POV-Ray : Newsgroups : povray.general : Weird image Server Time
4 Mar 2026 19:09:08 EST (-0500)
  Weird image (Message 1 to 10 of 11)
Subject: Weird image
Date: 24 Jul 2012 08:55:00
Message: <web.500e9a44683389ef7f523b7e0@news.povray.org>
Hey guys!  I'm getting a puzzling image from POV-Ray and I thought you guys
might be able to help:
When I render the following POV-Ray source file, I get parts of the inner cube
which are semi-transparent.  I don't think that should be happening.  Take a
look:
#version 3.6;
global_settings {
  max_trace_level 256
  ambient_light White
  assumed_gamma 1.0
  location <10,0,0>
  look_at <0,0,0>
  //rotate <0,0,-clock*90>
light_source {
  <1000,1000,0>
  color White
plane {
  y, -10
  pigment { hexagon Green, White, Blue }
box {
  <-0.99,-0.99,-0.99>,<0.99,0.99,0.99>
    checker Red, Yellow
difference {
  box { <-1.3,-1.3,-1.3>,<1.3,1.3,1.3> }
  box { -1,1 }
    transmit 1
  finish {
    ambient 0
    diffuse 0
    conserve_energy
    reflection {
      1.0
      fresnel on
    specular 0
    roughness 0.001
  interior {
    ior 1.5
The ior of the covering box is 1.5, which is that of glass if I'm not mistaken.
So why is there transparency of the inner cube?
Sincerely,
Chaanakya
Subject: Re: Weird image
Date: 24 Jul 2012 16:05:01
Message: <web.500eff56df11dff27f523b7e0@news.povray.org>
> look:
> #version 3.6;
> global_settings {
>   max_trace_level 256
>   ambient_light White
>   assumed_gamma 1.0
> camera {
>   location <10,0,0>
>   look_at <0,0,0>
> light_source {
>   <1000,1000,0>
>   color White
> plane {
>   y, -10
> box {
>   pigment {
>     checker Red, Yellow
> difference {
>   box { -1,1 }
>   pigment {
>     transmit 1
>   finish {
>     ambient 0
>     diffuse 0
>     conserve_energy
>     reflection {
>       1.0
>       fresnel on
>     specular 0
>     roughness 0.001
>   interior {
>     ior 1.5
> Sincerely,
> Chaanakya
My main issue is the transparency of the solid box when the outer box has an IOR
of 1.5 - the solid box should not be even slightly transparent!  Is there
something I'm doing wrong?  Is this a bug?
- Chaanakya
Date: 24 Jul 2012 17:22:31
Message: <500f1217$1@news.povray.org>
Am 24.07.2012 22:02, schrieb Chaanakya:
The inner box isn't transparent - it just looks like that because the
outer box reflects the pattern of the ground.
Rotate the ground plane by y*15 (for instance) to see what I mean.
Date: 24 Jul 2012 18:50:00
Message: <web.500f2580df11dff23eebe80d0@news.povray.org>
Okay.  That makes sense.  But shouldn't the image change if I give it an IOR of
-1.5 (instead of 1.5)?  There's no change in the image.
Thanks for your help!
- Chaanakya
Date: 24 Jul 2012 21:30:50
Message: <500f4c4a$1@news.povray.org>
> - Chaanakya
An ior of -1.5! I've tested with negative ior and it gives me a perfect
mirror. You are beter to use finish{reflection 1}
This makes sence since the ior is the ratio between the speed of light
in vacuum and it's speed inside the material.
Inside_Light_Speed = c/ior.
A negative ratio means that the direction of the light is reversed.
With an ior of zero, the result is undefined: Divide by zero.
In your sample, you use reflection{1.0 fresnel} (a prefect mirror! )
whitch is equivalent to reflection 1. Note the single reflection value.
As you also have conserve_energy, the 100% reflection means that you
have 0% transmition. In this case, fresnel have no effect, and the ior
is useless.
To get a correct result, you should use:
finish{reflection{0, 1 fresnel}conserve_energy}
interior{ior Your_ior}
Date: 24 Jul 2012 22:45:00
Message: <web.500f5ce6df11dff23eebe80d0@news.povray.org>
> > - Chaanakya
> is useless.
> Alain
I was told in this thread
(http://news.povray.org/povray.unix/thread/<web.500560817fd5a6c37f523b7e0@news.povray.org>/)
that I should be fine using
pigment { transmit 1 }
finish { reflection { 1 fresnel on } conserve_energy }
interior { ior -1.5 }
as conserve_energy would ensure that the correct amount of light was
transmitted/reflected.
Also, I was told (and the same message is in the docs) that reflection { 1 } is
the same as reflection { 0,1 } because by default it assumes reflection { 0,n }
where n is the float you give it.
Thanks!
- Chaanakya
Date: 25 Jul 2012 03:21:14
Message: <500f9e6a@news.povray.org>
Am 25.07.2012 03:30, schrieb Alain:
When the "fresnel" keyword is used, a single reflection value is always
taken to mean "0, X".
Date: 25 Jul 2012 03:24:03
Message: <500f9f13$1@news.povray.org>
Am 25.07.2012 04:41, schrieb Chaanakya:
There was never a mention of negative ior :-P
Date: 25 Jul 2012 03:33:48
Message: <500fa15c$1@news.povray.org>
Am 25.07.2012 00:45, schrieb Chaanakya:
There is, if you pay close attention. For instance, the total internal
reflections are gone.
That said, as has been mentioned before a non-positive IOR is physically
nonsense. (Metals have a complex IOR, but that's an entirely different
story.)
Try something like 1.0, 0.5 or 2.34567.
Date: 25 Jul 2012 08:30:01
Message: <web.500fe622df11dff27f523b7e0@news.povray.org>
> story.)
No natural materials have a negative index of refraction, but metamaterials do -
https://en.wikipedia.org/wiki/Negative_index_metamaterials
Hmmm...I see what you mean.  Okay, so essentially there's no transparency, the
image is just being reflected.  Thanks for clearing that up!
