POV-Ray : Newsgroups : povray.general : crand in Pov-Ray 3.7 ? Server Time
7 Mar 2026 19:28:02 EST (-0500)
  crand in Pov-Ray 3.7 ? (Message 1 to 10 of 12)
Subject: crand in Pov-Ray 3.7 ?
Date: 19 May 2012 18:45:01
Message: <web.4fb822208ba377448aa4293a0@news.povray.org>
Sometimes I want meshes too look a little more rough and get rid of some banding
artifacts. So I used to put "crand" in my finish statements in this case. But if
I use crand in Version 3.7 it has no effect anymore. Maybe it does not work in
3.7 because it was considered obsolete and taken out?
I've already tried small normals with bumps to get a similar effect as with
crand, but somehow it didn't look good, because they were distorted on some
parts of the mesh and not visible in very dark and light areas.
Can anyone tell me what I could use instead of crand in Version 3.7?
Best wishes
Simone
Subject: Re: crand in Pov-Ray 3.7 ?
Date: 19 May 2012 20:29:49
Message: <4fb83afd$1@news.povray.org>
On 05/19/2012 06:43 PM, mone wrote:
> Hi,
> Best wishes
> Simone
try the granite pattern, something scaled small (1e-2 or maybe 3) ...
play around with it!
http://wiki.povray.org/content/Reference:Granite_Pattern
Date: 20 May 2012 16:20:00
Message: <web.4fb951d82aff7d1cef0d539e0@news.povray.org>
Thank you for the tip James!
I tried different scales so far, it's a little difficult, 1e-8 is still too
strong, 1e-9 gives strange results with the lighting and with 1e-10 the pattern
is not visible. Maybe I will try it with a layered texture next ...
Best wishes
Simone
Date: 25 May 2012 22:58:52
Message: <4fc046ec$1@news.povray.org>
still too
the pattern
 > is not visible.
The scale of the normal won't affect its strength. Put a number
immediately after the "granite" keyword to scale down its strength:
normal
     granite 0.1
     // ... scale, etc ...
Date: 27 May 2012 22:50:01
Message: <web.4fc2e7902aff7d1c5f561ae80@news.povray.org>
> still too
> the pattern
>  > is not visible.
> normal
>      granite 0.1
Yes, thanks you. But it wasn't good with a normal because the normal pattern
doesn't show up in dark areas.
So I put it in pigment pattern instead, which did not work either.
But finally I used POV 3.6 again with "crand". (I thought I could get used to
POV 3.7 but it seems to be too different from older versions for my purposes.)
Best wishes
Simone
Date: 28 May 2012 07:42:26
Message: <4fc364a2$1@news.povray.org>
Am 20.05.2012 00:43, schrieb mone:
What exactly do you mean with "banding artifacts"? Some mesh-specific
stuff, or the banding that can occur when you have "slow" color
transitions in the image (such as the sky)?
For the latter, 3.7's "Dither=on" or "+th" works like a charm.
Date: 28 May 2012 08:32:04
Message: <4fc37044$1@news.povray.org>
On 05/27/2012 10:48 PM, mone wrote:
>> still too
>> the pattern
>>   >  is not visible.
>> normal
>>       granite 0.1
maybe then a normal isn't /really/ the answer ... what about an
isosurface sphere with noise?
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.2#Noise_and_pigment_functions
towards the bottom of the above tutorial section are a couple examples
don't give up ... 3.7 is WAY better in many aspects. I think if you try
to push through the initial learning curve the rewards will become apparent
Date: 28 May 2012 10:49:15
Message: <4fc3906b$1@news.povray.org>
That's normal... :-)
Maybe you should show us an example of what you try to achieve. Our
answers would be better focussed I think.
Date: 28 May 2012 11:20:08
Message: <4fc397a7@news.povray.org>
  Note that the granite pattern is quite significantly slower to render
than using crand (well, in pov3.6 anyways, where crand is supported).
  If you want a slightly faster alternative, use the 'bumps' pattern
(scaled vary small).
Date: 28 May 2012 13:08:00
Message: <4fc3b0f0$1@news.povray.org>
On 20.05.12 00:43, mone wrote:
> Hi,
Actually, that crand is still disabled is a bug. I had disabled it early on
during 3.7 development (years ago) and it is still marked as a TODO in the
code. I have opened a bug report for it. It should get fixed in final 3.7.
     Thorsten, POV-Team
