POV-Ray : Newsgroups : povray.general : Spanish Patio -Parse Error Server Time
18 Aug 2025 10:17:30 EDT (-0400)
  Spanish Patio -Parse Error (Message 1 to 7 of 7)
Subject: Spanish Patio -Parse Error
Date: 22 May 2012 05:50:00
Message: <web.4fbb602e76b4f9d2149d439b0@news.povray.org>
I am trying to render the following scene:
http://www.ignorancia.org/en/index.php?page=Patio
using MegaPOV (I cannot use PovRay on Mac).
I already included all the necessary additional files: LightsysIV.
However, when I am rendering the scene I get the following parse error:
File: .../Spanish Patio/patio/meshlath.inc  Line: 33
File Context (5 lines):
// horner's rule
#macro Horner(T,row,point
Parse Error: Expected 'identifier or expression.', point found instead
I have not changed anything in the file provided by Ignoracia, so I do not see
what I am doing wrong.
Any help is welcome.
Subject: Re: Spanish Patio -Parse Error
Date: 22 May 2012 06:25:01
Message: <web.4fbb68b7c245da6f149d439b0@news.povray.org>
> // horner's rule
I also get the following error:
File: TOMLEAF.inc  Line: 5
Possible Parse Error: Could not find file 'Leaf.tga'
//these declarations are only the bodies for the leaves below
#declare BODY=
height_field
 tga "Leaf.tga"
Parse Error: Cannot open TGA image.
If I outcomment the fountain code (which was generating the previous error).
I tried to get these files here:
http://pkgs.org/centos-6-rhel-6/epel-x86_64/tkgate-2.0-10.beta10.el6.x86_64.rpm.html
using RPMinator1.15b for Mac, but it did not work out. I was impossible to
extract the RPM archive.
Date: 22 May 2012 06:30:01
Message: <web.4fbb6a02c245da6f149d439b0@news.povray.org>
> > // horner's rule
> #declare BODY=
> height_field
>  tga "Leaf.tga"
Update:
I found the files for TOMTREE at his website:
http://www.aust-manufaktur.de/austv2x.html (just click on TOMTREE, the one
written vertically on the right side).
I still need help for the first part of the post, so please HELP!
thank you very much in advance ;)
Date: 22 May 2012 07:28:17
Message: <4fbb7851$1@news.povray.org>
In povray.beta-test you can find the latest version 3.7 RC5 for Mac.
> // horner's rule
Strange. The scene renders without problems here. Using version 3.7 RC5
for Windows, without changes to the scene (except for folder pointers)
Date: 22 May 2012 08:40:01
Message: <web.4fbb8864c245da6f149d439b0@news.povray.org>
> > // horner's rule
> Thomas
I managed to contact the author of the scene. Apparently I had to change point
to pointt.
It works now. Thank you very much.
Hope this post will be helpful for others in the future.
Date: 22 May 2012 18:21:56
Message: <4fbc1184$1@news.povray.org>
Am 22.05.2012 11:45, schrieb sic2:
> // horner's rule
MegaPOV reserves "point" as a keyword for its projection pattern.
As future versions or derivatives of POV-Ray may introduce additional
all-lowercase identifiers as keywords, it best practice to start
variable names with an uppercase letter; apparently though, even the
best don't always adhere to this.
Date: 22 May 2012 18:30:42
Message: <4fbc1392$1@news.povray.org>
Am 22.05.2012 12:21, schrieb sic2:
> #declare BODY=
> height_field
>   tga "Leaf.tga"
The file might actually be named "leaf.tga", "Leaf.TGA" or some such.
This doesn't cause problems on a Windows system, because it uses
case-insensitive filename matching, but on other OS filenames must be an
exact match.
