POV-Ray : Newsgroups : povray.general : Using the "built in" timrom.ttf font Server Time
6 May 2026 05:01:21 EDT (-0400)
  Using the "built in" timrom.ttf font (Message 1 to 6 of 6)
Subject: Using the "built in" timrom.ttf font
Date: 10 May 2012 22:30:01
Message: <web.4fac78fae539483dfa88e6bd0@news.povray.org>
I use povray 3.6 under Debian Linux. I see timrom.ttf in the include directory,
but if I simply #include timrom.ttf I get an error, since this is not a text
file. But if I try to use the text command as follows
text {
ttf "timrom.ttf" ...
I get
Parse Error: Cannot open font file.
What did I miss? Thanks.
David
Subject: Re: Using the "built in" timrom.ttf font
Date: 11 May 2012 02:39:49
Message: <4facb435@news.povray.org>
> text {
> I get
> David
Please check your debian-installation: they might have moved the
timrom.ttf out of the expected -L paths in system povray ini file.
(traditional variation is /usr or /usr/local ... distro repackaging sucks)
Quick fix: in your povray.ini ( $HOME/.povray/3.6/povray.ini IIRC), add
line:
-L<path to the directory where timrom.ttf is>
I/O restriction might also be on the way, but it is something I never
use. (I compile my povray myself, so I can disable it)
Date: 11 May 2012 09:00:00
Message: <web.4fad0c7967dcceee6891e8c0@news.povray.org>
> > text {
> > I get
> > David
> line:
I appreciate your help!
When I use the verbose option, povray tells me, before it looks at the input
file, that it uses the library path /usr/share/povray/include, which contains
the ttf files and everything else I should need. I tried cyrvetic.ttf with the
same error. I even ran sudo povray to avoid any read restrictions. No change.
The documentation says "any [true type] font will do." How might I go about
installing some other ttf file?
If I have to, I could define my own "font" built from primitives, but talk about
a kludge! Everything else seems to work well. Could this really be a bug in the
Debian distro?
Date: 11 May 2012 09:16:56
Message: <4fad1148@news.povray.org>
  If nothing else helps, make a soft link in the same directory as the pov
file you are using that points to the ttf font you want to use. Such as
for example:
    ln -s /usr/share/povray/include timrom.ttf .
Date: 11 May 2012 09:38:03
Message: <4fad163b$1@news.povray.org>
WARNING !
povray I/O restriction are not managed by the system, but by povray
itself. Being run as root does not change that mechanism. (at
best/worst, it might change the accessibility of files & folder for the
program, but it won't stop povray from denying the access)
If Warp's answer is useful (having a symlink in the local directory),
then you have to learn how to get the right behavior from I/O
restrictions in the config file of povray.
Date: 11 May 2012 11:40:00
Message: <web.4fad327a67dcceee6891e8c0@news.povray.org>
I found the problem. I typed in .tff instead of .ttf
How embarrassing.
Thanks for your advice and attention!
