date: 14 Dec 2012 13:36:02
Message: <50cb7192$1@news.povray.org>
Am 14.12.2012 17:40, schrieb Brad:
> Hi,
You could use a fourth POV-Ray scene, using an orthographic camera, and
applying the other image files as textures.
Date: 15 Dec 2012 17:45:00
Message: <web.50ccfc7a13a38afa85de7b680@news.povray.org>
This is how I usually do it.  (N.B. This is much easier in POV-Ray 3.7 than in
previous versions, due to 3.7's image map gamma handling.)
However, sometimes I whip up an HTML document to display the images, then take a
screen capture.
Date: 16 Dec 2012 08:20:02
Message: <web.50cdca6c13a38afab87c24580@news.povray.org>
Thanks to both of you for your response. This sounds like it might work. Do you
know of any simple examples online for me to see how this is done exactly?
Thanks,
Brad
Date: 16 Dec 2012 09:40:51
Message: <50cddd73$1@news.povray.org>
There is a scene called Mydesk.pov in the directory
POV-Ray\v3.7\scenes\advanced
That will show you how it is done. It is not exactly what you want but
the principle is similar. This scene creates an image of a desk then
puts that image back into the scene as a photograph. If you run the
animation a couple of times the the photograph gets recursive with the
photograph showing an image of the room with the photograph showing an
image of the image of the image...
Regards
Date: 16 Dec 2012 09:45:16
Message: <50cdde7c$1@news.povray.org>
Ooops! It is called desk.pov & desk.ini.
The Mydesk was me experimenting. :-)
Regards
Date: 16 Dec 2012 21:05:01
Message: <web.50ce7c4e13a38afa85de7b680@news.povray.org>
Play with these scene files.  First render brad_source.pov with the given
command line arguments to generate the individual images, then render
brad_montage.pov to compile them.
______________________________________________________________________
//brad_source.pov
//+a +w200 +h150 +kff3 +fn
#include "shapes.inc"
camera { location <0.3, 0.3, -7> look_at 0 angle 30 }
light_source { <-1, 1, -1> * 1000, rgb 1 parallel point_at 0 }
sky_sphere
{ pigment
  { gradient y color_map
    { [0 rgb <0.6, 0.7, 0.9>]
      [1 rgb <0.2, 0.3, 0.6>]
plane
{ y, -1
  pigment { checker rgb <0, 0.4, 0.1> rgb <1, 0.75, 0> }
object
{ #switch (frame_number)
    #case (3) Round_Cone_Union (-y, 1, y, 0.15, 0.15) #break
    #case (2) Round_Cylinder_Union (-y, y, 1, 0.2) #break
    #else sphere { 0, 1 }
  pigment { rgb <0.61, 0.61, 0.64> }
  finish
  { reflection { 0.9 metallic }
    diffuse 0.06
    ambient rgb 0.01
    brilliance 3
    specular 1000 metallic
    roughness 0.0001
//brad_montage.pov
//+w220 +h490 -a
camera
{ orthographic
  location <100, 235, -1>
  right 220 * x
  up 490 * y
background { rgb <0.2, 0.02, 0> }
#default
{ finish
  { diffuse 0
    #if (version < 3.7)
      ambient 1
    #else
      ambient 0
      emission 1
box
{ 0, 1
  pigment { image_map { png "brad_source1" } }
  scale <200, 150, 1>
  translate 320 * y
box
{ 0, 1
  pigment { image_map { png "brad_source2" } }
  scale <200, 150, 1>
  translate 160 * y
box
{ 0, 1
  pigment { image_map { png "brad_source3" } }
  scale <200, 150, 1>
Date: 17 Dec 2012 12:25:00
Message: <web.50cf545513a38afafbb940860@news.povray.org>
Very cool, this worked for me. Thanks so much for the simple example. I'll play
around with it to see if I can get the final look I'm going for.
Also, Stephen, thanks for the desk example. I'll check that out as well -- it
sounds pretty neat.
Best,
Brad
> //brad_source.pov
> sky_sphere
> { pigment
> plane
> { y, -1
> object
>   #end
>   finish
>     diffuse 0.06
>     ambient rgb 0.01
>     brilliance 3
>     roughness 0.0001
> //brad_montage.pov
> //+w220 +h490 -a
> camera
> { orthographic
>   right 220 * x
>   up 490 * y
> #default
> { finish
>   { diffuse 0
>     #if (version < 3.7)
>       ambient 1
>     #else
>       ambient 0
>       emission 1
>     #end
> box
> { 0, 1
>   scale <200, 150, 1>
>   translate 320 * y
> box
> { 0, 1
>   scale <200, 150, 1>
>   translate 160 * y
> box
> { 0, 1
>   scale <200, 150, 1>
