POV-Ray : Newsgroups : povray.general : Realistic sky sphere at twilight Server Time
4 Mar 2026 20:57:13 EST (-0500)
  Realistic sky sphere at twilight (Message 1 to 6 of 6)
Subject: Realistic sky sphere at twilight
Date: 7 Feb 2012 13:05:00
Message: <web.4f3167556a6d59495d50475e0@news.povray.org>
hello group !
I found on the net a decent model of the sunset sky some years ago.
http://povray.tashcorp.net/tutorials/qd_realskysphere/
the problem is that with the function max(min(y,1),0) or simply gradient y
the sky is red at the horizon at all azimuth.
To be 100% realistic it should be blue and darker at the opposite direction of
the sunset.
So i thought : Change the function, but correct me if i am wrong, the function
should be (z,y) -> f(z,y) and not y -> f(y) only (when the camera is looking
along the +z axis)
I don't think that a color map can handle two degrees of freedom ??
Other option : two pigment declarations for the sky sphere, one for x, other for
z, and play with transparency : results are quite disappointing , since a dark
streak appears from 0 to 180*y (the goal is to make the sky darker / blue only
near the horizon at the opposite azimuth of the sunset.
Thanks for any ideas !
Subject: Re: Realistic sky sphere at twilight
Date: 7 Feb 2012 15:38:11
Message: <4f318bb3$1@news.povray.org>
the pattern function is 3d to 1d (x,y,z) -> f(x,y,z)
the color_map only maps the 1d value to a color.
So the color may depend on more than one dimension,
(of course, not when using the gradient pattern).
Date: 7 Feb 2012 22:15:01
Message: <web.4f31e82db6d52b385d50475e0@news.povray.org>
thanks, i updated the function, and in my case i can simplify the function since
sunset is at z = 1 on the sky sphere and the opposite point is z = -1, i think
that there are no variations along the x axis, or at least we can omit them and
still have a quite realistic sky sphere.
so i figured this function :
{function { min(max(min(y,1),0) * pow((1 + abs(z - 1)),2),1)
I think that using the f(x) * f(z) form is good to "squeeze" the color segments,
but maybe what i need is to "stretch" the sky sphere to make the entries with a
red hue on the color map go below the horizon.
so maybe this is what i need :
f(x) * f(z) + g(z) (with g(z) growing when z decreasing)
or simply f(x) - g(z)
of course if anyone has some knowledge of the "real" mathematical model for a
twilight sky sphere (and an approximative function) , i ll be glad to hear it !
Date: 7 Feb 2012 23:45:00
Message: <web.4f31fd01b6d52b389726a3c10@news.povray.org>
I looked into this a couple of years ago.  If I recall correctly, a good
approximation can be made by combining a ground fog (Copper can work well) with
a regular gradient on the sky_sphere oriented in the same direction as the sun.
 The gradient's scale and wave form pick the first color in the color_map for
the sky right behind the sun, while the last color shows up on the opposite side
of the sky_sphere (usually below the horizon).  The color_map for the gradient
will vary with the time of day.
The sky sphere simulates the molecular (Raleigh) scattering, while the ground
fog approximates lower-atmosphere aerosol (water and solid particle) scattering.
Date: 8 Feb 2012 16:21:46
Message: <4f32e76a@news.povray.org>
You can combine that with some layered pigments on your sky_sphere.
A gradient with a bright spot where the sun is located, then, a mostly
transparent, filtering, vertical gradient used to tint the "sun" spot.
Then, you can use some fog or even media in a container some distance up
to make your clouds.
Date: 20 Feb 2012 23:15:01
Message: <web.4f43191cb6d52b38d7f39bd00@news.povray.org>
"rodv92" <nomail@nomail> wrote:
> hello group !
> the sunset.
> along the +z axis)
Excellent idea!
I only have one suggestion.  Why not construct the color_map automatically using
a loop and eval_pigment?
load the image as an image_map pigment, scale it to the right proportions
(dimensions don't matter), an
color_map {
    #local cStep = 0;
    #while(cStep < pigment_size)
        [1/numSteps srgb eval_pigment(...) ]
    #local cStep = cStep + stepSize * (pigment_size / image_height);
A.D.B.
