POV-Ray : Newsgroups : povray.general : Modulo in 3.7RC4? Server Time
6 May 2026 04:57:29 EDT (-0400)
  Modulo in 3.7RC4? (Message 1 to 2 of 2)
Subject: Modulo in 3.7RC4?
Date: 1 Mar 2012 21:30:01
Message: <web.4f50304e36bcbdfaf7bb1fbb0@news.povray.org>
Hi. I've been using this code in a color map. In 3.6 it behaves as expected. In
3.7RC4,  all my colors are shifted to cyan, magenta, yellow, and white.  This
makes me wonder if the mod() function is behaving differently in 3.7RC4, or if
it requires a different syntax now.  Crazy hypothesis, but so are the results
compared to 3.6.
For any two vectors of length <1, I use:
rgb< mod(a.x+b.x,1),mod(a.y+b.y,1),mod(a.z+b.z,1)>
Subject: Re: Modulo in 3.7RC4?
Date: 2 Mar 2012 08:33:22
Message: <4f50cc22$1@news.povray.org>
Am 02.03.2012 03:28, schrieb gregjohn:
> compared to 3.6.
The mod() function hasn't been touched since ages. But gamma handling
has, and can cause exactly the effect you see.
Instead, try this:
   srgb <mod(a.x+b.x,1),mod(a.y+b.y,1),mod(a.z+b.z,1)>
Or, if you're using this recursively, leave that line unchanged, and
instead set the initial values of a and b like this:
   #declare a = srgb<...>;
   #declare b = srgb<...>;
Alternatively (though not recommended if you're aiming for realism) you
can specify "global_settings { assumed_gamma srgb }".
