POV-Ray : Newsgroups : povray.general : Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit. Server Time
4 Mar 2026 20:47:22 EST (-0500)
  Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit. (Message 1 to 7 of 7)
Subject: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit.
Date: 2 Feb 2012 19:05:01
Message: <web.4f2b2427af7e52d7f8552de20@news.povray.org>
I am running Windows Ultimate 7, 64 bit on a dual CPU computer.  I already have
PovRay 3.5 installed in a Architectural program.
Do I uninstall the old PovRay 3.5 in the Architectural program first and then
install the updated version "PovWin362-64bit.msi," or can I install the update
over top of the old one?
Which update is best for this system, the PovWin362-64bit.msi or the Beta
Pov-Ray 3.7 for Windows?
Are the Pov-Ray 3.7 for Windows 32 or 64 bits?
Appreciate any help I can get. ;-)
ahed
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit.
Date: 2 Feb 2012 21:02:22
Message: <4f2b402e$1@news.povray.org>
You can uninstall 3.5 or you can keep them side-by-side. If the
architectural program expects 3.5 to be installed it will likely
not work with newer versions.
Definitely 3.7, it will make best use of your dual CPU for rendering
Both are available at http://www.povray.org/beta/
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bi=
Date: 3 Feb 2012 15:15:02
Message: <web.4f2c3fd77a2e2ca1f8552de20@news.povray.org>
Thanks for your reply,
If I keep the 3.5 installed in the architectural program, should I install the
3.7 in the same directory or install it in a separate directory, and if I
install in a separate directory, do you think the architectural program will be
able to access the 3.7?
Thanks again for you help, really appreciated
Ahed
Date: 3 Feb 2012 16:45:02
Message: <web.4f2c55467a2e2ca1f8552de20@news.povray.org>
Ahed
Date: 3 Feb 2012 20:05:46
Message: <4f2c846a@news.povray.org>
Does your architectural program use the PovRay GUIExtensions which is
version of 3.7.
I would install 3.7 in a separate dictionary and point your
architectural program to that exe.
What I did to get Bishop3D to work with PovRay was: Install 3.7 64bit,
then copy the bin folder somewhere. Uninstall the 64 bit version, then
install the 32 bit version of 3.7 and set up the PovRay GUIExtensions
for that. That means Bishop3D will use PovRay 3.7 for rendering. But I
can still start the 64 bit version manually and load the INI file to
render the scene if I want.
Remember that if your architectural program is designed to use PovRay
3.5 the syntax is slightly different in 3.7 and you may need to modify
the generated Pov file to take full advantage of PovRay 3.7
Regards
Date: 4 Feb 2012 16:30:00
Message: <web.4f2da215441c80b7f8552de20@news.povray.org>
> version of 3.7.
> Regards
>      Stephen
This is what in the Povray directory inside the architectural program:
PovRay - ini - PVEngine.INI and pvtools =
PVEngine.ini =
[Permitted Input Paths]
1=%INSTALLDIR%
2=C:\WINNT\Fonts
[Permitted Output Paths]
1=%INSTALLDIR%\Renderer\ReRun
2=%INSTALLDIR%\Insert Menu
[General]
CheckNewVersion=0
SendSystemInfo=0
No sign of "PovRay GUIExtensions".
I played around a little and installed the 3.7 win64 bit, where it wanted to go
then I removed the 3.5 and replased it with a copy of 3.7.  The architectural
program is still working. ;-)
I am looking forward to learning to use the PovRay 3.7, at this point I don't
know if it is working or not, as I never heard about this program before.
Have a great weekend
aned
Date: 4 Feb 2012 17:00:49
Message: <4f2daa91@news.povray.org>
> program is still working.;-)
Thank you and have a good weekend yourself.
You have come to the right place to learn about PovRay.
As you probably know PovRay only renders your image from a sctipt
generated by your architectural program. Which one is it by the way?
The entry in [GUIExtensions] allows your program to start PovRay and to
tell it which file to parse and render. My entry is:
[GUIExtensions]
UseExtensions=1
ExtDll17=C:\Program Files (x86)\Bishop3D\Bishop3DPovComm.dll
ExtDll18=C:\Graphics\Moray For Windows\MorayCtrl.DLL
This allows the modellers Bishop3D and Moray to communicate with PovRay.
Both of these programs amend the pvengine.ini file when they are
installed or via their preferences or settings menu.
If you have any questions to not hesitate to ask
Regards
