I know this has been talked about numerous times and I have found the following
example...
camera { location <-1.5,4.5,-10> look_at 0 angle 35 }
light_source { <10, 40, -50>, 1 }
plane { y, -2 pigment { checker rgb 1, rgb .5 } }
cylinder
{ -y*2, y*2, 2
pigment
{ object
{ text { ttf "timrom.ttf", "POV-Ray", 2.1, 0 scale <.1,2,1> }
pigment { rgb <1,.9,.8> }
pigment { rgb <.8,.4,.1> }
warp { cylindrical }
rotate y*160
finish { specular 1 }
....which works nice except I want the text to be rotated 90 degrees. Can this
be done or do I have to wrap an imagemap?
Am 09.07.2012 16:09, schrieb joe:
> example...
> .....which works nice except I want the text to be rotated 90 degrees. Can this
Simply rotate the text object you're using in the object pigment. (As
this may move the object out of the space that's visible when wrapping,
you may need to also apply an additional translation to fix it.)
> > example...
Ok... thanks. I was having a rough time finding the text after rotation. I'll
keep playing.
> keep playing.
Try it this way:
#include "shapes.inc"
pigment
{ object
{ object
{ Center_Object (text { ttf "timrom.ttf", "POV-Ray", 2.1, 0 }, x+y+z)
scale <.1,2,1>
rotate <whatever>
rotate y*160
